Results 1 to 40 of 47
    Junior Member One Ring
    Feb 15 2019
    Ontario
    8 Speed ZF Transmission-How many litres of fluid needed ?
    How many litres of fluid needed for a filter and fluid change? I want to drain fluid, remove pan, replace filter and fluid. I read the 8 speed holds about 9.5 litres when totally empty but all fluid will not be removed for a drain and filter change.
    Established Member Two Rings B8noobi3's Avatar
    Dec 22 2010
    2014 SQ5 Prestige
    IL
    A little over 4qt. Get 5 to be sure.
    Feb 27 2011
    Winnipeg
    All the fluid change kits seem to come with 9 litres, I'll have 9 on hand when I do mine in the next month or so and I'll save whatever is left for the next change.
    Jul 31 2016
    PA
    It's 8 litres plus a half if you have a trans cooler. See this reference from ZF. So nine sounds like a good number. Do you have a copy of the fluid change procedure and access to VCDS or something to read trans temp? It is a fairly specific procedure and if the trans isn't at the right temp, the fill level will be off.
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Dec 22 2010
    2014 SQ5 Prestige
    IL
    I would like to see how you get all 8 or 9 qt fluid out with just a fluid change without removing the torque converter.
    Jul 31 2016
    PA
    That's a good point, the ZF literature likely assumes you do both. Checked the Audi manual again for fluid capacity and it only says you need about half of that for a refill.
    Sent from my Pixel 3 using Tapatalk
    Jan 08 2016
    Los Angeles, California
    Is there a consensus on the mileage where one should do this? Pretty sure Audi claims it's "lifetime" fluid in there but obviously no fluid lasts forever.
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Jul 31 2016
    PA
    There are a few threads discussing that, ZF also has recommendations, they say 80 to 120k km (50 to 75k miles) depending on use (towing, track, etc.) but no longer than 8 years.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    My A7 with the ZF is at 158K on the original fluid. Previous owner followed the Audi line of lifetime fill. My plan is to drain and refill this spring / summer.
    Lifetime fill is too subjective. Lifetime of what? A car's life relies entirely on how well you maintain it. You can be meticulous and get 400K out of a car or beat the shit out of it and get 40K out of a car. BOTH are a car's lifetime.
    Feb 15 2019
    Ontario
    Thanks all for the replies. I have read that ZF suggests 100,000 kms for a fluid change and who knows, they built the tranny so why argue with them. I am at 86,000 kms and have extended CPO warranty but I will change filter and fluid in spite of Audi's "sermon" on lifetime fluid.
    I have located a Meyle filter, gasket and pan bolts for a lot less than Audi OEM's version.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by A1sailor View Post
    ecs tuning has the meyle filter kit for the best price at $35ish and I believe FCP euro has the cheapest lifeguard 8
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by Valpo A7 View Post
    Might do more harm than good at this point.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Jul 31 2016
    PA
    If done properly how would putting new fluid in and a filter change hurt anything? I'd rather have all the crap that's collected out of the trans.
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Your mileage is more than double the recommended service interval so the grit in the current fluid helps keep the friction between the clutch plates. ymmv
    Nov 27 2018
    Valparaiso, IN
    q5 dave, before I commit to doing it I will get a sample of the trans fluid and make a decision from there. I did some googling yesterday after you mentioned it. There seems to be some contention on whether the new fluid causes the damage or just exposes the damage that already occurred. The old fluid acts as a bandaid for the damage done already.
    Neglected fluid breaks down and coats the internals with varnish/sludge. New trans fluid is a very aggressive solvent and will immediately start attacking these deposits. You don't know you have a problem because you’ve been going along happily ignorant of the impending problem. Then someone works on the trans, a problem develops and the owner blames the last shop to touch it. If left alone, it will fail anyway. Broken down fluid is no longer capable of doing the job it needs to do.
    Feb 15 2007
    I just had my trans fluid on my 3.0T changed with a new OEM filter and gasket. It took 7 1L bottles of ZF Lifeguard 8 'green' fluid. it was full at 6.5 L, but decided to flush a little extra. My Q5 had 82k miles. I can definitely tell you shifts are smoother and quicker. My shop recommends a trans flush every 50-60k miles. Make sure you follow ZF's procedure to the T.
    Also, avoid the Miele filter kit. I've heard bad things about it. Not constructed very well and metal is weak. We drive Audi's. They are expensive.
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Feb 15 2019
    Ontario
    Zach, was it a fluid drain and filter change that your shop did on your vehicle that used about 7 litres? You mention they chose to "flush" a little more fluid, was the service a flush or a drain and filter change?
