Results 1 to 11 of 11
    Dec 01 2018
    Asheville, NC
    255/35/R19 vs 265/30/R19 on 19x9.5 et 35?
    Just ordered some new rims for my car today, got some 19x9.5 Vorsteiner VFF-108s. I'm having some trouble deciding on what size tire to get. I can deal with a little stretch, but overall not a huge fan of the look.
    I'm getting some Continental DWS06's since I will be in an area with a moderate amount of snow, but don't want to go with a summer + winter setup just yet.
    Anybody got some good opinions they would care to share about 255/35/R19 vs 265/30/R19 on 19x9.5? Pictures would be helpful as well if anyone has some good ones.
    Leaning towards 255/35s, but if there's anything I should know in order to help make the decision let me know.
    Thanks
    Edit: Car is stock otherwise.
    Jul 02 2004
    2010AudiS4
    Farmindale, NY
    I have vmr 710 19x9.5 with 255/35 Michelin pilot sport a/s. Good fit, some tire brands run wide/narrow. I didn't want to worry about rub.
    Veteran Member Three Rings 03redgti's Avatar
    Dec 20 2010
    lancaster, pa
    def go with the 255 35 the dws -06 run wide and dont stretch that well. Im running the same spec wheels and with my old blizzaks it didnt rub at all..when i installed my dsw 06 it was rub city. had to raise all four corners.
    2013 S4 | Glacier White | Chestnut Brown Interior 1/13 | Sport Diff | IE Stage 2 | IE Intake | JHM V2 Test Pipes | PLM V2 HE | Custom Magnaflow Exhaust | Solo-Werks S1 | Rohana RF-2 20x10 square | Continental DWS |
    Senior Member Three Rings Marlon177's Avatar
    Nov 04 2010
    2016 CLA250 4Matic
    NY/South Jersey
    I have pilot sport A/S3+ 255/19/35, DWS06 will run more narrow than this, I also had 245/19/35 DSW06 on my 19x9.5 before changing into A/3+.
    You might also wanna include your suspension setup.
    A/S3+ 255/19/35
    DWS06 245/19/35
    Junior Member Two Rings
    Jul 27 2011
    Richmond, VA Area
    I have 265 35 19 Michelin Pilot Sport A/S 3+
    https://www.audizine.com/gallery/dat...eway_Angle.jpg
    Stock springs koni shock/struts. The combination serves my DD style.
    Oct 19 2008
    Ontario%20Canada
    I don't like the stretched look either. I have some 19x9.5s (et40) on order for the Spring as well, and am trying to decide between taking a gamble on some 265/35 tires or playing it safe with standard 255/35. I'd MUCH prefer the extra meat, but I'll also be installing OE Sport springs (and Koni yellows) in the Spring as well. So.
    There's a giant sticky thread on this topic... I suggest you check it out. You can even search in that particular thread.
    2011 S4 - Ibis White - 3 pedals - daily driver
    2.95 PR, EPL software, Merc Racing HX, Eurocode inserts, Koni Yellows, H&R OE Sports, beefy RSB, homebrew CR15, stainless brake & clutch lines, custom FBSW by FlyDesigns, P3 Multi Gauge
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Quote Originally Posted by 03redgti View Post
    +1 on the 255/35/R19 with the Blizzaks when it comes to a winter setup. Since ownership of the car back in January of '17, I've had those puppies on the car each winter...and two very harsh winters later, they've still got ample meat on them, with no issues otherwise. And I ain't no granny behind the wheel neither!
    I run the same 255/35/R19 spec with my Pirelli P Zero's as my summer setup, but will - without a doubt - go for the Michelin Pilot Super Sport's/Michelin Pilot Super Sport 4S's when I wear the tread down as they're just that much more superior in every regard when it comes to a performance tire.
    I'm stock otherwise as well, OP - good luck!
    Jul 21 2004
    South Florida
    Here is 275/30/19 on a 19x9.5
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Oct 19 2008
    Ontario%20Canada
    Quote Originally Posted by bhvrdr View Post
    Ooooh, now THAT'S what I like to see!! You're obvs stock height, eh? What offset are the wheels? If you shaved an inch off the ride height, is there any doubt you'd have some serious rubbing issues?
    Jul 21 2004
    South Florida
    Quote Originally Posted by wes8398 View Post
    On an S5 there is TONS of room. With my offsets of et33 i'd have zero issue with rubbing at any height but you all need different offsets. You guys would have to be at more like et45 and make certain you can clear both inside and outside (on strut and on fender). Its been done though. The eurocode car I believe ran 275 on wide track tires too
    mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    Quote Originally Posted by Algorithm View Post
    Thanks
    with that offset you're going to need to get the 255's. i know you're not lowered, but people that are sometimes run into issues with 255s with that offset. i wouldnt go any wider
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
