Results 1 to 14 of 14
    Mar 19 2018
    Central Ohio
    Sirius Linking problem
    Yesterday the radio started having an intermittent signal, which causes the dash display to show "Linking" instead of the station name. When this happens the sound cuts out, then after maybe 10 seconds it will connect and music will play, then it cuts out again.
    I did the 3 button reset to no avail.
    I read it might either be a lose antenna connection to the XM unit, or maybe a bad antenna, which might need to be replaced by the dealer.
    So before I go to the dealer, where is the xm unit in a 2016 B8.5 S5?
    2016 S5 Brilliant Black | Black Optics | Alu-optic | Tint | Black 19" rotors | Black emblems | CR15
    Sep 21 2017
    Merrick NY
    Quote Originally Posted by galaxis View Post
    This sounds like a dealer issue, I have the same problem as have many others.
    Replacing the SiriusXM module is pricy but seems to be the culprit in most of these cases.
    Occasionally replacing the antenna also does the job.
    Short of buying an aftermarket module I’ll be looking at another head unit.
    Senior Member Two Rings PDXFlyGuy's Avatar
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    I had the same issue. The dealer said they were 95% sure the antenna was the issue however to find out for sure they’d had to remove the headliner to get to the antenna. That would cost $1000 plus $600 for a new antenna! I said no thanks and cancelled my XM.
    2018 Glacier S5 SB
    Sep 21 2017
    Merrick NY
    You could also get the app on your phone and use the app through Bluetooth.
    Mar 19 2018
    Central Ohio
    Quote Originally Posted by PDXFlyGuy View Post
    $600 for an antenna? Holy shit.
    Sep 21 2017
    Merrick NY
    So many people have had this same LINKING issue.
    I’m looking at an Alpine unit which is supposedly compatible although it has to be shipped from Italy.
    Mar 19 2018
    Central Ohio
    Quote Originally Posted by Surfer8210 View Post
    Good luck!
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    Yes! When the service manager gave me that quote it was an instant “no thanks!”
    2018 Glacier S5 SB
    Mar 19 2018
    Central Ohio
    I bet!
    Well, I managed to find the XM unit in the trunk, unplugged the green antenna wire, wiggled it, blew on it, you know, the highly scientific, technical fix, then plugged it back in. I sat in the driveway with the stereo on for a few minutes and it stopped doing the linking thing. I guess we'll see how it goes for the next few days. Hopefully I don't have to save up for a new antenna :)
    Nov 24 2016
    2016 Cadillac CT6
    Portland, Oregon
    I bet!
    Good luck! I cancelled my XM and found a good radio station. Figured I could put the money towards something else.
    2018 Glacier S5 SB
    Mar 19 2018
    Central Ohio
    *fingers crossed*
    Sep 21 2017
    Merrick NY
    I bet!
    I’ve heard of that approach working for others also. I’m going to attempt the same thing.
    Glad that it worked for you though.
    Veteran Member Three Rings spense5's Avatar
    May 10 2018
    I'm late, but my initial reply was going to be "how sirius is it?"
    Mar 19 2018
    Central Ohio
    Quote Originally Posted by spense5 View Post
    Don't expect this from a luxury auto, so yeah, it's sirius