    Its surprising to hear about the Meyle filter concerns that you mention as Meyle is an OEM supplier of various parts to the auto industry.
    Thanks
    Feb 15 2007
    The trans was drained when cold. The trans pan was then removed and the new filter was fitted, along with new gasket. Then the trans was filled cold. Then the trans was warmed up until oil was proper temp according to ZF spec. Then it was topped off and had an extra .5L left over so it was 'flushed' through.
    My shop has done "tons of the ZF8's" and they say the ZF8's take 6L but a few take up to 7L of fluids. I trust them, as they have been Audi trained and all have experience at the dealers. They recommend a trans 'service' every 50k miles. I think this is a bit on the conservative side, as ZF suggest a little higher mileage.
    And I was surprised to read/ hear about the Miele as well. Could have saved me about $150 but didn't want to risk it.
    Dec 22 2010
    2014 SQ5 Prestige
    IL
    Quote Originally Posted by zachf88 View Post
    That’s how they work since forever, the mechanic gains your trust then shafts you with guilt trips.
    I’ve personally changed 2 Q5’s and many other Zf from Bmw and none had gone over 5qt with just a drain and filter change. I wouldn’t be surprised if you open up your transmission filter to see a Meyle.
    Feb 15 2019
    Ontario
    I contacted Meyle, they said the transmission filters are built to meet the OEM specifications for the transmission filter, however, they are not approved to the specification by Audi. They are an aftermarket product.
    Feb 15 2007
    Quote Originally Posted by B8noobi3 View Post
    That might be the case with your tech, but my tech didn't see a dime for the filter. I bought it from another company (FCP Euro). Don't be so quick to jump to conclusions. It wasn't stamped with Meyle either. I have offered my 2 cents. Proceed how you want. $150 extra for OEM filter and gasket is not bad for assurance that it'll be perfect fit. Last thing I would hate is to have a crappy filter and have a car out of commission a few days and more costly repairs. I bought from FCP Euro to take advantage of their lifetime replacement warranty.
    Feb 15 2019
    Ontario
    I will try the Meyle transmission filter option, I do trust the company, I have used their products on Benzs in past.
    Jan 08 2016
    How was the Meyle filter? My mechanic is working on this for me today (felt compelled to get this done after reading this thread). We went with oem filter to be safe but damn the filter and fluid are expensive!
    Jan 08 2016
    FYI just got this done and mine took 7L also (my mechanic also thought only 6L was needed beforehand). The transmission now shifts night and day better, i.e. faster, crisper and more smoothly. I bought my vehicle used and was always a bit annoyed about how my ZF8 seemed to shift clunky but now I realize it just needed a fluid and filter change. It's expensive but WELL worth it.
    Established Member Two Rings Ashs4b8's Avatar
    Nov 21 2017
    For those that used the Meyle filter option, has there been any issues?
    Sent from my SM-G930U using Audizine mobile app
    2014 Audi SQ5 Prestige Phantom Black
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    Just check, some Meyle stuff is made in China now. If it's made in Germany or Europe for that matter I'd be fine with it but made in China, NO! Some Febi Bilstein stuff is made in China too.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Established Member Two Rings Damonkey09's Avatar
    Jun 07 2020
    69 Chevy C10 swb
    Fort Worth/Texas
    Bringing up an old thread but wanted to ask you Zack did you have a kit from FCP? If so can you share it? I would like to get the filter, gasket, fluid. And I thing I will get 2 4L just to make sure I have enough.
    Established Member Two Rings DUBDAWG's Avatar
    Aug 18 2017
    SQ5, IV Jetta 2.Slow, Polaris RZR, Yamaha Viper
    Syracuse New York
    Just did the ZF filter with the lifeguard 8 change. Ended up taking 6L and even seems alot happier now!
    Veteran Member Four Rings bb-tt's Avatar
    Apr 30 2018
    2017 TTS, 2011 Avant, 82 c3 vette, 2002 TT (sold), 2010 CC (sold), 2013 Jetta, 2018 Q7, 2019 Tiguan
    DFW, TX
    Quote Originally Posted by DUBDAWG View Post
    wow, that is the most i have heard anyone using for just a drain and filter change.
    2011 A4 Avant S-line Prestige
    Nothing to see here, keep moving!
    WPT+
    Feb 06 2013
    CA
    when I did mine, it took about 5.5 L, I had barely 1/2 of a bottle left since I'd ordered 6.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by djn876 View Post
    Just did mine today. The above chart was spot-on correct for a refill. 4 liters. That included the engine-running top off.
