Thanks Gunnark100, below is the most recent scan:
Thursday,21,February,2019,20:13:54:00007
VCDS --
VCDS Version: 18.9.
Data version: 20180927 DS296.0
VIN: WAUVF68K49A145821 License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 36 42 46 47 52 53 55 56 62
6D 72 77
VIN: WAUVF68K49A145821 Mileage: 138540km-86084miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0001
Revision: E1H14---
Coding: 010C010A190F0160
Shop #: WSC 25732 001 1048576
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F95BE5F8D9558292-802C
3 Faults Found:
4054 - Cylinder 1
P0301 00 [175] - Misfire Detected
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 138543 km
Date: 2019.02.21
Time: 20:04:17
Engine speed: 1206.00 /min
Normed load value: 20.8 %
Vehicle speed: 0 km/h
Coolant temperature: 24 °C
Intake air temperature: 13 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 12.439 V
Unlearning counter according OBD: 40
4063 - Cylinder 4
P0304 00 [175] - Misfire Detected
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 138543 km
Date: 2019.02.21
Time: 20:04:17
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [175] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 138543 km
Date: 2019.02.21
Time: 20:04:15
Engine speed: 1195.50 /min
Normed load value: 21.6 %
Intake air temperature: 14 °C
Voltage terminal 30: 12.156 V
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 C HW: 0B6 927 156
Component: 0B6 20TFSIUSA H04 0050
Revision: --H04---
Coding: 001002
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 366390D989477AFA3F-8062
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Revision: -------- Serial number: --------------
Coding: 150500
VCID: 79F95BE5F0D9558292-802C
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H06 0435
Revision: 00002001
Coding: 090200
Shop #: WSC 49615 000 1048576
VCID: 0305390D82151F52C8-8056
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000053940002
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Serial number: 0208000070124006
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0140
Revision: C1000000 Serial number: 0129.09.081408
Coding: 64002000
VCID: 72EB6CC9ADAF26DAD3-8026
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000132458
Coding: 26001097473CAF010000080300003D0D0F1C47080001014100 0000
VCID: 306FA6C1632354CA65-8064
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 021008 H06 0070
Serial number: SWF08100026194
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10275432
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000003009080691
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 F HW: 8K0 959 655 F
Component: AirbagVW-AU10 H27 0410
Serial number: 0039KD149BP9
Coding: 30453635423030303030554A304C384B3053
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 408FF601DB83C44A95-8014
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4035046B6
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME421615586
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME140C25269
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME63075338D
Crash sensor for front airbag: driver side:
Serial number: 63732SME7C0A3E1AD
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME210C1602O
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HIU0009F
Coding: 000017
VCID: 3D718FF5A471A9A2FE-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 HW: 8K0 920 900
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DL1CEX98
Coding: 8307110002000008020000
VCID: 67DD0D9D966DD37274-8032
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G089078185
Coding: 000303
VCID: 4683E019F1A7EA7AAF-8012
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18045FA4140908
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020302
VCID: 78FF5EE1CBD34C8AED-802C
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001156914
Coding: 00581300000000000000
Shop #: WSC 15216 002 1048576
VCID: 77FD5DDDC6CD43F2E4-8022
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007773422
Coding: 011C03204E00410001
VCID: 3F8DF5FDAE7DBBB2EC-806A
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0300122525
Coding: 0126063A207A341400B0020000000000
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 2 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS222 H06 0037
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6ED378B9B997023A37-803A
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007776071
Coding: 011C03205E00410001
VCID: 3E7388F9A977B2BAE7-806A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 10000000108098
Shop #: WSC 00000 000 00000
VCID: 3169A3C568295DC26A-8064
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: 3467AAD1573B68EA01-8060
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 L HW: 8T1 035 195 L
Component: Symph3 Sirius H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1052113
Coding: 240200020102870303D9070800
VCID: 408FF601D383C44A95-8014
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
2 Faults Found:
02633 - Antenna for Satellite Tuner
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 236
Mileage: 136720 km
Time Indication: 0
Date: 2019.02.08
Time: 22:19:35
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 236
Mileage: 136720 km
Time Indication: 0
Date: 2019.02.08
Time: 22:19:35
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 HW: 8K0 959 795
Component: TSG HL H06 0170
Revision: Serial number: 0000007799973
Coding: 010C03204000210001
VCID: 7F0DB5FDEEFD7BB2AC-802A
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H27 0240
Revision: -------- Serial number: 8K9827851
VCID: 7BF541EDFAE5679280-802E
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H27 0240
Serial number: 8K9827852
1 Fault Found:
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 218
Mileage: 136421 km
Time Indication: 0
Date: 2019.02.02
Time: 19:05:56
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 HW: 8K0 959 795
Component: TSG HR H06 0170
Revision: Serial number: 0000007785288
VCID: 7EF348F9E9F772BAA7-802A
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 C HW: 8T0 862 336 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005020774
Coding: 0010370
VCID: 3B7581ED7A65A792C0-806E
End-------------------------(Elapsed Time: 03:37)--------------------------
