Results 1 to 37 of 37
    Apr 27 2018
    Massachusetts
    stock S-line suspension with 19" wheels
    Did a forum search, couldn't find anything. thinking about getting new wheels/tires for my 2015 audi a4 S-line, but not if im gonna look like a monster truck and living in Massachusetts I dont really want to lower my car any more than it is... Can anyone show me pictures specifically of the OEM S-line suspension with 18 inch or 19 inch wheels?
    Established Member Two Rings hpmurdarah's Avatar
    Dec 26 2016
    Hyde park ma
    Doesn’t your car come with 18 already?
    Sent from a place far far away!!
    Apr 27 2018
    Massachusetts
    yes. sorry, meant just 19. not sure why I put that.
    May 10 2015
    Pittsburgh PA
    First, is you car actually S-Line or does it just have S-Line appearance package? If your car is S-Line you will have the sport seats and 3-spoke steering wheel. I ask this because cars with either the full S-Line package or the Sport package have lower suspension from the factory than cars without. With that lower suspension the 19s look really good.
    That said, the Prestige trim-level A4s were available with 19" wheels from factory when equipped with S-Line (which I believe was standard for the Prestige model). Also, the S4, which has the same ride height as the S-Line and Sport package A4s, was available with 19" wheels from the factory.
    Here is a stock A4 S-Line on 19" wheels
    Here is a stock S4 on the same 19" wheels
    Hope that helps!
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    Ya, I was going to say the same thing 19birel said above. I have S-line badges on my car, but I don't have a true S-line. Only the bumpers and side blades. If you have the S suspension and are having trouble finding what 19's will look like on the A4, just head over to the S4 model discussion and im sure you'll find a plethora of them on their stock suspensions.
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    I have a s-like package on my a4 and I have a set of Avant Garde M621 19x9.5 et35 that i’m waiting to put on (18” winter wheels rn) and I have a set of coilovers to also put on soon after, the look of 19” rims on the a4 with stock suspension looks alright to me but I really want to limit the fender gap, so I plan on lowering it 1.5” at first.
    I have seen tons of a4’s with 19” rims without lowering the suspension and they look pretty OEM even tho they came from factory with 18”
    ideally the best thing to do is just talk to a shop and figure out what set up you’re trying to go for and work towards that.
    IG @Colorado.a4
    Apr 27 2018
    Massachusetts
    Well now im paranoid! how do I know if my car is a true S line or if it isnt?
    Quote Originally Posted by NathanGreatScott View Post
    Dec 04 2018
    Quote Originally Posted by beantownb8.5 View Post
    s-line appearance package has the s4 front bumper, honey comb on rear “diffuser” and s-like badges/door sill plates. sport package has the 3 spoke steering wheel and some other things like sport seats. A true s line car is the s4 I guess?
    IG @Colorado.a4
    Apr 05 2017
    Western PA
    If you have the 3spoke steering wheel AND sport seats (pretty sure they say Sline on them just below the headrest, but i could be wrong), you definitely have a true sline and will have the sport suspension. You can also refer to your monroney sticker to see if it mentions sport suspension as an option. If you email AoA your VIN, they can provide you with it.
    Apr 05 2017
    Western PA
    another easy way would be to measure your ground to fender height. I'm not sure what mine is off hand, but I can measure it when I get home to tell you what the stock A4 height would be, then you can compare to that.
    Apr 27 2018
    Massachusetts
    Quote Originally Posted by colorado.a4 View Post
    well s**t. appearance package- dont have the 3 spoke steering wheel. not sure why my car looks lower than other A4s ive seen
    - - - Updated - - -
    Dec 04 2018
    - - - Updated - - -
    curious to see how many miles you have? if you’ve ever had suspension replaced?
    IG @Colorado.a4
    Apr 27 2018
    Massachusetts
    42k. bone stock, always serviced by audi. I thought it had to do with the wheels I had on it as well, but I guess not
    Established Member Two Rings studioRS's Avatar
    Jul 19 2013
    So Lake Tahoe
    In case you are still interested...
    My 2012 Avant Prestige S line with factory sport suspension option.
    Using my Hartmann RS6 19” wheels for winter duty. It came equipped with 19” rotors.
