Results 1 to 17 of 17
    Established Member Two Rings Orpo's Avatar
    Apr 15 2014
    Montreal
    Stock RS3 HP with 91oct vs 93/4 oct
    Afraid to ask...
    I heard a YouTuber make the following statement on a stock RS3 and I’m curious if it’s true.
    The statement was. A stock RS3 will make 400hp with 91 octane fuel, however, if you use 93/4 octane the RS3 will make 420 hp.
    I have my doubts, but is there any truth to this?
    Thx
    Established Member Two Rings ChrisR14's Avatar
    Sep 08 2015
    2009 VW MK6
    Germany
    It depends on the ECU software they're running. Higher octane ratings give you (or your ECU) the ability to utilize more aggressive ignition-angles which leads to more power and torque.
    This is commonly a benefit you can take when you're running a tuned map on your ECU which includes more advanced ignition timings.
    The 2.5 TFSI has a quite modern and intelligent ECU so the above statement seems possible since the european RS3 comes with the recommendation to fill with "Super Plus RON98" which equals to 93 AKI.
    You can check it yourself by logging the ignition angles in VCDS with 91 oct. If you see the ECU pulling timing you'll most likely have more power with 93 oct fuel.
    2014 Audi S5 3.0T STronic // Estorilblue
    VAG Coding and retrofit expert
    Nov 06 2017
    Vancouver
    It will probably make more on 94, but 20hp I doubt it. Maybe 5-8.
    Around here we have 91 10% ethanol and 94 no ethanol, I bet they're about the same. You can't really compare to anything in Europe because the engine mapping is different.
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    Stock, on average (comparing all dyno's), will yield, imo, over 425chp.
    Would guess +/-436chp on 93 octane.
    May 20 2010
    Audi does have a tendency to underrate their engines on paper. The B8s were notorious for this. So I wouldn't be surprised to see >400 hp, though by how much is another story altogether.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Stage 2 Banner Advertiser Three Rings Brian@Unitronic's Avatar
    Jan 11 2019
    PA
    you will see a good bump in power on the stock calibration switching from 91 to 93/94 octane.
    you can see this in the trap speeds of guys running e20 on the stock calibration
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Mar 09 2018
    2018 RS3
    If you have access to E85 in your area , you can mix up to E30 on the stock ECU without issues.
    Florett RS3+DS1+034TCU
    Apr 15 2014
    Montreal
    I’ll admit I was skeptical.
    But maybe there is something to it.
    Thx all
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    Quote Originally Posted by Potatohead_RS3 View Post
    No it isnt
    Jul 12 2018
    UK
    Not sure on the values, because I've seen some put stock at 395-400hp and others at 420-430hp (on 93ron). My TTRS is almost identical on 1/4 and 100-200kmh times to one that pulled 410hp on the dyno, but then that doesn't mean anything either...
    What I will say is that my local 99RON is 93.5AKI and I've done a bit of ethanol/methanol blending, given some of the test times in Germany seemed a bit faster than I was achieving. At about E15 equivalent I was achieving similar times which should be about 102RON/95AKI by my calc. Aral 102 pump gas in Germany is 102RON. Perhaps the Audi engineers stopped off at their local Aral before handing it over to the ECU calibrators...
    Jul 13 2018
    Winnipeg, MB, Canada
    I used both 91 and 94 on the stock calibration and I didn't notice a difference subjectively. Now that I have a dragy I could do some testing in Mexico, but there are so many other variables.
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
    Established Member Two Rings sti-tom's Avatar
    Nov 17 2017
    Edmonton
    Quote Originally Posted by TheContrarian View Post
    What ethanol content do you have in Winnipeg? In Edmonton we have 91Vpower with no ethanol and 94Husky with 10% ethanol. I am really interested to known what the difference in power could be. For SCCA autox you are allowed up to 15% ethanol, so I would also like to see what power would be made by mixing some E85 with the 94.
    Apr 20 2018
    Chicago
    Quote Originally Posted by sti-tom View Post
    On the stock tune not much. With a 93 tune adding a couple gallons of e85 can help if the tune is a little aggressive to prevent knock. Not recommended as the tunes aren't setup ideally for e25, but several seem to like this.
    Senior Member Two Rings SolarRS3's Avatar
    Jul 09 2018
    2016 KTM Superduke 1290R
    Winnipeg
    Im in winnipeg as well, we have the same as you in Edmonton, 91 vpower 94 10%e husky. I did not test with 91 only but with 94 i got 11.89 @ 115
    Active Member Two Rings Carguycbf's Avatar
    Oct 15 2018
    2017 Audi Q7, 2006 BMW 550i
    Monterey
    How would 100 octane work with a Uni stage 1+ tune? I am in CA and no 93 but I live near Laguna Seca and they have 100. Would the Uni Stage1+ tune work or would custom tune be required to get bump from stage 1 with 91 octane. E85 is not readily available in my area.
    2018 RS3 Daytona Grey
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    UNI probably has a 100 unleaded map available if you ask for it. That would rip! However you can always put a few gallons of 102 in the tank to bring the overall octane up to the level you are trying to achieve.
    Veteran Member Three Rings doady22's Avatar
    Feb 28 2010
    ft collins colorado
    If you look on APR's website they measure a 26hp 18ft-lbs from 91 to 93 so yes there is some to gain. I believe Audi tunes their cars to run optimal on 93 from the Factory.
    2018 S5 Sportback, ECS Intake, Milltek HFC, Wagner Tuning IC, EPL E40 Stage 2, ABT HAS Springs, Vorsteiner Vff 107 20x10 ET30, Headlights by Oneighty NYC
