Results 1 to 8 of 8
    Active Member Two Rings dyln's Avatar
    Jun 17 2018
    Connecticut
    Best front control arms
    Just got my cv joints done at a shop and they said my bushings are shot and I need all new control arms. I’m not paying for oem parts and I’d rather get something aftermarket. I’ve heard mixed reviews about the 034 kit and if I’m going to be spending the money I want something that’ll last and handle better. What would be the best ones to buy? I need all 8 arms
    Aug 09 2012
    Sylvania OH
    I have the Meyle kit, which includes tie rods and sway bar end links. I’ve only had it a few k miles, but no problems so far.
    Veteran Member Three Rings griga's Avatar
    Jun 30 2017
    Central Jersey
    Silver 2008 A4 2.0T | Thermal R&D Exhaust | Cupra R Lip | 034 Mounts | Peelers w/ Spacers | Custom Intake | Paint Matched Reflectors | B5 Perches |
    IG: https://www.instagram.com/rigadesigns/
    Jun 17 2013
    jersey city nj
    @ Lemforder brand. they are oem for Audi. Some mite say they are made in China. But they are made within oem specs. Some even come with the audi rings grinded off
    Veteran Member Four Rings Avant4me's Avatar
    Aug 09 2011
    NOVA
    Meyle hd and 034 here.
    Durability is all about proper installation and having them tightened at ride height.
    ~2007 DTM A4 S-Line Avant, 6MT, Stasis cat back, RAI downpipe, JHM Stage2 93, JHM HPFP, HFC, APR snub mount, 034M SD Motor mounts, RS4 RSB, VMR 708 19x8.5 ET35 245/35/19, B5 perches, NEUSPEED sport springs ~
    Oct 28 2014
    ON
    Lemforder is genuine, you can get a great deal from rockauto if you piece the kit yourself.
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by Avant4me View Post
    This right here.
    Torquing the lowers down on an alignment rack and knowing what angle (distance from the top) the top arms should be when installing them really helps with how long they last.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    The best control arm kit is the one that is installed correctly.
    CONTROL ARM KIT (A4 S4 RS4 B7, 12-PIECE, MEYLE HD)
    This upgraded, 12-piece OEM control arm kit includes all eight (8) front control arms, all metal tie rod ends, sway bar links, and all hardware needed to complete the control arm job on your 2005.5-2008 Audi A4/S4/RS4 B7. The quality of this kit greatly exceeds Audi OEM specs to improve durability and longevity. Your car will handle like new or even better. Designed by Meyle in Germany. Heavy-duty, 4-year warranty.
    This is the latest, greatly improved B7 chassis specific control arm kit. Do not purchase a B6 chassis kit for a B7 chassis car. Currently, Meyle HD is the only company that makes a control arm kit for the B7 model Audis.
    This control arm kit Includes:
    • 2 x 8E0407151R Front Lower Straight Control Arms
    • 1 x 8E0407693AL Front Lower Left Curved Control Arm
    • 1 x 8E0407694AL Front Lower Right Curved Control Arm
    • 1 x 8E0407505P Front Upper Left Control Arm
    • 1 x 8E0407506P Front Upper Right Control Arm
    • 1 x 8E0407509P Rear Upper Left Control Arm
    • 1 x 8E0407510P Rear Upper Right Control Arm
    • 2 x 4F0419811D Front Outer Tie Rod Ends
    • 1 x 8E0411317 Left Sway Bar Link
    • 1 x 8E0411318 Right Sway Bar Link
    • Complete Installation Hardware Kit
