Results 1 to 7 of 7
    Oct 21 2018
    3.0 TDI Audi Warranty?
    Hi all. After some misconstrued information from both dealers and private sellers alike, I figured the forum would be able to answer the following question with the most accuracy.
    Do 3.0 TDIs have an extended engine/powertrain warranty due to the dieselgate alterations? If so, what is covered and how long is this coverage good for?
    And while were here...is there anything to watch out for on these 3.0 diesels?
    Feb 19 2007
    I would love the same info- looking at a 2014 diesel A6
    May 20 2010
    There is an extended engine/powertrain warranty. What said warranty depends on the status of the vehicle at the time. IIRC, it's 10 years/120,000 total miles or 4 years/48,000 miles from the (not sure if it's from the scandal date like VW or the fix date). Covers the entire long block, heads, turbo & charge system, transmission & drivetrain, and entire exhaust system from the turbo to the tailpipe, and any emissions-related components.
    This is just my experience. My 2016 has the 10 year/120k mile warranty that goes back to the in-service date (September 2015 for me, so up to September 2025 or 120,000 miles, whichever happens first). I'll hit 120k way before 10 years, but it's there which is nice. As long as it's not modified/tuned, you should be good. 115k miles is the schedule DPF inspection/replacement, so that might be a nice freebie. The Settlement also entitles you to free Adblue.
    While I never had mine before the fix was implemented, from what I've read it's a bit louder and gets worse mpg than pre-fix. I've read a tune can restore pre-fix driving but have not done so on mine.
    I don't think there is any "gotchas" for failing components that I've seen. Aside from that, here are a few things I've noticed:
    1. It's hard for me to find good quality diesel (higher lubricity cetane). 40 cetane rating is the minimum legally required and some places have significantly higher (55+ cetane rating). I have an additive for winter but it's not the same. Winter diesel sucks. Results are worse fuel economy, what feels like worse power, and it sounds more like a diesel (i.e., louder)
    2. Can be a bit sluggish off the line at times. May be fuel-related but sometimes takes some effort to move. The 1-2 gear change be jerky if you lift your foot up right before/after the change.
    3. In cold weather I feel it takes a while to warm up. Example: In freezing weather, when I leave my work, I usually get in the car and start driving (keeping revs low). By the time I'm ready to turn onto the highway, my C5 is blasting hot air, coolant gauge straight up at the middle. The C7 might have 2 dashes--3 if I'm lucky. So not nearly as warmed up. Also, immediately driving you can feel it lug a couple minutes until it's gotten a bit warmer.
    4. 8-speed transmission always tries to be the highest gear it can even if you don't want it to be, so you may be hunting at certain speeds. In S, it is usually one gear down from D, which helps a lot. I find myself using the paddles a lot, plus the 8-speed shifts quite fast compared to the older 6HP transmissions (no DSG tho).
    5. MSRP on Audi Care Select for the TDIs is $1249--$400 higher than an S6 or S7!
    6. Love the diesel torque! Wish it had more rev range, but it's ok. And top speed limited to 129 mph :(
    Also, C7 in general:
    1. No track change buttons on steering wheel. Wtf Audi?!
    2. If you try to put on heated steering wheel when it's doing it's initial startup checks, it won't go on until you've gotten through the messages. But if it was previously on, it will automatically be on again.
    3. Gauges don't display enough info (like actual boost psi/bar, coolant temp degrees; oil temp can be observed by lap timer).
    4. Adaptive Cruise Control minimum distance is too long.
    5. VCDS coding for C7.5 is a PITA and you cannot enable the Hidden/Engineering menu b/c Audi mucked with it.
    6. Cupholders are a bit close to the arm rest, so drinks with a lid (e.g., Starbucks, McDonalds, etc) may lose the lid.
    7. MMI can be finicky at times. Sometimes it shows my entire streamed playlist; sometimes it only says "Audio is streaming from your device" or something and only has the one track. Not consistent with that but any solid state media is good.
    8. Love the LED headlights but I feel like they don't illuminate enough down the road. I think Consumer Reports faulted them for that too. I enjoy high beam assist though.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jul 06 2014
    Rhode Island
    As far as everything ive read including the warranty documentation given to each owner, Ive never seen the transmission and drive line being included in the warranty.
    Senior Member Two Rings bthethy's Avatar
    Oct 28 2018
    London
    Is this warranty just in the USA or worldwide?
    A7 3.0tdi 272 Black Edition Mythos Black Tech pack
    Feb 20 2019
    US
    Punch in the VIN at audidiesellookup.com for the official documents. I think the information I've seen was USA only. Term is 10/120k from in-service or 4/48k from the fix date, whichever is longer.
    The extended emissions warranty is not the same as a powertrain warranty. It covers pretty much everything in the emissions treatment and fuel system including the turbo, as well as the ECU/TCU/ODB electronics.
    It also mentions some longblock engine components but that seems to only be in the context of failures caused by the emissions system. Maybe Audi would offer some leeway on that but I would not count on them covering the engine/transmission under this policy.
    Oct 21 2018
    Awesome!! Thank you very much for the info - much appreciated!
    Quote Originally Posted by psiven View Post
    Great info, thanks!!
    Appreciate all the responses. Unfortunately the TDI I was looking at was involved in a pretty good accident that was not disclosed (Carfax stated the bags blew). The search continues...
