Results 1 to 30 of 30
    Established Member Two Rings SepangBlueS4's Avatar
    Feb 25 2013
    2013 B8.5 S4 2012 Range Rover Evoque
    Everett, WA Pacific Northwest
    Is it safe to drive without an undercarriage cover?
    Hey,
    We got hammered with over a foot of snow in the PNW. I drove over some compact ice which impacted the bottom of my car.. When I got home, I looked under my car and saw that my undercarriage cover on the passenger side broke in half.
    Is it safe to drive without the cover. Theres tons of snow, gravel, and debris on the road still due to the snowstorm.
    Thanks
    2013 Sepang Blue S4 - Premium Plus - 6MT - SS Inlays - MMI Nav - Sports Diff - Black/Black Alcantara - Full Front End Xpel - Gtechniq C1 Paint Protection - 20% Ceramic Tint
    Mod List: EuroCode Alu Kreuz - H&R OE Springs - Eurocode Sway bars - Eurocode End Links - AWE Exhaust /w non-resonated DPs. Black Diamond Tips - Roc-Euro Intake - Deval CF Rear Diffuser
    Wheels and Tires: VMR 718s 19x9.5 ET45 Hyper Silver. Michelin A/S3s 255/35/19
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Well done inspecting the area after the fact, man. A lot of people don't even bother to do that much, which is beyond sad.
    Considering you live in a climate like I do, I'd get that sucker replaced as soon as possible. If it's your daily-driver/your only means of transportation...I'd just take extra caution until you get a proper cover back on.
    Not only does more salt, sand, gravel and other debris get in there while the area is exposed, but those components are relatively fragile - hence the need for a cover.
    Good luck!
    Feb 25 2013
    Quote Originally Posted by Envy187 View Post
    Good luck!
    Thanks for the reply. Luckily the don't salt the roads here anymore.
    Yeah, this is my daily driver so I'll most likely be driving the wife's car until I'm able to get mine to a shop.
    Jun 05 2017
    Norfolk, VA
    If there is something that can do that to your cover, imagine what would happen to a fragile component without that protection. That and who wants all that salt and gravel getting all up in their under bits?
    S4 B8 3.0T, Silver: Current - Sports Diff. APR Stage 1
    A4 B8 2.0T, Silver: SOLD - APR: Stage 2
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    You may want to consider replacing it with a metal cover from ECS Tuning.
    Sent from my SCH-I545 using Audizine mobile app
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Jul 05 2018
    Everett, WA
    Same thing happened to me. I’ve been driving without one for over a month.
    Senior Member Three Rings Robdukes's Avatar
    Dec 11 2014
    01 Audi A4 2.8 Quattro
    Mount Cobb, PA
    Just did an oil change and noticed in the cover thats right in front of the main big cover ..there was alot of bits of road gravel and various bits of debris. Even found some beach colored pepples that must have gotten in there from the previous owner who lived next to the ocean. And thats with a cover thats not broken. Couldn't imagine how much junk would get in there with a broken or removed cover.
    Sent from my SM-N960U using Tapatalk
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The plastic covers are more for noise reduction and aerodynamics. You should replace it, but it is not critical.
    Feb 13 2018
    Quote Originally Posted by S4'ed View Post
    I'd love to see you remove whatever you have on your vehicle and go "nude". Especially in New Jersey with your adequate winters and snow-removal products they put on the roads? HOO-WEE!
    Senior Member Two Rings kashanova's Avatar
    Mar 11 2011
    Bronx, NY
    I got burned by this, I had some salt get in some crucial areas and it screwed me to the tune of $4000. I'd get it fixed asap.
    Feb 13 2018
    Quote Originally Posted by kashanova View Post
    Yikes, dude. That's beyond rough. Thank you for sharing!
    Feb 25 2013
    Yeah, I'll get it fixed soon. Luckily they dont throw salt down in the PNW.
    - - - Updated - - -
    Quote Originally Posted by doughboy17 View Post
    Thanks, I'll look into that.
    Aug 17 2015
    California
    Exactly this. If you are lowered, I highly recommend the ECS street shield. I had my plastic cover shredded by a huge chunk of ice one winter. Promptly replaced it with the Street Shield and havn't looked back. Have smacked the street shield a few times and glad I have it.
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by A4x View Post
    Better yet, get the evolution Thor skid plate. Much thicker, and better design. ECS SS is ok, but its held in place by basically same hardware as factory plastic on. Have heard many people complain a nj out it, but no personal experience. I'm going with Thor when I lower in spring.
    Sent from my VS995 using Audizine mobile app
    Veteran Member Three Rings VroomTT's Avatar
    Nov 21 2013
    SE FL
    Ohhh, my plastic shield was mia when I got my b8 recently. Luckily no snow in SFL, but I've been pondering the same question since buying it...
