Results 1 to 40 of 45
    Veteran Member Three Rings csobel's Avatar
    Mar 25 2018
    Portland, OR
    Let’s talk big HP B5’s and fast drag times
    Questions for discussion:
    —Who do you guys think holds the fastest B5 S4 1/4 mile time?
    — What qualifies as a B5 S4? Does it need a 2.7t? Interior? What kind of gearbox? What I’m getting at is, at what point is a B5 S4 just a shell and not really the real thing?
    — What would it take to build a monster?
    Cheers
    Active Member Four Rings
    Nov 12 2013
    '01 S4 Tip '91 200 20VTQA, '01 A6 2.7TA, VW Rabbit GTI truck.
    SanHo, CA
    1. Someone ran a 9.something.
    2. To me a VR6 turbo conversion is no longer a B5S4 but that's IMHO. Engine should be based on the 2.7 long block. 3.0 and a single would still be a B5. Any gearbox. Gutted with AC delete is fine but it's got to have the exterior body.
    3. Lotsa moolah...
    Registered User Four Rings
    Sep 01 2013
    Sweden
    RS4 limo run 10.1 officially, 9.9 unofficial with 890whp setup.
    3L stroker v6, stock 01 tranny.
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Usp 8.70 @170 ?
    /vr6
    I guess if you weld the diff, strip to the shell, and swap the motor, its a purpose-built 'racecar' at that point.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Vr6 is still an Audi/vw product
    so definitely still a b5 s4. Also
    the USP car is still using everything
    Audi minus the rear diff. Everything’s
    been beefed up but same layout
    more or less. It’s also not gutted
    and weighs 3,000lbs per NSCRA
    rules.
    It’s gone faster than 8.7 to date and
    that’s with Chris still shifting gears.
    It is a dogbox 01e but doesn’t have
    a sequential shifter.
    The only 9 second 2.7t cars I know
    of that aren’t gutted are the TTE cars
    in Europe. Other than that everyone’s
    chasing a ghost with this platform.
    Guruman and tweets did 10’s a decade
    ago on tials and gt’s. You had fasts4
    with a gutted k04 car in the 10’s too.
    With the 2.7t you have to spend twice
    the amount of money and break twice
    the amount of shit compared to other
    platforms to hit 9’s or low 10’s.
    To put it in perspective a stage 2 rs3
    or ttrs can pull a high 10 pass. Also
    the old I5 can be built and made reliably
    fast for way cheaper.
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by landfill View Post
    A big component to those cars achieving those numbers is the DSG, it's such a huge advantage over the 01E.
    2024 M3 Comp xDrive
    Sep 01 2013
    Sweden
    I have logged gear changes with std 01 tranny and compared to DSGs that changes gears in 0.01sec. We loose about 1.5sec in just gearchanges 1-2, 2-3, 3-4th and faster cars even 4-5th
    This puts us way behind ofc and the times doesn’t look so impressive.
    So, if we play with thought that we could avoid gearchange timeloss as DSG cars, all B5s that did 10s are actually in low 9s which all of the sudden makes it super quick.
    Mar 25 2018
    Portland, OR
    Has anyone done a DSG swap yet?
    Jun 07 2005
    Shepherdstown, WV
    Quote Originally Posted by csobel View Post
    The front engine longitudinal DSG sucked, failure prone and didn't hold power which is why most of the high power cars used the TC based ZF not a DSG, even the S4 dropped it and went to the ZF for the B9
    The transverse DSG is an entirely different box and much stronger, or least seems to be so far in the applications like the transverse RS cars.
    Also the B8+ cars moved the front wheels further forward/engine back in relation to each other. The output flanges for the front shafts are actually in front of the flywheel.
    80 rabbit pickup, 98 TJ 4bt cummins, 00 180TTQ 6spd, 02 Freelander, 03 Allroad 2.7t 6spd swap now with K04s, 06 A3 2.0T w/GT3071R (2012 JSW TDI and 2015 GSW TDI now in TDI purgatory )
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Dogbox ;)
    Nov 14 2013
    ^^^This, for cutting serious
    times. They all have custom
    gearing and a lot of them are
    clearing the traps still in 4th
    at 160-180mph.
    Also the stage 2+ e85 ttrs in 6
    speed is still really quick for a
    stock turbo 2.5L car. The DSG
    trannies are unreal though. Fast
    shifts but a numb driving experience
    IMO even with software.