    2016 Audi SQ5 Glacier White Metallic, technology & black optic packages
    Dec 04 2018
    suspensions, well the springs themself, tend to start slacking when you have a higher mileage. when I bought my car from audi (cert pre-owned) it had brand new suspension bc the previous owner had aftermarket struts on. this could explain why your car looks a little lower than others, don’t quote me on that but is a possibility based on mileage, road conditions, etc
    IG @Colorado.a4
    Established Member Two Rings B8A4Kevin14's Avatar
    Jun 20 2017
    RIP:2014 A4 2.0T/RS Grille/APR Stage 2/19" Black Alzor 349/Custom S4 custom Exhaust
    White Plains NY
    IMG_5853.JPG 2014 A4 stock-suspension with 19”
    Sent from my
    Active Member Two Rings adrianreece's Avatar
    Dec 06 2016
    '14 A4
    Fairfax, VA
    Here is my '14 A4 that has the S-Line Sport Suspension and stock 19's. All suspension is stock.
    2014 A4 P+, APR Stage 2, 034 HFC, ECS Luft-Technik intake, GFB DV+, ECS Transmission and Diff inserts, ECS weighted shift knob, ECS vent boost gauge, ECS resonator delete, Akibono ceramic brake pads.
    Veteran Member Three Rings keiffr's Avatar
    Feb 19 2014
    2006 Land Rover LR3 SE V8 4.4L
    Fresno/Clovis, CA
    Here’s my 2011 on 19”s with Stock suspension vs lowered on coilovers
    2011 A4 2.0T TFSI Quattro P+/ Phantom Black
    IE Stage 1 / A5 S-Line Y-Spoke 19x8.5 Wheels Offset: ET32 / 255/35/19 General G-Max AS-05 Tires/ Solowerks S1 Coilovers
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Check the color coding on your springs. Clicky click®
    Apr 05 2017
    Western PA
    My non-sport suspension is 27 1/4” gtf
    Senior Member Three Rings vincent_nguyen2's Avatar
    Oct 05 2016
    2014 Audi A4
    Dallas, TX
    Top: Stock
    Bottom: Wheels, coilovers, grill, tint
    It’s the only picture I got stock, but both wheels are 19” and with just a few total mods the car transforms greatly
    2014 Brilliant Red A4 Premium + S-Line
    APR Stage 2 w/ Downpipe | AWE Tuning Quadtip Catback | Airlift V2 | VMR V802 Anthracite Metallic on Falken FK510 255/35/19 | Macan 4P Front Brembos
    2022 Florett Silver SQ5 Prestige
    Maxton Design full exterior kit | IE Intake and Turbo Inlet | IE Catback w/ Audi Sport Tips
    Apr 05 2017
    Western PA
    Quote Originally Posted by vincent_nguyen2 View Post
    Top: Stock
    Off subject, but are you running spacers on your wheels? I'm installing 20x9's and solowerks in the very near future and was curious if your 8.5" wheels are getting you that look. Thanks! Looks great btw
    Oct 05 2016
    2014 Audi A4
    Dallas, TX
    Thank you! I’m not running spacers. I believe those wheels are actually the same specs as the factory one’s. I believe I oh so slightly rub the rear fender liners, but the fronts may have just escaped the fender
    Apr 05 2017
    Western PA
    Thanks man. I guess the wheel offset will play a role on this too and I'll probably have to play with the height a little once I get them on. trying to avoid rubbing or running spacers, but want to keep things looking flush.
    Established Member Two Rings wayneair's Avatar
    Feb 24 2008
    14 Q5 TDI Premium Plus, 06 A4, 08 Chevy Trailblazer SS, 97 Moto Guzzi Sport 1100i
    Clemmons , NC
    This is simple, you can keep very close to, if not the exact same, original ride height easily. When you switch to a larger wheel, use a lower profile tire. This way, the overall diameter stays the same, so ride height remains the same. Another factor to consider: factory 19s are usually associated with more robust factory sport suspensions, as the damping effect of tires diminishes as you move to lower profile tires, this is accounted for in the engineering and design of the entire suspension system. For a given suspension system, 19s are a harsher ride than 18s. The system must absorb much more energy due to there being less tire present to absorb initial impact. But to your initial question, keep tire profile in mind and you won't have any issues. There are wheel/tire calculators online where you can play around with sizes to find the right size to keep the same overall diameter.
    Sent from my LG-LS998 using Audizine mobile app
    06 A4 2.0t FSI - HPA K04 - Unitronic 2+ - owned since Feb 2008
    14 Q5 TDI Premium Plus - APR TDI tune - owned since Feb 2021
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    2011 s line with stock 19"
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Veteran Member Three Rings dennej1985's Avatar
    Jul 23 2012
    Wyoming
    Here’s mine with a couple different sets. 19x8 rotors, 19x9.5 VMR 810’s, and 18” sport wheels for winter. Car is on stock S-line+sport suspension in all photos.