    I can only imagine how much dirt/dust/sand kicks up into the bay without it
    I've been on the hunt for a used one, but may go the metal ecs route seeing as I'm also missing the hardware (multiple zip-ties currently employed to keep everthing where it needs to be hahaha)
    Also, not to hijack the the thread, but what about all the other underbody items, like the covers along botton all the way to the back. I'm pretty much missing a whole side and parts of one side (remnants of them are there, which I need to remove but it almost looks like they exploded off. Idk wtf happened there )
    Veteran Member Three Rings mys4.org's Avatar
    Dec 18 2007
    2013 S4 | 2013 Q5 3.0T
    PNW | Monroe, WA
    Quote Originally Posted by SepangBlueS4 View Post
    If you are in Western Washington I hate to give the bad news, but in this last storm most cities and WADOT did use a mix of salt and sand. They just don't use it all the time as we don't get hit with these 50 years storm often.
    https://www.wsdot.com/winter/WinterOps.htm
    In years past they tried to avoid salt but that effort mostly fail for high cost and effictiveness.
    MyS4.org | B8.5 2013 Audi S4: EPL Stage 2, Solo-Werks Coilovers | B8.5 2013 Audi Q5 3.0T: EPL Stage 1 & ZF Tune | Instagram: mys4dotorg
    Senior Member Three Rings studiobmx's Avatar
    Jun 20 2016
    1.8T Vanagon, B7 Avant, C5 Allroad, NCV3 Sprinter, Q5 (wife's), CB550
    Tacoma
    I’ve never had mine, and I detail my engine bay multiple times a year.... maybe I should get one 🤦🏼*♂️
    Feb 25 2013
    Quote Originally Posted by mys4.org View Post
    Well damn. Looks like I'm keeping my car in the garage until the rain washes all the salt away.
    Veteran Member Four Rings Joker S4's Avatar
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    I didn't like fitment of those street shields one bit. The front one is pretty legit, but I was never comfortable with the mounting hardware. And I also had the transmission plate, but that doesn't bolt up to the AK Brace.
    | 2012 S4 Prestige | TI Black Optics | Monsoon Gray Metallic | Black/Magma | STUFF | TD1
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Gorilla tape FTW
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by bakedziti View Post
    I lost all of mine in the first year or so of ownership, and finally replaced them all this past summer. They're expensive new, and pretty difficult to find secondhand from someone who will ship them. I picked up all 6 pieces from a part out for $200.
    My caution to riding without them is that they also cover all of your fuel lines.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Oct 31 2011
    B8.5 S4, B9.5 SQ5, MK4 Jetta
    Redmond, WA
    Anyone have part numbers for the covers??
    "if I wanted magic phallus shaped objects that didn't make me go any faster, I would just hit the gay club downtown, no need to spend $400." - Mec
    S4 Build
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by AKO View Post
    There’s 6 of them, 3 on each side. The two in the front and rear don’t appear to have been updated between the B8 & B8.5 MYs. Also, double check that the left middle didn’t get a revision.
    Left (F;M;R): 8K0825201E ; 8K0825207C* ; 8K0825215J
    Right (F;M;R): 8K0825202A ; 8K0825208H ; 8K0825216G
    °2011 A4 | 6MT
    Feb 24 2019
    Baltimore, MD
    You happen to know which bolts/screws/fasteners secure the front-most left one (8K0825201E)?
    Sent from my SM-G955F using Tapatalk
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by Javier.san1993 View Post
    IIRC; you’ll need a plastic shoulder nut PN#8E0825265C, but you may be able to salvage one from your old piece, or a new oem one should actually come with one of these. The other fastener is PN#8E0825267 and is a spreader type plastic rivet.
    °2011 A4 | 6MT
    May 14 2019
    AZ
    Quote Originally Posted by Joker S4 View Post
    Yes I have the Alu Kbrace and I bought he ECS trans cover but it does not mount up. Any options as I no longer have the stock trans cover
    Oct 14 2012
    Empty...for now...
    SE PA
    Does anyone know of any aftermarket options for the transmission belly pan/cover (the one that covers the x-brace)? Mine has been MIA for a while but originally because damaged when a bunch of snow went up through the slot and turned into a heavy chunk of ice. Ultimately the plastic-felt construction could not hold up to the wetness and weight and it must have dropped off on the road at some point. An aluminum option to compliment the ECS Street Shield would be ideal. I should add that I have the Eurocode Alu Kreuz brace.
    SOLD 2015 Daytona Gray S4
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by JBravo View Post
    What is it about the ECS transmission cover that prevents it from mounting to the Alu Kreuz? Is it a matter of having to modify or add holes to the shield to accommodate the mounting points on the brace, or is it just the wrong shape altogether?
    May 14 2019
    AZ
    I don’t remember the specifics but I do know that it shares 2 of the stretch bolts of the alu kreuz and then the front cover had issues fitting together with it. Maybe if you used both ECS aluminum covers it might work better. But regardless, the only way to drop the Alum transmission cover is to always pull the Alu Kreuz stretch bolts.
    Jun 20 2014
    B8-S4/Q5
    Mid-Atlantic
    Buy a new one? ECS has OEM and an off brand aftermarket. Both will suffice. Or fabricate your own.
    Sent from my SM-G930V using Audizine mobile app