    Sep 01 2013
    Sweden
    I got a buddy in US who’s building 770r car with AZR. Will be using DogBox as well. If he doesn’t brake some records - non will.
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    I will finally be running this year. See what happens
    Quote Originally Posted by Mocke View Post
    gonna take alot more than 770 and a dog box to break some records
    Apr 07 2011
    Home of the mighty beaver
    Lol
    Jun 14 2007
    2000 S4
    Connecticut
    My opinion on it is there are two buckets for drag times with our platform. One bucket is anyone still running the stock engine as a base (including of course those who have a slightly oversized variant with a bore/stroke) and then another bucket is those with different engines all together which I think at this point is mostly just a VR6. I don't however dismiss those with a different engine as not being S4s, you just can't really compare the two directly as it isn't apples to apples. Clearly with USPs car as the prime example, in order to get the S4 into the seriously fast territory you have to go pretty extreme measures.
    All these years after Marc ticked off the 10.7 in his gutted RS4-K04 car it's funny to think people keep trying to throw more HP at the problem to solve it. I never got really into drag racing, but using the new RS3s as an example isn't the problem mostly with our tranny?
    Sep 01 2013
    Sweden
    The problem is not in horse power. Its in the tranny. Thats a known fact.
    USPs car is hardly to compare to. Its a purpose built drag car.
    What do we have left?
    Phills 10.1 and lots of 10.7 cars.
    770s with E85 n Meth can easy make 700+ whp. With 01 tranny out of the equation beating 10.7 should be done in a bad try.
    May 13 2009
    XXXX
    Are we now referring to the manual shift as a 'problem'?
    If so, I'm going back to MG forever, where people still shift their cars!
    /Get off my lawn!
    Mar 25 2018
    Portland, OR
    Has anyone seen improvements going to a different manual tranny like the 0A3 or TDI or other?
    Established Member Two Rings Alchemy's Avatar
    Jan 14 2018
    North Carolina
    This has perturbed me for some time now. I mean we are talking about what is arguably one of the most, if not the most, notorious AWD platform in the car world yet hearing of 10s with power levels well in access of 700whp is rare. Is this because the people dropping the dough to use take the 2.7t don't care enough about it to keep breaking shit from hard launches or is it because the gearing ratios are just not up to snuff for superior 1/4 times? Perhaps a mixture of both?
    Personally I like roll racing.
    Driven to Succeed
    Apr 07 2011
    on a roll i beat a mid 10s dsg car... but I cant do better than mid to low 11s
    transmission is poor.
    Dec 23 2009
    Brazil
    The 01E, specially with the 2.7 powerband and the stock gear ratios are the problem in my opinion.
    There is a guy in Poland I think, that is running low 9 on a single 2.7 with an auto gearbox. And its not that powerful. He was running low 10s with 600hp. NOT whp.
    Pure ethanol R770
    Nov 14 2013
    It’s not the tranny itself but
    the gearing. You can buy
    different ratios from Europe
    or a tdi box for starters but
    the ones that are really quick
    are the straight cut custom gears.
    Also a lot of the drag guys weld
    the center diff and are using LSD
    or lockers front and rear.
    A quick example of the gearing problem
    is how quick you have to shift out of
    1st after launching out the hole. Also
    for people that are up there in numbers
    they end up having to shift into 5th gear
    right before the traps which shave a few
    10th’s or more off your times.
    On factory drivetrain you will blow diffs,
    snap axles & cv’s, chip 1st & 2nd gear,
    lose synchros, and much more before
    having to worry about any of that though.
    Nov 14 2013
    @Mocke I thought philips car
    went high 9’s already. That
    10.1 pass was awhile ago and
    seems rather low for 1200-1300
    CHP?
    Sep 01 2013
    Sweden
    He did 10.1 officialy and 9.9 unofficially with old tte950 setup.
    Haven’t seen any 1/4 times with latest 12-1300setup besides 341khp/ 1/2 mile.
    Seen they are aiming at 14-1500 with new sleeved block now.
    Sep 01 2013
    Sweden
    @VR6Bomber There is nothing else here but proper manual in all 3 cars i own. Wouldent have it other way.
    But! Manual shifter is a Slowdown compared to DSGs and getting fast 1/4.
    Mar 22 2013
    AK
    The LImo was never a 1/4 build, ever, those runs were for fun but the entire set up was always geared , literally, (has straight cut gears) for Vmax or high end acceleration .
