Yes it does! If you press the ECS button once it goes into sport mode. You need to turn it completely off. To start, start out with the car already warmed up a bit or you can’t do it. Then, at a dead HOLD the ECS button down until you see in the screen between your gauges that the ECS has been completely turned off. If you don’t hold it down, it won’t turn off. It will turn to ECS sport first, but don’t let off the button. Keep holding until you see it says ECS off.
Next, push the brake, mat the gas until it revs to about 5k rpms ish, dump the brake, and keep your foot fully floored.
Disclaimer, I’m not responsible for the thrills / crash that could potentially result if you are doing this in New England cold weather. Lol
Good luck and enjoy!
Sent from my iPhone using
Audizine