    FWIW, I did it twice, since I had 9 liters in the FCP Euro kit. The second drain/fill/top off was today after the first yesterday to thoroughly mix the new and remaining old. This gives me peace if mind, since the first drain fluid was very dark at 72,000 miles. So, total used was 8 liters, 4 each time.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Senior Member Three Rings no thx's Avatar
    Feb 26 2017
    DTW
    Change the filter too. You will be very surprised at how much sludge will be on the magnets
    Feb 26 2017
    DTW
    Quote Originally Posted by Ashs4b8 View Post
    Meyle filter is made in taiwan, and it also doesn't come with replacement drain/fill plugs. I would recommend official ZF one for that reason.
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by no thx View Post
    Meyle is OEM quality. I've used their filters for . . . decades in various vehicles. So, I went with the FCP Euro kit. FWIW, ZF does not manufacture filters. They are bought from a vendor and rebranded. I'm sure they are excellent quality. Meyle is, too. Mann, Meyle, Hengst and Bosch are all excellent euro-spec filters across the board. I would not hesitate to use any of those brand names.
    Lack of new drain/fill plugs are irrelevant to me. They are not the same design as oil plugs. I've never replaced a fill plug on any fluid on any vehicle - auto, truck, industrial or farm engine. Not on differentials, transmissions, gear boxes. I've been wrenching over 50 years.
    As to the drain plug - take a good look at the OEM design. It has a built-in o-ring. If it is damaged, you will get a leak right away. They don't wait to leak. Either they seal or they don't. Leave a clean pan under it while doing the fill and top off. If it is going to leak, you'll know it by the time you are ready to button up the bottom trays and bring the car back down off the lift or jack stands.
    As to the condition of the old filter, yes, there was quite a bit of fine graphite-looking metallic sludge on the magnets. It was doing its job. Since this is the OEM filter on the car when it left the factory, it saw the original break-in period for the new transmission. It is likely that most of the particles were generated during the first few hundred miles. However, the amount of material on the magnets did cause me to do the "double fill" to further dilute the old fluid still present.
    Just one opinion . . .
    Apr 30 2018
    DFW, TX
    Quote Originally Posted by MSq5 View Post
    That is my plan other than i was going to try to put a couple hundred miles on it before doing the second drain and fill. was going to try and do filter and first drain today but got tied up and have dyno time scheduled 2moro morning so put off at least another week. Agree 100% on the meyle filter.
    WPT+
    Feb 14 2017
    Gulfport, MS
    Maybe its just me, but removing the transmission undertray was not easy. There are three T-25 screws. That's the easy part. There are two plastic "push" fasteners, one on each side. They don't want to come out. Eventually, I had to find a way to get a finger on the back side and pull each of the three "prongs" away from the center post to unlock it and get it out. Dealer probably just cuts them off and replaces with new to save time.
    If you are going to do the double drain refill process, I recommend you leave the undertray off until completely done.
    Jun 07 2020
    69 Chevy C10 swb
    Fort Worth/Texas
    Has anyone used a fluid evacuator to pull more out? I have ordered the 9L kit and would like to pull more out in one shot.
    Sent from my iPad using Audizine Forum
    Established Member Two Rings serg72's Avatar
    May 19 2021
    Kharkiv, Ukraine
    Quote Originally Posted by Damonkey09 View Post
    I never did that, I don't think it's necessary. Replace every 60 t. Km and there will be no problems. On the reverse car was 5hp19, made a replacement every 60 t. Km and had no problems, drove 560 t. Km
    Feb 14 2017
    Gulfport, MS
    I have one, even transmission specific. Its great for filling, as it both extracts and fills by reversing the valve. It will not be of any benefit for drain, if you are thinking of inserting your hose in the fill plug. The ZF8 has a separate drain plug at the very bottom of the pan. Then you actually remove the pan to change the filter. Its like taking the pan off the engine. There will be some oil in the pan, so you tilt it and let it flow into your drain collector. You let any remaining fluid drip from the exposed transmission internals. Then you replace the filter and reinstall the pan, with a new pan gasket.
    The issue is that there are chambers in the transmission that hold fluid, so does the torque converter. They do not drain. The only way to get more than about 4 maybe 4.5 liters out is by successive drain and fills to dilute the old fluid with new and drain and fill a second time. This is by using the initial fill and top off procedure each time.
    Jun 07 2020
    69 Chevy C10 swb
    Fort Worth/Texas
    Thanks MSq5. That was what I figured but wanted to check with someone first.
