Results 1 to 40 of 59
    Veteran Member Four Rings elijahallen's Avatar
    Nov 12 2006
    Michigan
    SQ5 does it all, build thread
    Hey guys, I should have started this a long time ago. I’m a long time Audi enthusiast and have always had one fun Audi (URS4/6’s, B5 S4’s, AAN converted coupe Quattro, B8 S4, etc.) and another car that a use for work (Allroads, Cayenne S, Q5 tdi, etc.). This year I decided to do something different and sell my TDI and my B8 S4 and take the money and buy and mod a 2016 Audi sq5. I picked one up with 32k on it, waited till the 35k mile service and then went dual pulley with supporting mods. To my surprise the car has been very fun and I use it to haul family, pull my work trailer when needed, and this spring plan to road course it. Here are some pictures of past cars and some of current. I will be updating as I add things and also add videos of some of my experiences with this car.
    The SQ5 the day I bought it.
    The mod bug began with an apr dual pulley 187/57 and an apr cold front. and auto tech HPFP IMG_1382.jpg
    Next came 75mm TB and ported blower.
    And a set of test pipes
    Tuning was done by giac and is still in progress to get the most of what I have. Here is a video of before and after dual pulley pulls.
    https://m.youtube.com/watch?v=5BPcKnZYos8
    Here is a video of before and after test pipes with otherwise stock exhaust.
    https://m.youtube.com/watch?v=ARHdhceHhbY
    More to come :)
    2014 Porsche 911 turbo S, 2022 RS3 Uni DP, mid pipes, Racingline Piggyback(SOLD), 2018 RS3 Uni Stage 3 Iroz built motor(SOLD), 2017 Q7 APR stage 2 DP, 2016 Audi Q5 TDI Malone stage 2, 2013 Q5 3.0t DP stage 2(sold), 2016 SQ5 DP stage2 (SOLD) ,2014 Q5 tdi Stage 2(SOLD),2008 Porsche Cayenne S stock(SOLD),2011 B8 S4 DP stage 2+(SOLD),2001 B5 RS4 clone Built motor 600hp(SOLD),3 B5 S4 Avants Stage 3+(SOLD),95 S6 Avant RS2+(SOLD),94 S4 K27 built motor(SOLD),91 Coupe AAN RS2 Conv. Built motor.
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    This is a great, high quality build. Excited to see what unfolds.
    Sent from my
    '18 S5 - BBS / EPL
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    My SQ5 does it all, build thread
    Are you running the factory exhaust with test pipes? The only reason I ask is that I have heard a Milltek with test pipes and it is much louder than that...unbearably loud...almost.
    Regardless, fun times for sure.
    Nov 12 2006
    Michigan
    Quote Originally Posted by bajan01 View Post
    Yea this is my daily driver so I need it quiet. The factory exhaust flows very well so there is very little gain in going cat back other than sound.
    Nov 12 2006
    Michigan
    Quote Originally Posted by JD S4 View Post
    Sent from my
    Thanks JD, it’s gonna be fun!
    Veteran Member Three Rings rusq5's Avatar
    Mar 26 2015
    SF Bay Area
    Glad you finally made a build thread!
    Excited to see the cars progress and how the track events go this spring/summer.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Nov 12 2006
    Michigan
    Speaking of track, here is the wheel tire setup. I can’t find r-compounds in this size but we’ll see how it does with these.
    Senior Member Two Rings ellwood's Avatar
    Feb 12 2015
    16 SQ5, 21 M340i
    PA
    awesome build man, looking forward to the pics with those wheels mounted up did you do the HPFP as a precautionary upgrade or were you seeing a lack of fueling in the logs?
    2021 M340i xDrive, 2016 Sepang SQ5, (sold) 2012 Glacier White S4 6MT - APR Stage II
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    The comparison pull video is showing that even after the tune and test pipes the upshifts are at stock 6,400 rpm. Have you raised that in your ZF8 TCU tune? If so, did that help with acceleration times?
    I assume the illuminated CEL light on the dash is because of the test pipes. Can that be coded out with VCDS or otherwise eliminated. I'm in a state with no emission testing, so I'm considering the test pipe route and higher pulley ratio after I first upgrade cooling when my warranty expires.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Jan 11 2018
    Florida
    Quote Originally Posted by MSq5 View Post
    I assume the illuminated CEL light on the dash is because of the test pipes...
    Oxygen sensor spacers should take care of that.
    Nov 12 2006
    Michigan
    Quote Originally Posted by ellwood View Post
    Yea I did the Autotech HPFP at the same time as the dual pulley, I will update that info, thanks
    Nov 12 2006
    Michigan
    Yea I had not done the TCU tune yet at that point. It is faster with snow tires than it was with summer tires after the TCU tune but I also ported the blower and added test pipes at the same time. Looking forward to doing pulls with the 295's mounted to see where it's at.
    Veteran Member Four Rings Rocs's Avatar
    May 25 2009
    Audis
    Conshohocken, PA
    Those test pipes on the stock exhaust after you launched it sounded so nastyyyyyyyy. I wanna keep my sq5 stock for a little while if I can but I really want to just get a set of test pipes now.
