Results 1 to 8 of 8
    Veteran Member Four Rings MK2SQ's Avatar
    Aug 11 2018
    Motor Oil recommendation for B9 SQ5 and 2019 Jetta VW
    With Audi care going to end this year for me and want to perform my own oil changes on the SQ and wife's 2019 Jetta SEL Premium (could be soon replaced with the RSQ3 or the Q7) regardless, I'm looking for a 5W30 motor oil that would be the best option for both.
    I heard a lot of people are using the Liquid Moly oils? is this the best option for the SQ? also looks like Mobile 1 is the best overall rated oil. when VW recommends Castor Oils i want to get the best oil i can for it and use the same on the Jetta for convince.
    What do you all use and recommend?
    Prestige B9 SQ5 / Moonlight Blue / S sport / DAP / Dynamic Steering
    JB4 Tuner / ROC-Euro Intake / Lowering Links / 034 Trans Insert / V-FF 109
    / Brembo GT 380mm / AWE Exhaust /
    Build Thread | Instagram @_kademan_v60cc_ | YouTube @MK2 SQ
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Use what Audi and VW recommend
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Aug 11 2018
    Quote Originally Posted by 2018_SQ5 View Post
    so it would be the Castor edge
    https://applications.castrol.com/oil...60-kw)-(2013-)
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    LiquiMoly, Castor, and Mobile 1 are all fine, full-synthetic lubricants. Use whichever of these is most convenient for you to obtain.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Castrol is the factory fill and oil used at all VW/Audi dealers during service appointments. When Audi Care ended I used Mobil 1 Euro . Recently I changed over to Shell Rotella.
    What is your favorite beer?
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Aug 11 2018
    Quote Originally Posted by q5 dave View Post
    true, i used to use only Mobile 1 when owning GM products, i will probably just go with castrol if its not difficult to get
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Mobil 1 Euro formula (my choice) is approved by Audi/VW. Castrol Edge is also. Both are full synthetic.
    Shell Rotella T-6 (full synthetic) is technically a diesel oil for direct injection turbo diesel engines. However, it has a huge following in high performance modified turbo auto applications. The Subie and Mazdaspeed guys love it. Worked great in my Mazdaspeed 3 for ten years. Don't know if any high output Audi turbo cars are running it, though.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    I usually buy the oil change kits off of ECS or FCPEuro since they include the oil/filter/new drain plug & washer for a great price. Only have used LiquiMoly in my prev. A4 and will be doing the same on the Q5. Never burned any oil or had any issues with LiquiMoly and Mann filters.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
