Results 1 to 12 of 12
    Veteran Member Four Rings RoofRails's Avatar
    Apr 29 2018
    Wow...... The ZF 8hp
    2015 Q5 3.0T S-Line | Glacier White |10.96 @ 126mph ! | 034 Stage 2+ E40 octane tune | Fluid Damper Crank Pulley 200mm / Griptech 60mm SC Pulley | Jokers Ported blower with APR UC TB | BG SQ5-HPT TCU tune| Snow WMI injection kit 400cc @ TB, 300cc @ BPV | Merc Racing C7 HX / CWA 100-3 pump 100% DC | APR open intake W/carbon UC pipe | Vogtland Springs | Nuespeed RS102 20/9.5/et25 rims |
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Pretty crazy. I had to watch some other auto trans educational videos to make any sense of this. I could barely understand 6 speeds!
    Interesting that each series of the 8HP has a different power rating. Looks like we have the “8HP55” which is rated to 550 ft/lb of torque. Good to know!
    May 31 2016
    Mexico
    Quote Originally Posted by PNW Avant View Post
    8HP55 is actually 500 newton meter which translates to 405 ft-lbs.
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Ah good catch... seems like many here are surpassing that figure with mods and tunes....
    Wikipedia says 550nm
    https://en.m.wikipedia.org/wiki/ZF_8HP_transmission
    But perhaps the rating is at the output, not input?
    Jan 08 2016
    Los Angeles, California
    Quote Originally Posted by Q5OnTheMove View Post
    That makes no sense; the TDI comes stock with 428 ft-lbs.
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    May 31 2016
    Mexico
    Quote Originally Posted by Pittdawg View Post
    I was answering the question on 8hp55. I never claimed thats what the tdi has. Raise thd vehicle and check part numbers to see which transmission the tdi has.
    Jul 31 2016
    PA
    ZF uses the last two digits to specify the torque rating. 55 is 550 NM, 70 is 700 NM, etc. So for us it is 550 NM or about 405 lb ft, as previously stated.
    Sent from my Pixel 3 using Tapatalk
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    I think wikipedia just has some bad information.
    ZF documents say the 8HP55A can take 650nm. So more like 480 ft/lbs.
    https://www.yumpu.com/en/document/re...drichshafen-ag
    Jul 31 2016
    PA
    The 55A was a higher torque variant of the 55 made for some specific vehicles if I remember from reading before about these. Sometimes they provide a higher torque rating for diesel applications so likely the internals are a little different even if the trans model is the same.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    If I take these two sources together, the Q5's have the "0BK" transmission, which Ross Tech says is a "ZF 8HP55AF" with 700nm max torque.... The Q5, Q5 TDI and SQ5 transmissions all start with code "0BK" but ultimately have slightly different part numbers. Certainly possible they are slightly different variants, but I doubt it.
    I can't really find anything about the "8HP55" without the "A".
    "OBK" Trans code
    https://audiparts.audiwilmingtonde.c...-0bk300042d002
    0BK = 8HP55A
    http://wiki.ross-tech.com/wiki/index...:Transmissions
    Jan 08 2016
    "OBK" Trans code
    0BK = 8HP55A
    That's my point, there's many modified 3.0T (Q5s and SQ5s) well north of 400 hp and 400 tq; meaning many would have grenaded their transmissions by now if they were limited to just 405 ft-lbs tq. 500 ft-lbs tq is much more likely to be accurate in my informed estimate.
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    Yeah that clearly made no sense so I tracked down the facts. Lots of misinformation apparently.
