Results 1 to 24 of 24
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Best turbo upgrade for 400 WHP and good spool plug and play?
    I currently have a stage 2 S3, what is the best turbo kit for a daily 400whp?
    Something that is reliable and dosent require fuel system.
    Currently eurodyne stage 2 TCU/ECU and UM Haldex.
    Hopefully was able to stay with eurodyne didn’t want to have to buy all new software but if I have to I will. Currently have a tuner that can road tune with Maestro.
    Nov 13 2009
    the OC, SOCAL
    curious, why not just buy the rs3 at 400 hp?
    Feb 11 2015
    New Jersey
    Not spending that kinda of money in my opinion it is not distinctively different same exterior, identical interior and to me for the money looking for RS wide rendered body kit aggressively obnoxious old RS4 look!
    Senior Member Two Rings BP11's Avatar
    Dec 13 2014
    QuattroLand
    Contact United Motorsports about their offerings for the Vargas hybrid turbo...
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Price difference is about 35k between trade in value on a used S3 and new RS3. If you can go stage 3 for 5k that is not a bad deal.
    There were some options for a modified is38 turbo for more power. That may be another possibility.
    -cW
    2023 X3 M40i Alpine White
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Quote Originally Posted by 2015S3 View Post
    Probably a CTS500 turbot for $3200, sometimes they have it for $3000 on sale. I was APR Stage 2 on my S3 and I was very satisfied, the midrange torque was an avalanche.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Aug 29 2017
    Tucson, AZ
    Quote Originally Posted by 949 View Post
    Not worth it financially. I made the change myself but knowingly that it is not financially a good move. You are at least jumping into a $30000k difference when going from a used
    S3 to a new RS3. Either you buy the RS3 straight up either used or new and skip the S3 or invest $5000 on a turbokit and call it a day. You can also invest more and get a top notch turbokit from Iroz.
    at 3100ft elevation
    Jan 03 2019
    Va
    I have the IHX475, Dragy’d an 11.3 on stock fuel. Ordering a fuel system this week. Want to eventually get an IMS kit, though DBV2 is a really good turbo.
    Apr 07 2018
    durham nc
    Stick to eurodyne and get maestro to custom tune. I got the EQT turbo which is very affordable at 2k and makes easy 430 whp on 93 pump but can do almost 500 at full e85. Its spools maybe 300 rpm later than an is38. I would maybe avoid a boss500 for what your looking for because its definitely laggier than something like the EQT or IHX475 and the housings have been notorious for cracking with CTS kits.
    Established Member Two Rings Jadar's Avatar
    Sep 16 2017
    BMW 335i F30
    Chicago
    Quote Originally Posted by S3DUDE View Post
    What entails a full stage 2 kit bolt on and tune wise? Just picked up an s3 and want to do some type of tune. Do you think it was in the 11’s with the stage 2?
    Not really wanting to do a turbo upgrade long term not sure about the engine taking that. I’m sort of just leaning doing a high torque stage 1.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by Jadar View Post
    I'm stage 2, and best I could do on 93 (today) was a 12.1 @112 Intake, downpipe, res delete, tune, ecu tune. Trans got hot tho. If you want to drag, feels to me like the trans will be the limiting factor. Intercooler probably needed too. Was only 50 today, so don't think that hurt times much though.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Established Member Two Rings 5_cyl's Avatar
    Nov 12 2018
    Salt lake city
    The RS3 shares the same interior but under the hood and the transmission it’s all different. That DQ250 tranny will have a hard time with the power so will the haldex. Save the time and money and get a RS3, a stage 2 RS3 will handle your bigger turbo S3 everyday.
    Aug 29 2017
    Tucson, AZ
    With APR stage 1 I ran 12.5@110 on 91OCT and at 3100ft elevation, with Stage 2(adding a catted downpipes) I ran a 12.2@113-114mph again on 91oct and at 3100ft elevation. both runs with a splash of ethanol. high 11's very possible at sea level. the car with either stage 1 or 2 is plenty fast
    at 3100ft elevation
    Jan 03 2019
    Va
    2015 A3, IHX475 on stock fueling.
    Jan 03 2019
    Va
    Not that I’d suggest this turbo, I’d get a DBV2 over this one. To be fair, stock fuel system was stretched out that run with VP MS109 (105 octane) running 26psi. Buying MPI and a LPFP this week and will convert to E85 and around 31psi.
    Sep 14 2006
    If you're stage 2, literally all you need is the DBV2 that costs less than $3k and is direct bolt on. Just have it tuned through Moose or Mabotech with Maestro. DBV2 made about 400whp/400tq WITHOUT ANY fueling. This is awesome. Quite a few DBV2 S3s and A3s running 10 second quarter mile with high trap speeds. The DBV2 is still working on the triple ball bearing which will be the same price.
    DBV2 sounds like the perfect solution for stage 2 owners because it's literally a bolt on and you don't need to get a custom downpipe. Power seems to come on smooth and early like a stock turbo, but it has top end and keeps pulling.
    If you decide to add fueling, easily over 500whp....EASILY
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Sounds like DBV2 is a great option. What happens when you use it with stock tune? Just runs less boost? I still have 3yrs and 75k left on my Mechanical Breakdown Insurance. I really like the idea of not having to change anything else other than turbo and software. Works with rest of stock parts.
    -cW
    Aug 29 2017
    Tucson, AZ
    So what is a DBV2?
    at 3100ft elevation
    Veteran Member Four Rings 2010A6's Avatar
    Mar 10 2015
    2017 Jeep Cherokee; 2018 S3 Nano Gray
    Albany, NY
    So what is a DBV2?
    Looks to me like a kit for an IS38 internals upgrade. Their site offers an option for the kit with or without a doner turbo.
    Sent from my Pixel 2 XL using Tapatalk
    Current: 2018 Audi S3 2.0T Nano Gray / Magma Red
    Past: 2010 Audi A6 3.0T Midmight Blue / Pistachio Beige
    Jan 03 2019
    Va
    So what is a DBV2?
    https://www.dbv2.com
    Jan 03 2019
    Va
    I’ve had a really good exp with “moose”. Tuned me on both 93 and MS109. Will be tuning me on full e85 once my fuel system comes in and I get a base line 1/4 on race gas to compare to.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    A Borg Warner EFR 6758 or 7163 should get you there and offer a broad power band.
    2019 SQ5 Prestige
    Sep 14 2006
    -cW
    Exactly, it's a perfect option for someone like me who has stage 2 with supporting mods. I don't want to have to get a custom downpipe like I would have to for the turbo upgrade that APR uses. There is a guy who ran a DBV2 turbo (not sure if V1 or V2), but I think he ran 10 sec 1/4 mile with Unitronic stacked with JB4. Personally I'll have mine tuned with Maestro since I already have eurodyne.
    -Thomas
    Current: /S3
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Some other options to consider.
