Yes, 2 ECU connectors, long and short one. That part is clear.
Not sure where the "E box" is. Might be the box with the multiple colored connectors (red, white, brown, black, beige, etc depending on car). This one has white, red, brown and ground bolt.
Could be this is the T17d (17 pin, red) and the T17j (17 pin, brown).
Found total of 4 broken (well, chewed through) wires. on was blue, the other 3 were yellow/green.
One green/yellow connects to the red plug, pin 1.
The blue goes to the white plug, pin 11.
Need to trace the other 2 yellow/green ones.
Is there a pin out for the 3 plugs to determine where they connect to the ECU?
Or an ECU pin out that shows the wires to the 3 plugs?
4 broken wires:
https://drive.google.com/open?id=1Q2...sFO-y5SfabV7Ol
3 ECU box 17 pin connectors red, white, brown ("E box in plenum chamber"??):
https://drive.google.com/open?id=1V2...6boWP-iDYiBiAy
Blue wire on white connector, pin 11?:
https://drive.google.com/open?id=1Hm...BDS4ad0UH-GsZr
Yellow/Green wire on red connector, pin 1?
https://drive.google.com/open?id=1zy...8r3C5Bz1iRdghS
https://drive.google.com/open?id=1KM...deaBXDNalhCJLp
