Originally Posted by
MSq5
Do you have any evidence of present safety of Red Line Waterwetter with G12? Why do you conclude that they have "adjusted their chemistry"? Any evidence of that beyond "I've had no problems." There was an objective test in that thread where one member actually added the product to a solution of water and G12, heated the mixture and observed and documented the formation of the precipitate. It was nasty stuff. Do we have any current testing of that type that would make me feel that, indeed, the formulation was changed? I'd like to see some objective evidence.
My '17 came with pink coolant, which I believe to be G12. I will make sure to switch to G13 in the future - Merc Racing heat exchanger on order, but many here are running G12.
So just like all of the other people who had no issues in the threads you shared, I just have my own experience, that is my only 'evidence'. As is the same as all of the people who did claim to have some interaction. It is all anecdotal evidence, but not sure why people's experiences do not have issues are provided less weight in their experience than people that do.
I also never concluded anything, I said they likely would have adjusted their product. I don't work for them nor have I done chemical analysis between the two, however the assumption that a product manufacturer would not test or update their product over a decade and a half to ensure compatibility as new products come out to ensure their continued viability in their target market seems an unlikely business model.
The "test" performed was far from scientific, in a 'metal' container of unspecified alloy, that was contaminated with who knows what, doesn't provide a lot of scientific info. If there were pictures, they aren't there any more. Again, going back to why are the experiences of people running it without any issues for 100k miles as invalid data points, but a guy with torch and a cup is the only data point we need? Those experiences of real world application (which, for semantics, could be called "testing") should also be considered valid and therefore one could postulate that maybe there is another variable to consider that is causing an issue and not just simply the interaction of the two products since the results are not universal (manufacturing batches, system contaminants, etc.).
I'm done though, I get you won't use it and presenting both sides is fair and people should make up their own minds based on all the info out there, I just wanted to point out it is not a universal problem, and there are just as many instances of people running it long term with no problem.
The shop manual for my car says G13, so could be what is in there and could be more compatible, again as stated, just my experience.
