Results 1 to 22 of 22
    Senior Member Three Rings KAMP's Avatar
    Sep 18 2018
    2004 Nissan Murano SE AWD
    Oil reading in MMI vs Dipstick..
    Hey guys, did my first oil change after purchasing my 2016 in December. Used the Liqui Moly kit + dipstick and took it for a quick drive (already feel it running smoother). Anyways, I parked the car in the garage and waited the two minutes as suggested. In the MMI the reading shows MAX but my dipstick is currently sitting at the second set of dots up top, under MAX (I’m using the genuine Audi/VW dipstick).
    Either way, I know I have to wait longer for a more accurate reading on the dipstick.. BUT is it okay for the MMI to sit fully at MAX?.. or would that indicate too much? I put in just over 6.5 quarts in and wanted to make sure its not somehow overfilled. Thanks.
    Mar 28 2016
    I would rely on the dipstick for fine measurement. I never use the MMI now that I have the dipstick. Can't beat the accuracy of a dipstick.
    Established Member Two Rings JeffSQuattro's Avatar
    Nov 28 2016
    The capacity for oil is usually in the 7-7.2 quart range. I wouldn’t worry with the max reading in mmi as you’re using the dipstick.
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    Both the MMI reading and physical dipstick pertain to the TOP QUART of oil, not the "maximum" and "minimum" level of ALL the quarts of oil within your engine.
    #themoreyouknow.
    Either way, oil consumption's not out of the norm with our vehicles. I'd keep an eye on it, but wouldn't fret too-too much.
    Ultimately, if you added "too much", your car would scream at you - letting you know you overfilled.
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by Envy187 View Post
    #themoreyouknow.
    Well said. I didnt know it was the top quart. Great to know.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Sep 18 2018
    #themoreyouknow.
    That is what I was thinking but thought I’d double check with you guys here. Thanks either way. I put in probably closer to 6.75 quarts, so I have about a quarter left in case I need to add later. Is anyone usually filling in all 7 quarts? I used car ramps, so I’m not sure how much was left in the pan.
    Also, the car’s been sitting for a good hour now, so I’ll recheck either way. I know best readings are after an entire night but at least I’ll have a ballpark of where it’s at. Oh and I usually don’t like to fill my cars to the top quart/maximum, just to be on the safe side. Anyways, here is what I was seeing earlier...
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    If anything the dipstick shows you are not completely filled , if you are using correct dipstick.oil level should be up to max line when you check oil after car has been sitting overnight.MY Audi dipstick had no holes in it.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Oct 19 2008
    Ontario%20Canada
    ...you can feel a 2016 running smoother because of an oil change? Man, that's impressive... ;)
    Sep 18 2018
    Quote Originally Posted by jygesq View Post
    I am using the correct dipstick. I just checked the level again after the car set for numerous hours in the garage. It does show slightly higher than the pic posted.. but not yet at “Max.” Either way, I feel that it has a sufficient amount of oil in it. If need be, I’ll add more in a day or two.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    IMHO, using the dipstick, any level in the widened center portion or above is fine, My cars never showed the level to be at MAX, even after oil change. When you do an oil change, you can never remove all the oil. How much old oil you actually get out will determine where the initial oil level will be. I remember the 4.2 V8 in the B6 S4 had something like 13 qts of oil ,But only 8 or 10 qts could be removed with the rest of the oil remaining in the oil galleys. Better to be a little under filled than over filled. If you are really anal about it, top it off after you drive the car for a few days.
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    I just did my oil with an extractor. It pulled out around 7 quarts of oil...which was concerning because I was in a hurry and busy last time and had a shop do a synthetic with it 5,000 miles ago and was expecting some oil to burn. At any rate...I put 7 quarts back in and my MMI was about 3/4th's of the way to "Max". I know in the past when I changed my oil it would read "max" after fill up. My best guess is there is some level of error with the MMI.
    I may look into a dipstick at some point but I've been lazy and also putting precedence on things that make my car go fast.
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Quote Originally Posted by BDP View Post
    I also use an extractor and it will remove 6.8 liters (7.185 quarts) of oil. I then fill with 7.25 quarts. I change it every 5000 miles and it only uses around two ounces during that time and mileage. I'd say that's pretty good.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Mar 05 2016
    Quote Originally Posted by KAMP View Post
    The MMI measurement indicates by slice of 1/4 quart. Let say your little over the 3/4, your MMI will show max. I have done the test and came to the conclusion, always rely on my dispstick for accuracy. Just make sure you have the right dipstick. I have the exact same dipstick, if you measure the lenght, I can confirm.
