Page 1 of 4 123 ... LastLast
Results 1 to 40 of 141
    Veteran Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    Completed: B9 S4 Caliper Installation
    Finished results teaser
    Hi guys. I wrote this post to share my experience installing B9 S4 front calipers on my 2014 B8.5. My brake pads were worn down enough to trigger the brake warning, so I used that as an excuse to upgrade my brakes. I got the calipers and OEM pads for about $600 (with pads). Here's a breakdown of the parts used/required and associated cost:
    Parts bought:
    • B9 S4 Front Calipers (2): $600
    • (These are made by Akebono, not Brembo)
    • (Came with pads)
    • Steel Spacers (4 needed): $17.70
    • (1" OD X 1/2" ID X 1/2" Thick)
    • ebay.com
    • Caliper Bracket bolts: $29.95
    • (M12-1.25 x 80mm JIS Hex Head Flange Bolt Class 10.9 Zinc JIS B 1189)
    • Amazon.com
    • C7 A6 Rotors (2): $185
    • Zimmerman Z Coat 100.3357.20 (or 4G0615301A)
    - Total (calipers, bolts, spacers, rotors): $832.65
    Installation Process:
    1. Remove Wheel then turn steering wheel so the caliper side is more accessible. (With the window down, turn the steering wheel to the furthest lock position, then while holding the steering wheel, turn off the car and open the door. This will lock the steering wheel position.)
    2. Remove OEM caliper bolts (13mm)
    3. Remove OEM caliper bracket (21mm). (WARNING: breaker bar required)
    4. Rest the caliper on the lower control arm. Do not remove hydraulic line.
    5. Remove rotor after removing the screw (#27 Torx I believe).
    6. Clean hub with brake dust cleaner and wire brush.
    7. Mark dust shield with Sharpie pen and remove the 4 #27 Torx screws. Remove dust shield then trim the marked spots with heavy duty tin snips. Reinstall dust shield. Hammer any spots that may come in contact with the caliper bracket down flat against the knuckle for best clearance results.
    8. Remove the two 7 point inner spline bolts from the B8 s4 caliper. This will separate the caliper from the bracket. Make sure to note the orientation. I recommend using a vice for this step. (See more info below regarding issues encountered with this step.)
    9. Place the caliper bracket onto the wheel hub knuckle and insert the OEM caliper bracket bolt (21mm socket) into the top hole, keeping it loose.
    10. Let the bracket rest on the knuckle and identify the points of interference preventing the bottom hole from lining up.
    11. Using a grinding bit, remove just enough material from the wheel hub knuckle to allow the bracket holes to line up. This is the kind of non-ferrous bit that gave me the best results.
    12. Once all clearance issues are grinded away, it is now time to install the caliper to the bracket. Add 1/2" tall spacer between the caliper and bracket, using the new 80mm bolts (17mm socket) to replace old 7 point inner spline bolts. Tighten, but do not torque down yet.
    13. Install C7 A6 rotor (356x34) and #27 Torx screw.
    14. Install brake pads (paying attention to the brake pad orientation labels) and brake pad sensor (driver side only). (Optional: jump the old pad sensor and immobilize with zip tie)
    15. Place whole assembled caliper over the rotor, making sure both 21mm bolts can cinch the bracket flush onto the knuckle. Do not tighten. (Looking inside the caliper should show "73L" or "73R", indicating which side of the car that caliper should be installed on.)
    16. Remove assembled caliper and transfer the hydraulic line from the old caliper to new. Completely remove the old caliper from vehicle now. If installing an aftermarket brake line, install that now. If you choose to not disconnect the line from the top of the wheel well, you will need to turn the whole caliper in the air while screwing on the hydraulic line fitting or else the line will twist and bind. The connection is not a swivel type.
    18. Install assembled caliper and rotate the rotor, checking for clearance and listening for any grinding noises (there shouldn't be any).
    19. Torque down the 2 OEM caliper bracket bolts (21mm socket), then the 2 new caliper mounting bolts (17mm socket), then tighten the brake line fitting going into the caliper.
    20. Repeat previous steps for other side.
    21. Bleed brakes (starting from the farthest to closest from reservoir).
    22. Clean up with brake cleaner and a rag/cloth. Apply stickers if so desired.
    23. Reinstall Wheels.
    24. Perform preliminary brake testing, then full brake break-in procedure.
    25. Stand back and admire your new bigger brakes!
    Removing the 7 point inner spline bolts was problematic for me. Using the straight flute style bolt extractors didnt work for me, but the spiral style did the trick. I recommend using the following bolt extractors if removing the bolts becomes problematic for you.
