So I have searched, and am pretty familiar with what could be causing my clutch pedal to not return fully, or stay mostly on the floor. Just looking for some fresh input , especially as my whole clutch setup is new.
~5k miles ago or so. Slave failed. Replaced everything with a TTV B7 FW, B7 RS4 PP , JHM stage3 Disk, Duralast slave, stainless line. New reservoir as the original was corroding apart, but did NOT replace the master( I presume its OEM still). Everything worked out perfectly and operated with no issues.
For the first time this week, on a cold start the pedal began to not fully return after I reversed out. The clutch starts to engage in the same scenarios and will drag even with the pedal almost fully down, until I recycle it essentially then the pedal is back to normal. It sounds like the slave starts to back out after holding the pedal down. When it sticks to the floor it ISNT fully dropping, but staying an inch or so up. The clutch actually operates just fine when it is doing that, even though I only have to press it that tiny inch to disengage. Seems to be only occurring at stops or low speeds. I can pull the pedal back up and its springs back to normal. I’m assuming this is a slave or master issue as everything else seems to work ok. What are the chances this could be my master, and is it even worth replacing the master first? If the master is allowing fluid by I imagine this is what would be happening right?