    By the way, if you over fill the MMI will pop a message warning ‘please reduce oil level’
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Aug 22 2014
    bloomfield,ct
    I stand corrected, my dipstick does have holes on it. All my oil changes are done by dealer ( Audi cares) my oil level is at the max line.Dealer use. an extractor to change oil.. if you level does not quite reach the max line, you should not be concerned , it is not too low nor too high in the photo you show
    Jul 30 2012
    2004 A4 6M Avant, 2013 S4 6M, 2016 GMC Acadia
    Monmouth County NJ
    On my B8 S4 I use an extractor to do 5000 mile (half of recommend) oil changes and take it to a shop for the 10,000 mile changes. So it gets and oil change every 5000 miles. My question is that I am getting way less oil out with my Schwaben hand pump extractor. I only get about 4 quarts out. I can't figure out why. I go down the dip sick hole and the extractor hose stops at a what seem like the full depth. The depth of the hose is 1 and a half inches deeper than the length of the dip stick. Does anyone have any thoughts on this? I pump an additional 2-3 minutes after the air bubbling noise starts and get about an additional quart during that period. I always have a warmed up engine, not hot.
    Thanks
    2013 S4 6MT P+ Black 165K.
    2018 VW Golf Sportwagon 1.8T 5MT 77K.
    2016 GMC Acadia 145K
    2004 A4 3.0 6MT Avant Atlas Grey 285K - SOLD.
    Jul 05 2015
    Lower Hudson Valley
    Quote Originally Posted by Charlie B View Post
    Thanks
    Is the car level? Did you check the oil level before you extracted?
    Jul 30 2012
    Monmouth County NJ
    Yes car level and oil was in-between Min and Max before I started.
    After I posted this question I read a few other discussions. People talked about having to push past a stopping point to get to the correct depth. Some people talked about not having any issues. I typically use the fatter hose supplied with the Schwaben extractor because its faster. But this time I tried the thinner hose hoping that it would fit in a smaller clearance places. So I tried to jam the thinner tube down farther past the usually stopping point which I was able to do and I felt it going into the pan. Problem was that It was a bitch getting it out. I really had to pull hard and when I got it out it was bent a little and had a small kink into tube. So Im not going to do that any more. I wonder if some cars have a slightly different build where the dip stick ends and there is an engine part that stops at a slightly different resting point. Either way I don't think I can find a way around this which is a bummer because I love the principal of the extractor.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Well - Best practice for me with topsider - is to use the dipstick as the length for marking the tube - Once I hit that mark, I let it suck oil until it starts to gurgle - pump some more for a few - THEN pump it up good, and SLOWLY push the tube a little further in - typically pull what seems like another good bit (1/2 qt?) that way.
    If you are getting it caught - it's probably a little to far in - and small tube most likely helps as it should soften a little more for flexibility...
    I never measured but the topsider is 8 quarts and was always mostly full - so guessing I got most of it - not really a huge deal if you missed a little anyways....
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Jul 30 2012
    Monmouth County NJ
    Thanks that's good advice. Ill try and push a little farther when the tube is softer. Happy miles.
    Veteran Member Three Rings AerotusX's Avatar
    Mar 24 2014
    Thanks
    Similar to you, I also felt strange that I can only extract 5L when I did my first oil change with MityVac. I assumed the rest of the oil was burnt away. I added 7L new oil and the measurement was good.
    2015 Audi S4 Prestige | DSG | Moonlight Blue Metallic | Black/Magma Red Fine Nappa | Sports Differential | ADS | Aluminum/Black Wood Inlays | 19x9.5 VMR V710 | XPEL PPF | 3M Crystalline Tint | KW H.A.S. | Vag-Com | CR-15 | Alu-Kreuz | APR Stage II | APR CPS | RS4 Grill | Eurocode Sways | Eurocode Inserts | ECS TCU
    Mar 28 2016
    Quote Originally Posted by AerotusX View Post
    If you were 2L down you should have been adding between oil changes. I would also think that the MMI should have given you a low oil warning at that level.
    I use an oil extractor as well, but don't measure what comes out. I fill it to the max line on the dipstick and check the oil periodically. I've never yet had to add between a change (I run 6-7k OCI).
    Mar 24 2014
    Quote Originally Posted by hilmar2k View Post
    You're right and that's what was strange, I didn't get any low oil warning light. The only reason I knew how much came out was because I transferred the oil from MityVac back into the 5L bottle for disposal. I still had the two 1L empty bottle with no oil left in the MityVac.