    2016 SQ5
    2012 A4 6mt
    2004 A4 Ultrasport
    Nov 12 2006
    Michigan
    BTW, that is traction control light not CEL, that video was before test pipes.
    May 23 2018
    Vancouver
    Car sounds great. How much effort to get those test pipes in?
    Jan 11 2018
    Florida
    Quote Originally Posted by Moalm View Post
    A billion efforts...find a shop to do it for you.
    May 31 2016
    Mexico
    Quote Originally Posted by elijahallen View Post
    Since you installed test pipes, are you smelling gas inside the cabin?
    I had test pipes on my old G35 and had the smell of gas in the cabin
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Nov 12 2006
    Michigan
    It depends on the shop, my shop was able to get the job done in 3 hours. They had a special tool for the hidden bolt that gives people trouble.
    Nov 12 2006
    Michigan
    Quote Originally Posted by Q5OnTheMove View Post
    No smell in cabin, it does smell more outside though. I plan to do HFC's at some point but didn't want to ruin my stock cats so threw these in for now.
    Veteran Member Four Rings 1RAudiSQ5's Avatar
    Mar 08 2007
    Ashburn Va
    Where did you source the 75mm throttle body?
    2019 Audi SQ5 Premium +: CETE module // Vorsteiner VFF-107 22x10.5 // AWE Cold Front // CTS Intake // CTS Turbo Inlet // 034 Trans Insert // AWE Touring Exhaust // 034 Swaybars
    2021 Audi SQ7 Prestige : 034 Lowering Links //
    AKA WantaA4
    Nov 12 2006
    Michigan
    Quote Originally Posted by WantaA4 View Post
    https://www.euromodsperformance.com/...e-body-upgrade
    Feb 14 2017
    Gulfport, MS
    Thanks for the clarification. That's good to know. Do the test pipes throw a code, and are you able to code it out?
    Nov 12 2006
    Michigan
    I am hoping I can have it coded out with a custom tune but I’m not having much luck with giac right now so looking into other tuners. I added offsets to the 02 sensors and those keep it from throwing any codes.
    Feb 14 2017
    Gulfport, MS
    Are those the right angle shaped extenders?
    Nov 12 2006
    Michigan
    I just used straight extenders with gas flow restictor that came in different sizes. The middle size seems to be the one that works best. Here is a link. https://www.jegs.com/i/Vibrant-Perfo...BoCfGgQAvD_BwE
    Mar 26 2015
    SF Bay Area
    Maybe I missed it, but are you running stock suspension?
    What alignment specs do you plan on running? I went on a drive this weekend and am thinking about putting a few degrees more camber in the front to help with turn in. The x-brace really helps with under steer, but I'm thinking I can still make some improvements with a good alignment.
    Also, FWIW, after 20-ish miles of really tight roads I was getting fade in the brakes.
    -Rusty
    IG: @grn_rs6
    Nov 12 2006
    Michigan
    Quote Originally Posted by rusq5 View Post
    I haven’t decided on suspension yet. Maybe just euro springs. I really want to keep it stick feeling for daily driving. I have an 034 RSB to mount and will probably do the X brace as well. The brake fade you had is just the pads you are running. With a higher temp pad they should be fine on the road no matter how hard you push them, track I’m not sure yet but I have dedicated track pads to test the envelope.
    Mar 26 2015
    SF Bay Area
    I've got EBC redstuff on the fronts, which did a lot better than the OEM pads, but still had some fade. Dedicated track pads sounds like a good idea.
    -Rusty
    IG: @grn_rs6
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Just throwing this out there, I’m getting new springs/shock put on today, so my Euro/ROW kit will likely go up for sale in the next week or so. 15,000ish miles and will probably sell for roughly half of retail.
    Nov 12 2006
    Michigan
    Quote Originally Posted by buggravy View Post
    PM'd you
    Nov 12 2006
    Michigan
    The Reds are for street only, the yellow would be a better choice for spirited driving :-)
    Mar 26 2015
    SF Bay Area
    But...I was on the street! haha
    I will also have a set of KW HAS for sale soon too, if you're interested in going that route.
    -Rusty
    IG: @grn_rs6
    Nov 12 2006
    Michigan
    PM'd
    Feb 14 2017
    Gulfport, MS
    Thank you, sir!
    Nov 12 2006
    Michigan
    Porterfield racing brake pads got here today. We’ll see how stock brakes hold up at the track with proper pads.
    Jan 15 2018
    Ford Raptor
    Rochester/WA/PNW
    How are the test pipes with just normal driving? Any cab drone?
    Jan 11 2018
    Florida
    Quote Originally Posted by AKIN187 View Post
    Lots...I drive around in D just to minimize the annoyance.
    May 07 2016
    Take a look at the thread by Evil35r in S4 forum. He’s reduced rasp and drone by using header wrap. Might be worth a try
    Sent from my
    '18 S5 - BBS / EPL
    Nov 12 2006
    Michigan
    You can't even tell they are there in normal driving if you keep the rest of the exhaust stock. Literally no change until you start to boost then they are louder but not bad.
    Jan 11 2018
    Florida
    Perhaps. That won’t change the decibel level at WOT throttle though.
