Results 1 to 7 of 7
    Jan 03 2019
    RS3 jack/lift points
    I saw many online videos about installing jack pads for Golf MK7. Does the RS3 already have dedicated lifting points (besides the pinch welds)? If not, will this MK7 kit fit the RS3?
    Thanks
    Established Member Two Rings RS-AudiSport's Avatar
    Aug 16 2018
    Lakewood, CO
    Quote Originally Posted by mbar View Post
    Thanks
    Yes, the rear has jack pads for you. The front does not, but you can follow the arrow on the side skirt up front (about 12" from the end side skirt close to front wheel) and go right behind the pinch welds, should be fine to jack from there. See attached pics
    InkedRS4_underbody_LI.jpg20190303_125157.jpgInked20190303_131622_LI.jpgInked20190303_131600 (1)_LI.jpg20190303_125209.jpg
    EDIT: Sorry my undercarriage pics came out upside down lol, but you get the idea
    Mar 09 2018
    2018 RS3
    front does have jack pads but further in...
    https://www.audizine.com/forum/showt...1#post10870663
    Florett RS3+DS1+034TCU
    Veteran Member Three Rings jd_rs3's Avatar
    Dec 18 2018
    Longmont, CO
    Anything wrong with using the pinch welds on a 2 post lift? Is that not preferred?
    2018 nardo gray rs3 - sold
    Aug 16 2018
    Lakewood, CO
    Quote Originally Posted by tegxsi View Post
    Interesting...never noticed them, thanks for sharing!
    Quote Originally Posted by jd_rs3 View Post
    Idk....in a pinch (get it? punny ) you probably can, but I doubt it's "good" for the welds in the long run to use it as your official jackpoint. Most cars I've owned, if I couldn't find a jackpoint I did it under the pinch welds but, once I had a bad experience where the sideskirt started buckling and folding in on itself. So now i'm paranoid and make sure I find official points to jack it on (apparently though I missed it on the front of my RS3, yikesss)
    Feb 16 2004
    Bay Area
    The jack puck on the chassis is stronger and will not bend overtime unlike the pinch welds. It should be easier to lift the car using the jack points vs the pinch welds. You'll have more working room and will not need the car to be dead center of the posts.
    Unbeknowst to Speed, Racer-X is actually his older brother who ran away from home years ago...
    Jul 13 2018
    Winnipeg, MB, Canada
    The jacking rail that the the arrows on the side skirts point to (for the front and back) is pretty robust. Not your typical pinch weld, its seems reinforced.
    I didn't see the jack pads, that's a nice addition. Audi seems a little better than other manufacturers in providing solutions and identification of locations. My Fords only give the standard emergency scissor jack locations as lifting points.
    2018 Audi RS3 - Ara Blue, Black Optics
    2019 Audi SQ5 - Manhattan Grey, Black Optics
