Results 1 to 23 of 23
    Veteran Member Three Rings abe's Avatar
    Feb 22 2009
    2008 S4 Avant, 2015 Q7 TDI, 2017 Q5, 2013 F-450, 2015 Ford Edge SEL
    Must I Use Adblue?
    Have to do this first fill on my 2015 Q7. Must I use Audi's adblue product or can I use the Blue Def product? My belief is that it's just a water/urea solution so there shouldn't be an issue but perhaps there's another additive or something.
    I searched but I couldn't find a thread or website that addressed this question. I fail at searching. Sorry.
    Thank you!
    Onwards,
    -abe
    '08 B7 Ibis White Avant
    Feb 22 2009
    And then to follow up, I seem to recall a while back that using these would not fill the tank completely. Is that true?
    Onwards,
    -abe
    Mar 02 2009
    State of Confusion
    Blu def is fine- it's all the same stuff
    Mar 02 2009
    State of Confusion
    Quote Originally Posted by abe View Post
    Check your owners manual to see fill amount. Keep in mind that it is probably not completely empty when you fill it.
    Try not to spill the urea solution as it's caustic
    Feb 22 2009
    So following up on this, seems like whenever I post for help I always find it right after the post.
    It looks like it would be quite difficult to fill up using anything other than the AdBlue bottle with the special spout or getting a special fill hose so I could use a larger supply jug. Someone suggested elsewhere that once you use one of those special bottles to cut the bottom off of it and use it again in the future, which I will. Results were mixed on whether or not Blue Def (which has the same ISO certification) is a good or bad thing. What I can't find is a supply with a two-day delivery, and no one around here (Advance, Auto Zone, etc.) seems to carry this stuff in stock. So I'll have to buy it direct from Audi. No biggie if it's just the one time thing.
    Thanks for the replies folks. BTW I've spilled urea on the side of my Ford several times. When it dries it leaves a salt residue, which is expected. Didn't seem to harm the paint tho. Not saying you're wrong! I'll be careful. Thanks.
    Onwards,
    -abe
    Mar 02 2009
    State of Confusion
    Walmart has it here
    Veteran Member Four Rings s4buckeye's Avatar
    Dec 21 2008
    '23 RS3, '23 S5 Cab and '22 RAM 3500 SRW LTD NE
    Kali
    Must I Use Adblue?
    you can use any DEF out there. most have the nozzle that fits. Napa has it with a bottle and nozzle that fits. pretty cheap iirc as well.
    fill it until it burps, let it settle and run into the other of the two tanks. fill until full and spray off any excess with water
    “Wanting to be someone else is a waste of who you are.” - Kurt Cobain
    Active Member Two Rings Pierce330's Avatar
    Sep 28 2018
    GTA Ontario, Canada
    Thank you!
    You could actually delete the system as a whole! It will make your Tdi more reliable. Reliability issues lie within the clean diesel tech.
    Mar 07 2004
    2025 Q7, 2018 TTRS, 2022 Q5
    Charleston, W.V.
    The dealership will fill it for free. It was part of the settlement on repaired TDI’s.
    Established Member Two Rings matt94gt's Avatar
    Aug 10 2011
    72%20Bus
    Victoria BC Canada
    Quote Originally Posted by BarryT82 View Post
    Not here in Canada at least, I was told only during services.
    14' Audi Q7 TDI Sline
    06' Audi A4 Avant Quattro - sold
    94' Ford Mustang GT - Modded
    72' VW Bus - OG Stock
    Jan 24 2016
    KCMO
    Quote Originally Posted by matt94gt View Post
    I discussed with my Service Advisor. In the US, they will fill once between service intervals for free, not an unlimited number of times.
    Veteran Member Three Rings mark_ma's Avatar
    Feb 25 2015
    Denver/Colorado
    if you have your owners manual, look on page 263
    i highlighted the requirements of the adblue/def.
    as long as it meets the ISO 22241-1, your good.
    cheaper to go to walmart to buy the 2.5 gallon then go to the stealership
    Le build thread of mark_ma,
    Instagram: @mark_b6s4, Youtube: markb6s4
    4 wheels, 8 pistons, two mufflers , ultra light weight seat warmers, see through windows, carbon fiber turn signals, wireless key fob, photon reflecting side mirrors
    Mar 02 2019
    Minnesota
    Walmart all the way! Cheapest by far.
    Veteran Member Three Rings street2gen's Avatar
    Oct 13 2013
    Whitewater, WI
    Ive had two dealerships in our area tell us its not free one of which said it takes an 1hr and a half to fill....??????, I believe i remember seeing documentation that said it was part of the settlement, does anybody have that?
    Ill just fill my self with this much of a hassle, but wth.....
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Everyone should inform AoA of each dealership that fails to meet the stipulations of the settlement.
    Established Member Two Rings allbizns's Avatar
    Jan 02 2016
    2013 Audi Q7 TDI S-Line, 2018 Ram 2500 Cummins, 2006 Mazda Speed 6, 1970 Big Block Nova, 1955 Chevy
    Mooresville N.C
    Quote Originally Posted by dredog1984 View Post
    This is my dealerships policy also. But I also have a Diesel pickup so I always have 2.5 gallons of Peak Blue Def on hand. I buy it on sale at my local parts store they usually have a sale of 2 (2.5 gallon) jugs for $17.99. Thats all I have run in mine other than the few times its been to the dealer and they top it off with AdBlue with no issues.
    I also run Opti-lube XPD In every other tank of fuel.
    Sent from my SM-G930V using Tapatalk
    Oct 13 2013
    Whitewater, WI
    Quote Originally Posted by street2gen View Post
    Ended up going with 3rd dealer i called that did it for free.... Kid got the S**t all over the side of the car and all over the s-line wheels..........ill do it my self from now on lol
    But we now have a hesitation/stumble that's very noticeable after cold start until it warms up. Threw a CEL also, i forgot what the code was will have to check it again later.
    Veteran Member Three Rings Gunmeister's Avatar
    Feb 03 2019
    Spokane, WA
    Has anyone had a hard time with Audi honoring free AdBlue fill ups from your local dealer? I've always had them fill it no question asked and now all of a sudden my local dealer refuses to fill my Adblue and said to go to my next closest dealer hich is 4 hours away. They also said because I didn't get my vehicle serviced at their dealer that they will not honor this free service. I called Audi of America and they told me they have to do more research on the matter and have not given me a response. When I told Audi of America I do not get my vehicle serviced at this dealer or any dealer anymore unless warranty work they seemed alarmed. My Audi Care expired and I now purchase my own oil and filters but I perform the maintenance myself. In this supplied paperwork it does not state anywhere that I have to go to an Audi Dealer. I know AdBlue isn't very expensive but its the principle at this point. Let me know your experiences if you have any.Screenshot_20211211-223446_Adobe%20Acrobat.jpg20211211_223611.jpg
    2016 A6 TDI*|*Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | Audi All Weather Mats*| 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | iDatastart VWX CMVWXA0 Remote Start*| Auto Hold Activated | ESCORT Radar Max 360c*| 1 of 1 for 2016
    2016 A6 TDI | Mugello Blue, Pearl Effect Exterior | Alabastar White Interior | Audi Exclusive Line | Eucalyptus Natural Wood Decorative Inlays | Prestige Package | Comfort Seating Package | Driver Assistance Package | S Line Sport Package | 20" Black Optic Package | Cold Weather Package | 18% Ceramic Film Windows | 70% Ceramic Film Windshield | Thinkware Q800 Pro Dash Cam | Audi All Weather Mats |1 of 1 for 2016|
    Veteran Member Four Rings Zolli's Avatar
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    Quote Originally Posted by Gunmeister View Post
    My nearby dealer, Audi North Scottsdale (operated by Penske), has topped it off on the occasional times I’ve brought it in for service. The first time, incidentally, it was in for service because the pump that transfers the DEF between tanks had failed, so I was getting the 1500 mile warning much too frequently. Normally I do my own service work, as much as I can anyway, and fortunately they are cool about it. The only time I’ve had a service guy aghast is when he saw that my wheels and tires were not the Pirelli trash that fits the S-Line 22s (I had some aftermarket wheels and all-seasons fitted for some rough terrain work). I’ve never purchased AdBlue; I’ve only used Blue DEF and once the transfer pump was fixed, the refills have been on about a 9500-mile interval.
    Feb 03 2019
    Spokane, WA
    Quote Originally Posted by Zolli View Post
    My dealer damaged my vehicle doing warranty work a couple years ago so we aren't on the best of terms. I'm hoping Audi of America forces them to comply to the warranty.
    Sep 29 2016
    2011 Q7 TDI
    Scottsdale, AZ
    My dealer did too: put a scratch in the rear bumper that looks like the driver backed it into one of their stucco walls. I didn’t notice it until I got home. Very irritating, and I can’t prove they did it. I hate going to the dealer for anything other than specialist items. This latest visit was for an airbag igniter. I don’t fool around with the airbag system so insurance doesn’t have a reason to deny a claim.
    I hope AoA stays on them, too. Be sure to make a report, and use names
    Feb 03 2019
    Spokane, WA
    It wasn't Audi of Spokane by chance was it lol? So frustrating. Why can't the quality of service match the quality of the brand. I rrally enjoy my Audi... but I can't take it anywhere without being let down.
