Results 1 to 15 of 15
    Nov 09 2018
    nj
    Does it have Sport Diff or not? Worth it?
    So down to 2 Q5's in the quest for Camera Chase Car. 2013 and a 2015. The 15 doesnt have the sport diff as far as i can tell from the menus and window sticker and the 13 I am confused a bit.
    If memory serves me on the 13, I saw the diff showing in the menu in the individual section. Had 4 items in it and I didnt know much at the time about the sport diff or I would have taken a picture of the menu to remember.
    I was able to get the window sticker of the 13 via the vin and it doesnt clearly show the option. What it does show in the S line package section is Audi adaptive dampening suspension & audi drive select controls.
    But no exact mention of the diff itself. Is this the correct package or should I see a line about the diff?
    Nobody at the Audi dealership could tell me either way unfortunately. I do know now what to look for underneath so will look for on monday. Mechanic said it looks beefier and there will be wires coming out of it. Hoping someone here can shed some light on before that.
    So need opinions, is not having a sport diff a deal killer for the abuse i will put this car under?
    Is the non sport diff any less robust then the sport diff? Coming from US cars and trucks, usually cars without posi rears are less robust.
    Also is the performance that much better? We will chase everything from slow city driving to hauling ass with race cars.
    Thanks
    Dec 09 2018
    A 08 335i BMW and 2017 A3/ 2018 SQ5
    California
    2018 Sports differential. Biggest difference I see is the thingy on the side which reminds me of a starter, normal diffs don't have it. You could have torque vectoring done by braking also which might be what you are reading into the statements. The actual sports diff may not have appeared until 16-17 but I dont' know.
    As for you use:
    Non track, it won't matter one way or another unless you are going at it in a curvy section.
    I was able to drive a Q5 loaner for a day without the sport diff and there is a very noticeable difference between the two. This was not under hard driving at all on either of the two as they are both under the break in period. I can feel the sport differential helping the car turn in quicker and solidly. Part of that could be because of the suspension being under Dynamic also but I've just started to use the Individual mode and can notice it also.
    If chasing race cars you probably were going to have to change things anyway to keep up so I've no idea if it would make a difference to you.
    BTW my analysis is worth exactly nothing but it is what I've noticed in the last 45 days.
    Nov 27 2017
    Los Angeles, CA
    Sport diff was not an available option on 2009-2017 Q5/SQ5 models.
    Nov 27 2017
    Los Angeles, CA
    Also, for what it's worth, with good quality 295 tires and lightweight wheels I have a really hard time getting close to the limits of traction, whether accelerating, turning, or braking. The S4 guys need sport diff because they are not running tires this wide and they get more power spikes with the DSG transmission.
    Nov 09 2018
    nj
    No man I appreciate all help. Thanks for posting the picture too. Now I really know what Im looking for. Thanks!
    Nov 09 2018
    nj
    Thanks for the help. Are you 100% sure on that? Dealer and a few others have said different. Thanks
    Nov 09 2018
    nj
    Quote Originally Posted by stapan View Post
    Are you 100% sure on that? A dealership and a few others have said different. Thanks
    Veteran Member Three Rings Whinny SQ5's Avatar
    Sep 03 2017
    2001 Mazda Miata SE // 2014 S5 Prestige // 2022 TTRS Heritage Edition
    Colorado
    Agree. I'm pretty positive the sport diff became available with the new gen (B9) SQ5.
    Sent from my SM-G955U1 using Audizine mobile app
    SQ5 - Mythos Black | Black Optics | Black & Magma Red | Carbon Atlas | B&O | VFF 102s | Variant Sena | 034 | AWE | ECS | IE | JXB | BFI | Sparco
    TT RS - Heritage Edition | Alpine White | Ocean Blue Interior | SM-10RS | RSe10s | 034 | Unitronic | JXB | BFI
    Dec 22 2009
    2008 A4 Avant
    Bellevue, WA
    There is no sport diff. Look at the brochures I previously linked you to. There are no “secret” options. It’s all there. Your dealer is probably confusing the active suspension with the sport diff. Who knows.
    http://www.auto-brochures.com/audi.html
    See s4 from 2013: lists sports differential on page 40
    http://www.auto-brochures.com/makes/...Sport_2013.pdf
    Q5 from 2013. No sport diff.
    http://www.auto-brochures.com/makes/...%20Q5_2013.pdf
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    sport diff became available as an option starting with the B9.
    If you ever decide to get a B9 then definitely get the sport diff
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
    Sep 07 2018
    Colorado
    Quote Originally Posted by PNW Avant View Post
    Holy damn this website is awesome!
    Bookmarked!
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Not that additional reinforcement is needed, but there is no sport differential on the B8.5 platform. Honestly, given the driving parameters you've described in other threads - center of gravity and weight load/distribution - torque vectoring between the rear wheels would be way low on the list of things from which you'd benefit.
    If you really need to keep up with speeding vehicles through turns, you might want to consider an S4 or perhaps an A6 or A7 of the same time period.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Nov 09 2018
    nj
    Thank you all. Appreciate the help. No sport diff on these years. Thanks!
    Oct 04 2017
    Toronto, Canada
    I think the Audi SQ5 Plus has it, but it's in Australia or New Zealand.
    Dec 09 2018
    California
    I keep forgetting that I ended up with Dynamic steering, so ignore what I said.