    • Bolt Extractors: Irwin Bolt-Grip
    • Part#: 394002
    Here are the measured weights for the calipers and rotors:
    Calipers (without pads): 12lbs 5.3oz
    Rotors: 30lbs
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
    Jan 25 2015
    MKII%20SQ5%20%28sold%29%2C%20Jeep%20JKU%2C%20MKV%20Jetta%2C%20Tesla%20Model%20S%20P90D
    Monument CO
    Damn, nice write-up. Will definitely be referring back to this.
    - APR Stage 2.5, Jokerz “Chaos” ported supercharger (blown, replaced with OE), APR CPS cooler and DSG tune, Autotech high pressure fuel pump, 034 drive train and rear endlink inserts, KW height adjustable spring (HAS), VS Forged light weight wheels, Snow Performance WMI kit, SRM WMI Direct Injection Plates.
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    Did you have to use spacers for the Peelers? I might go this route instead of the Macans. Nice write up!
    Senior Member Two Rings darkrock's Avatar
    Sep 15 2010
    2013 F150, 2022 Explorer Timberline
    Bergen County, NJ
    Awesome write up! I'll be looking to maybe go this route when I'm due for new brakes
    Sent from my SM-G950U using Audizine mobile app
    2015 S4 6MT Premium+
    Sport Diff, Brilliant Black, Alcantara, Carbon Atlas, B&O, Tech pkg
    H&R OE Sports, ECS intake, ECS x-pipe, ECS flush kit, Magnaflow 11385, Carbon Imports Low Kick, 3M 20% tint
    Previous:
    B5 S4 6MT AWE Stage 3
    B6 S4 6MT stock
    Jun 21 2013
    DC
    Quote Originally Posted by A.C. View Post
    Curious as to what the selling points are for this over the Macan.
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    Nice write up man. That's a pretty cheap OEM BBK setup.
    I would probably get the RS5 brake lines so you have the proper pipe fitting into the fixed caliper instead of the banjo.
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Great Job. Fantastic DIY.
    Nov 24 2018
    Redwood City, CA
    This is awesome. I had been thinking Q5 calipers, but this looks way better and the price is great!
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    Nice write up
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Really nice write up man! When it's time for my brakes I'm definitely going this route. The stock calipers look so tiny in comparison
    Sent from my SM-G965U using Audizine mobile app
    Feb 12 2017
    Redmond, WA
    What caliper brackets did you use and where did you get the spacers?
    Sent from my SM-G955U using Audizine mobile app
    Jan 23 2017
    Idaho
    No wheel spacers needed with my stock Peelers.
    Calipers came with the brackets.
    For Macan vs these, I'm not sure what the price difference is. One pro the Macan has are that they have the slide in style pad cutout so you don't have to remove the caliper to replace pads at all. Price it out and compare. I paid $832 for the whole "kit" including Zimmerman Z coat rotors and OEM pads. YMMV.
    The spacers and bolts were purchased through eBay and Amazon. It's all explained in the post.
    Feb 12 2017
    Redmond, WA
    Quote Originally Posted by FromRagsToS4 View Post
    Sorry, it's not clear if the brackets came with the OEM Calipers. I was reading on my phone and the parts explanation wasn't clear due to spacing.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    These are really nice and they are bigger than the Q5 brakes. The rotor is bigger than stock.
    Nov 28 2015
    Montreal, QC
    Good job and wow are they huge lol!!!
    S4 B8.5 no track, just enjoying spirited driving.
    Sep 22 2013
    Sweet post!
    Established Member Two Rings artz66's Avatar
    Jan 04 2016
    Illinois
    Awesome post. Looks like something I’ll be doing in the future. The difference is amazing, is there any upgrade to the rear brakes?
    Oct 30 2012
    Oxford, MS
    That's nice work. The B8 and B8.5 should have never come with such dinky brakes. Now you need the S6 setup for the rears!
    Jan 23 2017
    Idaho
    Most of the braking comes from the fronts, and the rears arent bad brakes in the least. I think rears would be just for looks if anything.
    Jan 14 2015
    Edmond, Oklahoma
    Where did you source the calipers from for that price? Ive been looking for a while and keep coming up with around $900 total shipped the calipers, brackets, and pads. $600 is a way better price!
