Pardon, I attempted to move this thread to the correct place but find I cannot.
Thanks in advance for any light that can be shed on the subject.
This occurs daily, especially when below 10 degrees (C) or colder, when attempting to start the vehicle first time.
The routine is: Remote key pressed in or in vehicle, dash lights come on, static battery voltage 12.6 (AGM battery of appropriate capacity, less than 6 months old, charges @ above 14V), foot on brake pedal, press start button to crank, dash lights go out, engine does not crank, CEL appears, and then at least 20 other codes appear, battery voltage does not drop below 12V.
So I scan codes, and always see a communication error between ECM/PCM "A" along with plenty of other codes (see list below). I clear the codes using the Carista app and Bluetooth dongle in the OBD port, often have to clear the codes two or three times, car then starts immediately with a strong cranking effort indicative of a good battery, idles smoothly during warm up, tho' sometimes the CEL stays on and often cruise control does not work until I do one more engine off clearing of codes. Car runs beautifully for the rest of the day, starts without fail, mileage is as expected, engine does not skip, CEL does not reappear until next day's start up routine. I do not have a VAG Com.
Subject: Audi A4 B8 2 Litre Turbo TSFI Quattro 8sp ZF Sedan, prod date 1/2012
Date: Thursday, 21 February 2019 07:13
OBD2 - confirmed:
U0100 - Lost Communication With ECM/PCM "A"
OBD2 - pending:
OBD2 - permanent:
CAN network gateway:
01314 - Engine Control Module (ECM)
Ignition authorization:
01330 - Central Control Module for Central Convenience (J393)
Central electronics:
Body/convenience system:
Heater & air conditioning:
03220 - Stop Valve for Coolant for Climatronic (N422)
Instrument cluster:
Parking brake:
ABS:
00473 - Control Module for Electric Park- / Hand Brake (J540)
01315 - Transmission Control Module (TCM)
Transmission:
12551
12554
12562
Headlight aiming:
336388
Radio:
