Results 1 to 17 of 17
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Backup Camera retrofit possible for better resolution?
    Has anybody tried or accomplished it? The B9 and C8 cameras have much much better resolution and they are very functional in the night also. The C7/C7.5 just looks shitty and is almost useless in the night if there are no street lights.
    Sent from my SM-N950U using Tapatalk
    Aug 11 2016
    CA
    I agree 100%. I was shocked how crappy the cameras are.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    agreed as well my c6.5 camera was light years better too.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    May 11 2014
    Walnut Creek
    Subscribing to this.
    I wonder if it’s the camera or display being shitty. Or both I guess.
    Oct 23 2018
    Left Coast
    Wow, someone is reading my mind! Agree 100%. I was driving a rented a KIA Optima last week, and compared to my C7.5, the backup camera blew me away.
    Subscribed.
    Jan 22 2019
    Auckland New Zealand
    I was told it is the display that was causing the crappy camera resolution. Otherwise I was going to get a camera from another model.
    Feb 15 2017
    Rochester Hills, MI
    I've been looking for the solution for a while, no luck. If anyone find one, I will be very interested
    2016 RS 7 Sepang Blue, Milltek Non-Res Exhaust, AWE S-Flo 2.0 Intake, APR Stage 1, Neon Yellow Caliper, Black RS7 Performance Wheels, Escort Passport 9500ci Radar Detector with AL Priority Laser Jammer
    Veteran Member Four Rings a4android's Avatar
    Jun 08 2015
    Montreal, QC
    In my theory, you can get aftermarket video cam connected to the OEM rear camera control module.
    Maybe I will try to replace it tomorrow, if and only if it's not too cold to do that.
    Daniel Kim
    2010 A4 B8 - My first car ever!
    2012 A7 C7
    Aug 27 2018
    C7.5 A6 3.0T Prestige
    WA
    I think there may be some issues depending on your configuration? I believe cars with rear cam only are analog, and ones with side/front cameras have digital rear cameras.
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by xanmato View Post
    That's correct. 360 degree oem system is digital. Mine is analog though.
    나의 SM-G960W 의 Tapatalk에서 보냄
    Daniel Kim
    2012 A7 C7
    Mar 11 2014
    Dallas/TX
    Mine has the 360° and bird's eye.
    Nov 07 2005
    RS6, M5
    Melbourne, Australia
    I’ve had both systems in the C7/C7.5, and IMO the picture quality in the 360 degree camera setup is inferior (significantly).
    Jun 08 2015
    Montreal, QC
    So, I've changed my 2012 C7's OEM camera to cheap aftermarket one I am selling somewhere for few dollars. Everything remained OEM but the camera module itself.
    The outcome is mixed.
    The image quality is indeed better, but it's not HD class that the camera is made to. The Audi factory backs up cam controller water downs near HD imagery to 1990's S-video. Still better than 1980's image quality of the OEM camera.
    So it's not something you pay someone $$$ to do this, but a fun(?) weekend DIY everything cost under 40$.
    If you have knowledge of hooking up video wires and do not forget to keep aftermarket in-line 12v voltage regulator before splice wires, it's a 3-hour job.
    Probably, I will remove the factory OEM back up the controller and revive HD quality imagery when my own 9" folding screen c7 android system completes.
    And a piece of bad news for the 360 surround camera system - those cameras are LVDS and no, those are NOT replaceable.
    Maybe I would make an aftermarket kit replacing cameras and the controller but using OEM wires because the most challenging thing to install an aftermarket birdview kit is wiring.
    In OEM camera(left), there are Moiré pattern(in dark circle) appears due to poor optical quality of imaging sensor - you see green blurred stuffs along dark edges, and there is also a lot of pixelation due to up-scaling 320x240 camera. In retrofit camera, there is no more Moiré pattern and dynamic range of objects are better due to better aperture value lens and imaging sensor, but you can see still moderate pixelation and interlaces as the OEM controller is down scaling image. Also, I see the changes in horizontal plain due to different optics.
    Daniel Kim
    2012 A7 C7
    Dec 11 2018
    Austin, TX
    Did you loose the parking sensor view when moved to the nonOEM camera ?
    Jun 08 2015
    Montreal, QC
    Quote Originally Posted by fast_20t View Post
    Nope, that works fine. It's the camera controller(separate unit) that overlays the sensor view.
    Daniel Kim
    2012 A7 C7
    Mar 24 2015
    Arizona
    Daniel - have you tried retrofitting one of the C8/B9 camera modules/cameras in it's place? I'd be curious if brought different results....
    Veteran Member Four Rings Audisthesia's Avatar
    Aug 14 2019
    Tampa
    I would have to agree, the camera on my S6 are shit. The backup camera on my Passat is so much better, on a car that is less than 1/3 the cost. SMFH.