    Now: 2014 S4 |6MT|Estoril|Lunar/Black|AFE|
    Then: 2012 A4 Quattro 2.0T 6MT
    2003 A4 Quattro Avant 5MT
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    Here is my 2011 S-line with stock 19"
    Sent from my SM-N960U using Audizine mobile app
    2011 A4 Avant Prestige S-Line
    Veteran Member Three Rings S-Liner's Avatar
    Oct 21 2014
    Illinois
    '10 A4 Avant Prestige Plus S-Line w/sport pkg
    My Oil consumption results..."Oil consumption measurement found to be using 3.26 quarts per 1000 miles"
    Veteran Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36(98)M3 convertible//VW B6(07)Passat
    Bel Air Maryland USA
    Yi
    Veteran Member Four Rings kaz02a4's Avatar
    Jul 04 2012
    2012 A4Q 6M
    Rochester, NY
    Just to clarify here, I believe you could have the sport package separate from the S-Line package. In other words, sport + S-Line does not = true S-Line. My car has both packages, and is not the true one.
    You need the sport seats that are labeled with "S-Line" (I believe they are alcantara?) as well as the steering wheel with the badge. It should look something like this:
    RIP B7: Stg. 1 UM, RS4 rear sway, Apikol snub mount, trip computer retrofit, OEM bi-xenons retrofit, RS4 seats retrofit, B7 S4 Ti wheels, BSH CC, 034 SD mounts, restitched steering wheel by my own hand
    Hello B8: P+ Quattro, 6 Speed, Sport. Stg. 1 APR, CR-15, Fly Designs steering wheel, Euro Impulse shift knob, Macan BBK, Alu Kreuz, 034 RSB + endlinks, SPC control arms...
    Apr 05 2017
    Western PA
    Quote Originally Posted by kaz02a4 View Post
    Yes that’s a good point. I’m assuming the sub thinks he has an sline because he has the fender and doorsill badges. And I believe you could have the sline style package and sport suspension as an option. I’d recommend the OP get his monroney sticker from Audi so he can check what options came on his car. It’s a simple email to AoA
    Established Member Two Rings seansuth's Avatar
    Aug 25 2017
    Verona, NJ USA
    I have the stock 19s and lower S-Line suspension
    Looking for: 2015 Nogaro Blue S4
    Morristown, NJ
    www.instagram.com/a4fromnj
    www.designbyno9.com
    Jul 02 2017
    Knoxville TN
    Sports package came with 3 spoke steering wheel, sport suspension and sport seats. S-line came with alcentera seats and black interior and IIRC black headliner.
    All of this is in the sticky buyers guide
    https://www.audizine.com/forum/showt...uestion-Thread
    Oct 26 2017
    San Francisco
    Quote Originally Posted by Novarider View Post
    This only holds true for the B8 cars. The OP has a B8.5.
    For B8.5 S-line appearance package just has different front and rear bumpers and some S-line wheels (18 and 19 available).
    Sport package adds 3 spoke steering wheel, sport seats and sport suspension which lowers the car and is stiffer.
    You can have Sport without S-line and vice versa. They are standalone options and not very common together for B8.5.
    To add to the confusion:
    2014+ A4 all had S-line Appearance package as standard equipment. Sport package was still an additional option.
    2015+ added 3 spoke steering wheel as standard equipment on top of the standard S-line appearance package. Sport package still an option.
    I guess for B8.5 a "true" S-line car would be S Line + Sport package.
    Don't even get me going with the B9 cars... just about all the ones I've seen have S-line badges all over. lol
    2014 Audi A4 Quattro - S Line, Sport package - GIAC Stage 1 v2 E85 tune, Endless MX-72
    Junior Member Two Rings
    Feb 08 2020
    Tampa, FL
    True. Theres SO many variations of this car. I have a 2015 S-Line and it has the door sill blades, fender badges, S4 bumpers, newer 3-spoke steering wheel without badge, regular non-sport seats, and I believe regular monster truck ride height lol.
    Quote Originally Posted by z k View Post
    Oct 05 2016
    2014 Audi A4
    Dallas, TX
    Late to this thread, but here’s my OEM S-Line on OEM 19” wheels
    Also different 19” wheels before I lowered it (sorry for the individual photos)
