The motivation behind this thread is seeing repeated posts about the same issues over and over.
The goal is to provide an index of the most common problems, how to effectively diagnose and differentiate between them, and offer advice on how to remedy them
For now, I want to generate a list of the problems we have, and later I can elaborate on their symptoms and solutions. Please help me add to the list!
Things that are somewhat ubiquitous among all engine I don't want to include (spark plugs etc.)
FORMAT:
will be grouped by symptoms, causes will be listed below. Since causes will be repeated, causes will be listed below the list along with in depth descriptions, further diagnostics, and solutions.
Common Symptoms
clunking especially at low speeds and over bumps
Torn control arm bushings
misfires and decreased performance
Catalytic converter failure
Supercharger IC failure/leak
coolant loss
PCV failure
Thermostat failure
Water pump failure
Crossover pipe leak
Coolant reservoir cap failure
Overheating issues
Thermostat failure
Water pump failure
B8.5 Electric Steering issues: Notchy and vague steering input/output, wandering on road
Faulty steering rack
Faulty intermediate shaft
Electronic issues
Diagnosing and repairing common problems
PCV failure
- coolant loss at an increasing rate, usually invisible and undetectable by pressure test
- coolant in oil
- excessive steam in exhaust
- milkshake under oil cap
- Suction through oil fill cap
- rough start especially after car rests for short periods after driving
IC failure
- coolant loss
- misfires in cylinder 3 and/or 6
- rough starts
- fouling of spark plug 3/6
- Change in exhaust tone (usually muffled and deepened)
- misfires in cylinders of one bank (corresponding to the side of failed CAT) especially under high loads
- white residue around exhaust exists
- loss in power
- possible catalytic converter codes
Thermostat failure
- engine overheating
- fans running when engine off or running excessively hard all the time
Water pump failure
Control arm bushings failure
Wheel bearing failure
Crank pulley failure
