Results 1 to 7 of 7
    Active Member Two Rings clarkthashark's Avatar
    Jul 05 2016
    2017 Subaru Outback (Gen 5)
    Charlotte, NC
    SOLD - 2003 Audi A4 Avant 6spd Manual Avant – Atlas Grey – 204259 Miles - $2,300
    For Sale: 2003 Audi A4 Avant 6spd Manual Avant – Atlas Grey – 204259 Miles - $2,300
    Located in Charlotte, NC – Local Pick Preferred – VIN WAUVT68E53A193452
    In March of 2017 I purchased this car not running with a 3.0 motor that had a snapped timing belt. As a project, I replaced the 3.0 with a motor from a donor car and photo documented the entire process.
    The car runs and drives but does have some issues that I’ve detailed below. I planned to continue to modify this car as a weekend project but due to a recent job change I would like to sell this onto another enthusiast.
    Imgur Picture Album
    https://imgur.com/a/LY5BytZ
    This car is fun to drive and would be a great platform for a 2.7TT swap or other build projects.
    Pros:
    - 01E 6 Speed Manual
    - Rebuilt 3.0 AVK motor (All gaskets from OEM Victor Reinz, All coolant O-rings and seals OEM from Audi Northlake)
    - Maintenance History below and in paper recipes from previous owner (back to 160k)
    - Winter Package (Headed front seats, Heated Window screen nozzles, Headlight washers)
    - B5 S4 Front Brakes
    - Working Cruise Control
    Imgur Engine Rebuild Pictures
    https://imgur.com/a/KaNWj
    Cons:
    - Engine using some Coolant. I do not know if it is leaking in the motor (rear main seal) or if it is leaking in the interior heater loop.
    - Uneven idle at start. Currently I believe this potentially a fuel pump issue. May need to be replaced.
    - Interior Headline Sagging (See pictures).
    - Driver seat back cover panel unclipped.
    - Tires low on Tread.
    - Rear Shock need to be Replaced (See Audi Northlake Pre-Purchase inspection notes).
    - Two Front Inner CV Boots Busted
    - Passenger Fog Light Bulb Out (Throwing Code)
    - Driver Side Headlight Auto Level Error (Throwing Code)
    - Windscreen washer tube to nozzles needs to be replaced.
    Previous Ownership History:
    - B5 S4 Brake Swap
    - New Front Steering Rack
    - CV Boot Replacements
    - Power Steering Pump Replacement
    - All paper maintenance history records available
    My Ownership History:
    190k miles
    - Clutchmaster FR-250 Clutch
    - Lightweight Steel Flywheel
    - Metal Clutch Slave with Braided Steel Lines
    - APR Snub Mount
    - 034 Density Line Motor Mounts
    - Engine Air Filter replaced
    - Cabin Filter Replace
    - Intake manifold diverter tube/valve replaced (OEM from Audi Northlake)
    - Roof Bars on stock Avant roof rails added.
    191k miles
    - Rear Hatch Lock Actuator replaced (OEM from Audi Northlake)
    192k miles (Due to Low Oil Pressure Warning)
    - Oil Valve with O-Rings (OEM from Audi Northlake)
    - Piston Oil Sprayer with O-Rings (OEM from Audi Northlake)
    - Valley crank Ventilation Cover Gasket (OEM from Audi Northlake)
    - Oil Pressure Switch (OEM from Audi Northlake)
    - Oil Temp Sensor (OEM from Audi Northlake)
    - Oil Pan Dropped to check for any debris, none found (pictures available) and resealed
    - Ravonal 5w-30 Oil Change with Mann Filter (BlauParts)
    201k miles
    - AC High Pressure Switch (OEM from Audi Northlake)
    202k miles
    - Presale Inspection performed by Audi of Northlake
    202.5k miles
    - Driver side Valve Cover Gasket (OEM Victor Reinz)
    - Passenger Side Cam Shaft Position Sensors
    - Valley Coolant Pipe to Thermostat housing O-Ring Replaced (OEM from Audi Northlake)
    - Rear horizontal Coolant Pipe to heads O-Rings Replaced (OEM from Audi Northlake)
    - Coolant Pipe through Valley to Rear horizontal Coolant Pipe O-Ring Replaced (OEM from Audi Northlake)
    - Delete of Throttle Body Heater (Capped) https://imgur.com/DZOIyjW
    - Intake Manifold Gaskets Replaced (OEM Victor Reinz)
    Other Additions
    - New (less than 1yr old) Interstate Battery
    - Oil changes with Mobil 1 0w-40 European formula
    Extra Items
    This car can comes with the following if wanted by buyer:
    - 032 braided stainless steel brake lines.
    - Original 3.0 motor (valve damage to heads from timing belt snap is very minimal only on once cylinder head).
    - All extra used parts from engine swap (engine wiring harness, intake manifold, engine coolant piping, Red Cap Ignition Coils (5), new NKG spark plugs (4), and all other parts on rack in picture).
    Imgur Parts Album
    https://imgur.com/a/2NlfSK0
    Hindrick Pre Purchase Inspection – Feb 2018 – 198k Miles
    https://imgur.com/a/txqWmnl
    I purchased an A6 in August-2018 and have not been driving this A4 regularly. I do not expect to add any additional millage to this car.
    I also have 1000+ pictures of all my work on the A4 that I will gladly pass onto the next owner.
    Thanks for reading though this post and let me know if there is any additional details/images that would be helpful for me to provide.
    Thanks,
    -Clarktheshark
    Daily | 2015 A6 C7 3.0 TDI | 8-Speed Auto | Oolong Gray
    For Sale | 2003 Audi B6 A4 Quattro Avant 3.0 | 6-Speed Manual | Atlas Gray
    Previous | 2011 Golf 2.0 TDI 2-Door | VW TDI Buyback
    Jul 05 2016
    Charlotte, NC
    For Additional Info regarding Property Taxes:
    NC DOT Appraised Value $3,530.00
    NC Registration Fee: $36.00
    County and City Tax for 2019: $47.36
    Total Property Tax for 2019: $83.36
    Nov 01 2012
    '87 951, 2010 GTI, '76 Blazer
    Eastern NC
    I will be ecstatic if you still have this for sale in two months. I'm migrating back to the East Coast after I sell my house here in AZ.
    Jul 05 2016
    Charlotte, NC
    Sounds great Drewnashty! Let's stay in touch and good luck with your house sale and the move.
    Jul 05 2016
    Charlotte, NC
    Any feedback? I'm very motivated to sell my A4.
    Nov 01 2012
    Eastern NC
    Just finished my last week at my job. Over the next two weeks I'll be painting, replacing the carpet, landscaping and then Zillow has an inspection scheduled so they can give me an offer. I'm pretty motivated to sell so I think I should have this thing sold near the end of this month.
    The "uneven idle at start", is that anytime you start the engine or only when it's cold? Does it have a hard start also? Once in gear it goes away?
    Jul 05 2016
    Charlotte, NC
    Quote Originally Posted by drewnashty View Post
    The idea smooths out after 15-20 seconds. I personally believe it needs a new fuel pump.
    - - - Updated - - -
    SOLD - Car sold a few hours ago.