    09 A4 P+ with K&N filter and APR Stage one tune, VDCS Mods, LED fog lights, HR OE springs, AG m510 wheels (SOLD)
    14 S4 Prestiege DSG, Sport Diff, Peelers, VDCS Mods, Billy Boat Exhaust (SOLD)
    12 S4 P+ DSG, RS4 Grille, ECS Intake, Peelers, more to come shortly
    Oct 03 2014
    Nyc
    OP where did you source the calipers?
    Tyler beat me too it
    Jan 11 2018
    Toronto/Ontario/Canada
    Quote Originally Posted by tylern012 View Post
    Also interested where you sourced the Calipers?
    Aug 19 2016
    Newport Beach/CA/USA
    i have a set of brembo 4 pot brilliant red just from powder coat. fits oem factory setup. no mod necessary for b8/b8.5 a4/s4 a5/s5 $600 if interested.
    Attachment 106853
    Feb 12 2017
    Redmond, WA
    So why would you do the B9 caliper vs the Porsche Macan, arent they both 6 piston?
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by techracer View Post
    Macan is 4 and I don't think the pad is a as big.
    May 07 2014
    San Diego
    Also this set up uses a 356mm rotor vs 345mm rotor on the q5/macan.
    ‘12 S4 Avant swap
    Feb 12 2017
    Redmond, WA
    according to this JHM link they can do 380mm rotors with the porsche calipers and they say they are 6 piston? https://jhmotorsports.com/products/b...-s4-s5-q5.html
    Oct 30 2012
    Oxford, MS
    Different caliper. The Macan/Q5 is a 4 pot.
    Jan 14 2015
    Edmond, Oklahoma
    According to that link its also almost $3000 for the whole setup, If OP sourced calipers for $600, rotors will be a few hundred, and spacers and bolts are a Misc. cost you come in under or right around $1000. For something that is still 6 pot but 26mm smaller for $2000 less sounds like a good compromise to me .
    Jan 23 2017
    Idaho
    $832.65 with pads and rotors actually...
    Jan 14 2015
    Edmond, Oklahoma
    Where did you find the calipers for so cheap of you don’t mind sharing? Everywhere I have found they are $900 shipped for calipers, brackets, and pads.
    Sep 08 2010
    SF Bay Area
    When they were still affordable. Mine came out to $700 flat, new rotors and pads too.
    Sent from my LM-V350 using Tapatalk
    May 07 2014
    San Diego
    I’m in it $970. I bought the red front and rear $800, Zimmerman rotors $150, spacers $20, hardware I had laying around the shop. Had I hopped on a black front set when available I would have saved a couple hundred bucks. Oh well the red is nice.
    ‘12 S4 Avant swap
    Jan 14 2015
    Edmond, Oklahoma
    Man y’all have a different eBay than I do or something. I have searched the exact verbiage in the above pictures and got nothing. Sent LKQ an email and they said they don’t have any either. WTF!!!!!!!!!
    Apr 16 2017
    Illinois
    Can anyone chime in on whether this is better than the A8 setup with 380mm rotors? I suppose that depends on the caliper difference among both kits.
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Junior Member One Ring
    Jan 16 2019
    Sanchez
    The LKQ ones were limited quantity off wrecked cars.
    More info in this thread
    B9 S4 front brake caliper specs & availability for use on B8's?
    https://r.tapatalk.com/shareLink?sha...9&share_type=t
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    I'm next ! I have Q7 4M Calipers it's a bit bigger and I will need spacers too I knew about. I need 5-8mm spacer and looks like some grinding as well by your pictures. I'm going to use Q7 Rotor 375mm
    Nice work btw
    2013 AUDI S5 4.0T SWAP 9.7@145mph < Press @svarog_performance < last test updates
    Veteran Member Three Rings friskuh's Avatar
    Jul 31 2017
    Orlando
    will the ECS 365x34 rotors work for this caliper?
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    This is annoying. I have no problems with the S4 brakes (I don’t track). But now this is something I need to do.
    This just can’t be ignored:
    Senior Member Three Rings Symko's Avatar
    Jun 10 2011
    ‘12 Glacier S4 ‘19 SQ5 (wife’s)
    Reston, VA
    My thoughts exactly. Huge difference and I am guessing in performance as well.
    Quote Originally Posted by Ford Prefect View Post