    The current build goal is to reach 400km/h plus......that is 249 miles per hour.
    Nov 14 2013
    I’d love to see a b5 going 250mph.
    It’d be cool to see him going up
    against Jeff Garners urs4. I hope
    Philip goes to Santa Poda too. I’d
    like to see him shatter some v6 twin
    turbo records.
    @vr6bomber Ha I feel the same. The
    guys over on MG would never consider
    driving a DSG or doing a DSG swap lol.
    I’m only considering a b8.5 or b9 s4
    in DSG as my daily. Maybe I’m getting
    old that I don’t want to sit in rush hour
    and row gears.
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    Quote Originally Posted by VR6Bomber View Post
    /Get off my lawn!
    agreed. I'm same with launch control though. At some point you're just a passenger on an engineering exercise. You listen to the hardcore drag guys and it's about tweaking the software, not anything he did wrong. bleh. CVT this thing at 7 grand, press the launch button... and this is a sport?
    I'm not sure I understand the swap/lightweight rules either, versus transmission is somehow different. It all seems arbitrary. Imho you've violated it being a b5 s4 the second you changed anything, including the k03. From there it's just arbitrary, and without some desire to level competition, or set some speed/price ratio that might be relevant to a consumer, I don't understand why anyone would care.
    i mean a top fuel car has no radiator, no transmission, and a multiplate clutch system controls power delivery, and the clutches tend to fuse themselves together after a run. It's absurdity, and wholly uninteresting once you've figured out how to engineer it. Bringing this crap to our platform? bleh. why bother.
    Speed per dollar. Speed per practicality. And what I view as king: Smiles per dollar. And yeah it's slightly cool to see a b5 shell haul, but imho, speed isn't king. Someone gets a k03 car running 11s is kinda cool, arguably cooler than cvt 9 second turd nobody wants for any other reason than a drag run.
    How these things should be discussed:
    https://www.audizine.com/forum/showt...b-4sec-0-to-60
    (and yes they're wrong about the '60 or 0-60 if he's thinking of the same video, the OP was right about ~4 sec 0-60 -- it was a budget build on slicks if it's the same basic setup I've seen come accross the platform once or twice. Drag times are significantly dictated by your '60 foot on low hp / high grip cars, almost entirely in fact absent some atmospheric/software/shifting anomaly. Driving the wheels off a k03 at ~12 sec from the videos I've seen in the past, for the same price as the turbo swap. Not a 1/4 mi guy in particular ($ and arbitrary), but impressive stuff, and looks fun.
    You want a monster? well don't even buy an s4 shell, but if you do, don't use any of it. can be done pretty cheap.
    Mar 25 2018
    Portland, OR
    Quote Originally Posted by james 408 View Post
    (and yes they're wrong about the '60 or 0-60 if he's thinking of the same video, the OP was right about ~4 sec 0-60 -- it was a budget build on slicks if it's the same basic setup I've seen come accross the platform once or twice. Drag times are significantly dictated by your '60 foot on low hp / high grip cars, almost entirely in fact absent some atmospheric/software/shifting anomaly. Driving the wheels off a k03 at ~12 sec from the videos I've seen in the past, for the same price as the turbo swap. Not a 1/4 mi guy in particular, but impressive stuff, and looks fun.
    I agree it’s arbitrary... unless there is a sanctioning body that’s establishing the rules. I have to disagree that top fuel dragsters are “crap”... building the fastest thing on earth is not a small feat and the level of engineering and development that goes into them is very high. Not to mention the skill to drive them repeatedly without taking flight and cratering.
    Nov 04 2013
    Palo Alto, CA
    Agreed, doing 4 seconds would be fun even as a passenger. But it scales as you go through the NHRA ranks. Shape, do I press a button to shift, do I have to moderate anything at all? I'm saying a 9 second cvt with an s4 shell and auto launch is a turd. Maybe at full weight that's impressive as an engineering feat, but... what are you doing, and why.
    Not that even that doesn't make sense if you want to beat/surprise street cars consistantly, maybe that's fun (it is, it just gets old). Just saying you gotta determine what you're trying to do before you determine what you're trying to build/compare. Budget? Skill? Street legal everywhere? Faster than ___? Made by who? all valid/arbitrary points people made well before I did. And if you want some degree of vanity, you need to tick off the popular ones. At least enough for somebody to rightly say: you don't like the hannover limo, usp (10 years ago?) or the alm brothers are dope? What an idiot.
