Results 1 to 15 of 15
Thread: 0w-40 Oil?
    Senior Member Three Rings rbish56's Avatar
    Nov 16 2018
    LSX swapped 86 cutlass 442
    chicago
    0w-40 Oil?
    i picked up mobil 1 oil from costco 6qts for $28. It meets audi standards for oil but is it wise to use it? i am stage 2 UM tuned. on all the websites i see 5w-40 being used. i just want to make sure ill be alright. i plan on changing the oil in 5k miles. can anyone advise? thank you!
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    0W40 just means you'll have better oil flow at lower temperatures compared to 5W40. That is what the "W" rating on oil grades refers to, stands for "winter".
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    No concern. I ran M1 0w-40 for over 40k miles before switching to Rotella 5w40.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Nov 16 2018
    chicago
    thank you, guys! why the switch to rotella if you dont mind me asking?
    Junior Member One Ring
    Sep 17 2017
    Dallas
    I am pretty sure “W” stands for weight.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by rbish56 View Post
    No reason other than Walmart had it on sale when I was oil shopping haha. Runs great in both the q5 (V6T) and B5 1.8t.
    Quote Originally Posted by superk1075 View Post
    +1 Figured he was just trolling but idk Audizine can be surprising lmao.
    Nov 23 2018
    New Jersey
    I just bought some. Doing my oil change today actually. Mobil1 is the best. They put the most research into oil and they are a category 5 oil, I think.
    Sent from my LM-G710VM using Tapatalk
    Veteran Member Four Rings RDA990's Avatar
    Jan 07 2013
    Germantown, Maryland
    Quote Originally Posted by q5 dave View Post
    It does actually stand for winter:
    https://www.valvoline.com/about-us/f...-viscosity-faq
    Quote Originally Posted by Valvoline
    What does the "w" in a grade of motor oil stand for?
    The "w" in motor oil stands for winter. The first number in the oil classification refers to a cold weather viscosity. The lower this number is, the less viscous your oil will be at low temperatures. For example, a 5W- motor oil will flow better at lower temperatures than a 15W- motor oil. The higher number, following the “w” refers to hot weather viscosity, or how fluid your oil is at hot temperatures. The higher the number, the thicker the oil at a specified temperature.
    Brilliant Red B6 A4 1.8T quattro Ultrasport
    Frankenturbo F21L | Motoza Tuning | FMIC | Test Pipe | Bosch 550cc | 710n DV | Podi Boost Gauge | 21 PSI
    Dolphin Grey B6 A4 1.8T quattro
    Brilliant Red B7 A4 2.0T quattro
    Sep 17 2017
    Dallas
    You’re right, just learned something new.
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Use 0W-40. Usually it has "higher grade" base oil than 5W-40. For example castrol OE 5W-40 (stuff sold to dealerships) is formulated with cheaper base oil than castrol 0W-40 (will say made in Belgium or German).. search on this topic at bobistheoilguy.com
    Sent from my ONEPLUS A3000 using Tapatalk
    Jul 10 2016
    Quote Originally Posted by Davethaboss View Post
    Mobil 1 0W-40 is not true group V (ester based) oil. It is still a very good oil for the price. I believe it is group III (hydrocracked ultrarefined oil) + maybe some group IV (PAO) + additives. I run M1 in my Audi
    It is my understanding that true Group V oils are brands like high end stuff like Motul and Redline.. but $15/qt engine oil is probably overkill outside of professional racing. Look up MSDS in oils you buy,it is often a blend of different base oilz..
    Nov 23 2018
    New Jersey
    Quote Originally Posted by n8vs3 View Post
    Mobil 1 0W-40 is not group V (ester based) oil. It is still a very good oil for the price. I believe it is group III (hydrocracked ultrarefined oil) + maybe some group IV (PAO) + additives. I run M1 in my Audi
    I went to proof read my comment because, I forgot if it was group V or IV. I thought I made the change but, it did not. Thank you for correcting the incorrect statement.
    Nov 16 2018
    chicago
    thanks man, i appreciate this!
    Dec 25 2004
    Earth
    My S3 performs better with 0winter 40 oil😎
    - - - Updated - - -
    I run Castrol😎
    Summer I will run 5summer 40😋
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    higher weight = higher drag, windage and more heat (and worse heat transfer to the cooling system) and less hp delivered to the wheels. On the flip side, if you don't have enough film thickness you don't have enough lubrication. Really need an oil pressure gauge to see if your oil is in the right range for your driving environment. In racing, we often run "0" weight oil or as thin as will deliver about 10psi oil pressure per 1,000 rpm.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
