Originally Posted by
CELison
These motors are very stout. If you pulled the heads off yours, I guarantee the cross hatch is still there. Plenty of 200k+ mile stage 3 cars with great compression. They almost never have issues related to the rotating assembly/rings/ect. The problem isn't rebuilding the motor, it's the power you will want to make on your freshly forged tower of power. When you make 650chp on a motor that was designed for 250chp, issues are going to pop up more often than a normal stage 3. Of course you can run a mild power level, but there's not fun in that. At least for me, I'm in kill mode all the time in case I run into any fun on the highway. E85 in the car for 2 years besides storing it over winter. If you're prepared to put up with the issues, then let it rip. But it was 25 degrees and snowing this morning. If I had to fiddle fuck with my car at 7am in this shit I would not be too happy.
If you can afford it, buy a cheap reliable daily. Jeep XJ, 2.8 B5 (I've owned both) ect. There will at least be times when your car is down for a couple days and you need to get places, or it will have issues, but be drivable, but you won't want to drive it bc something is fucked up. At least for me, it's a headache I wouldn't want.
Issues that came up after going the built motor route. All of these would be very annoying if it were my daily. Obviously these are not all built motor issues, just b5 issues.
1. clutch began to slip on E85
2. Heads lifted at full tilt (think I fixed this, but jury is still out)
3. Fuel pump couldn't keep up
4. Fuel fittings leaking with fuel injection clamps
5. wg needed adjusting (again)
6. wideband took a shit
7. 2 coolant leaks
8. coolant res cap failure
When this stuff happens, it's nice to be able to just let the car sit in the garage until you have time to fix it right.
I appreciate your input and the phrase "freshly forged tower of power." Would you dissuade against DD'ing a stage 3 in general (I know you had multiple turbo issues but outside of that)? Not sure if during any of that 2009-2017 your stage 3 was a DD. Also, would be great to have a daily driver and have this car just be a fun weekend car but it's not in the cards with the current living situation in the city, ie parking/storage so seeing if it can be both. It's not perfect, but seeing what those who have been through it and wiser than I think.
I understand running at a mild power level similar to a "normal" stage 3 during most driving and having a higher boost tune for weekends/spirited drives may not be ideal for you, but I am thinking it sounds like a solid option for what I am looking for. Do you think it could potentially accomplish a balance of normal stage 3 reliability with extra power available for certain occasions? I'm very interested in thoughts on this.
VR6Bomber
Is it now twice a week that we have to discourage someone with grand plans to DD a stg3?
I can't add anything to what has already been said above, all very good advice.
For your perspective:
I am having a motor built right now:
$6k on the bottom end (via the cheapest route: IE's and JE's 1mm overbore, bearings, seals, new oil pump, chains, ARP mains, balanced checked, new flywheel, the basics and nothing crazy)
$6k on the top. (mildly worked/built 2.8 heads)
So $12k for the long-block including timing gear and accessories.
$5k on a pair of TTE's. (just for the turbos, no inlets or hardware, etc)
Did you see how fast we got to $17k....
We didn't get to fueling or tuning yet...
Many 2.7 projects never get finished because they end up costing way more than originally projected.
Whatever you think it will cost, double it. That's the best advice I can give.
Sorry, same question as I asked CELison. It sounds like you wouldn't recommend DD'ing a stage 3 in general? If you don't think it is a terrible idea to DD one what are your thoughts on the build with a mild tune and extra power available for certain occasions?
I appreciate your input and in regards to cost I have not doubled the amount I think it will cost but I have put a decent cushion in place for miscellaneous items that could very well arise. I'm not planning on a full motor build really just forged rods, new bearings, studs, balanced, re-ringing pistons, timing belt/water pump job and reseal. The only other thing at this point that I'm considering is a different set of cams and possibly doing something with the heads. I really do appreciate all the input and don't want to be the next person selling off parts in the classifieds because I got in over my head. For a fully built motor like you are having done, I completely agree it's more than I have budgeted. The price difference between the forged rods, bearings, studs, re-ringing pistons and balancing I see being a difference of around $1k in parts. I am really not trying to be argumentative, I want to make sure I'm not missing anything or going in blind which is why I am asking these questions and again very appreciative of all the recommendations and responses.
Alchemy
I'm glad your head is in the right spot with tackling the accessory stuff as well. My $.02 is to focus on maintenance items & go for a K04 stage 3 car on E85. For daily driving it's hard to argue with a well put together k04 car where you're into full boost just north of 3,000rpms. Save the $ you want to spend on the engine internals and focus on a proper suspension and brakes, it well breath new life into the car.
You'll be happy and the car will last a LONG time. My k04 car has been in it's current state for over 10 years according to all the maintenance records I have, once you start cranking on these blocks all the weak links begin to become apparent and frustratingly annoying where as most well cared for k04 cars only need timing belts, clutches, olil changes, spark plugs, and the occasional reseal @100k intervals.
I appreciate your input and I do want to make sure that I do what I can, within reason, to make it as reliable and fun as possible. The proper suspension and brakes will definitely happen, I just forgot to add those in the original post. It is refreshing to hear that you have had over 10 years on your K04 setup. Do you mind providing your thoughts on the forged rods with a mild tune with the goal being to not constantly be pushing the block and seeing the weak links, while also having a high power tune for certain occasions? (Sorry for all the repetitive questions, this seems like it could be ideal for me in theory but I'm not sure if it would translate to the real world results I'm hoping for).
I am really appreciating all of this advice and it is definitely making me consider what makes the most sense. Please keep the information and advice coming!