    Nov 14 2013
    The sad truth is that when you’re
    trying to be the fastest the only way
    to achieve certain goals is by going
    Auto. If it’s strictly a sanctioned drag
    car I wouldn’t care but if it’s something
    I will drive on the street and at the track
    for me it has to be manual.
    The fastest 6 speed Supra runs like an
    8.5 in the 1/4 and that’s with a robotic
    skilled driver. All the TH400 and power
    glide Supras are all in the 7’s and lower.
    I’m pretty sure the Puerto Rican’s with the
    2jz corolla drag car are in the 5’s. I forgot
    if they’re el Freddie or del otro I forgot
    their names.
    I’m more for trying to push the limits of
    a 6 speed rather than going Auto any day.
    It just sucks all the manufacturers are phasing
    them out.
    James what vanity? Are you saying you don’t
    like people who push the envelope with these
    cars? If you don’t approve of it then we have
    to agree with? We’re losers for admiring these
    cars?
    May 13 2009
    XXXX
    This might be a whole other can of worms, however.
    Technology is great right?,
    It saves lives and can accomplish the menial tasks and allows us the time to do more important things and so forth...
    Does a DSG 'enhance' the driving experience because its performance is 'faster', or is it contributing to the loss of 'essential' skills?
    Can you truly have a motorsportman who doesn't even need to know how to drive a manual?
    Lets send a self-driving tesla down the track and just cut out the human and shifting 'problems' altogether..!
    Nov 04 2013
    Palo Alto, CA
    James what vanity?
    No I just recognize we're all vain to a degree, myself included.
    So just like part of the appeal of an audi is its reputation/respect from others, so too would that influence my build choices. And aligning with others' tastes is something one should consider under than umbrella.
    It's all part of my philosophical math as to what arbitrary rules a fast b5 needs to adhere to... if others don't agree well then consensus is you've failed at the task :)
    For me, and apparently vr6, maintaining driver input is paramount, for others it's the amount of original components (some more than others). So either you've got to be the fastest outright by strapping an audi badge onto a drag car, or you've got to play a bit of arbitrary to carve your niche fastest.
    I think the reality is, if you take an s4 shell, and crack into the 7's, I don't care what's powering it or what it weighs, I might take a pot shot at you, but at the end of the day I'm going to have to shutup and admit that's pretty cool, and if someone wants to argue it's no longer a b5 let em, but it'll pass the duck test (looks like a duck, sounds like a duck, it's a duck). Same thing if you take a ko3 car into the 10s.
    Nov 14 2013
    Me personally I wish technology
    froze in the early 2,000’s. This shit
    I see people use nowadays is completely
    unnecessary IMO. I don’t need Alexa,
    FaceTime, self driving cars, refrigerators
    with screens, garbage cans that talk to
    me. The new generation can save all of that.
    Sep 01 2013
    Sweden
    As it has become nowadays with all RS3s MQBs, TTRs etc... doing some crazy times, i think the grandfathers of 1/4 would turn in their graves.
    Its not a driver skill any longer, sadly.
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Haha this is how I feel. Every new appliance we bring home wants to connect to our wifi. Like, wtf? You're a refrigerator... Just keep my beer cold.
    Nov 14 2013
    Seriously all I need my fridge
    to do is store my food and beer.
    I don’t need to see through the
    door, write a grocery list on a screen,
    surf the web or watch tv on the
    door.
    What ever happened to just going
    to the store and using a list or
    remembering what you need. The
    appliances and cars for that matter
    do everything except give you a blowjob.
    Veteran Member Three Rings xFvse's Avatar
    Sep 08 2016
    Wuhan
    their names.
    them out.
    cars?
    Dsg swap the bitch
    Nov 14 2013
    ^^Always a possibility.
    How deep are your pockets
    and or skill set. Wasted
    time IMO. You could probably
    make a custom adapter for
    a TH400 or another good
    domestic tranny for less
    headaches, time, and money.
    If you’re interested hit up Aaron
    aka speeding G60 on here. He’s
    putting in a domestic auto into
    his 2.0t coupe quattro drag car.
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Also
    10th’s or more
    This is true. I'm bouncing off the limiter across the line in 4th gear. I could shift and attain a higher mph, but would then be much further from that 10 second number.
    Kind of puts me in a wierd spot. More power then is going to make the quest harder to attain unless I added a lot more power to make that final shift worthwhile.
