Results 1 to 23 of 23
    Jan 31 2018
    2005LK55%2C%202016%20Honda%20Pilot
    Dallas TX
    Best tire pressure gauge
    I need to start watching my tire pressures better but want a decent and easy to use gauge. Any recs?
    2015 CPO S5 Daytona Gray
    Mar 28 2016
    They are all pretty accurate. Get an inexpensive digital gauge and you'll be fine.
    EDIT: I've had good luck with Tekton stuff, so here's one:
    https://www.amazon.com/TEKTON-5941-D...ressure+gauges
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Four Rings Envy187's Avatar
    Feb 13 2018
    For years, I was content with the "pencil/pen" tire pressure gauge that is available, but I recently went ahead and purchased the one hilmar2k provided today.
    #thefutureisnow.
    Mar 28 2016
    I have a compressor in my garage, so I actually just use this to both fill and check.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Senior Member Two Rings BigKeshy's Avatar
    Jun 01 2017
    West Orange, NJ
    If you're into analog, I've had this one for a few years: https://www.amazon.com/gp/product/B072KRX43Y/
    It'll hold the needle in place after pulling it off the valve stem so you don't lose the reading right away. Only thing you need to take care of is to make sure you hit the vent release (reset to 0psi) when you're putting the gauge back into storage so you don't wear out the spring and cause the calibration to go awry. Otherwise, super dependable.
    2013 B8.5 S4 MT
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    hey along the same lines as this topic - I really miss not knowing the exact pressure, just something I've had in all my jeeps, and now it seems like no one is doing it anymore. Has anyone had any luck or positive things to say about bluetooth gauge caps?
    https://www.amazon.com/Pressure-Moni...KZ8DKHSFZ&th=1
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
    Mar 28 2016
    Quote Originally Posted by rcz22 View Post
    My worry with those is that the valve is always open, so you are relying on the seal between the cap and the stem. Also, if they are heavy enough, they might necessitate a wheel balance.
    Mar 05 2016
    https://www.amazon.com/gp/product/B0...iglink20461-20
    Very accurate, been 4 yrs and still running on original batteries.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Jul 05 2015
    Lower Hudson Valley
    Mar 05 2016
    Quote Originally Posted by evanb View Post
    The problem with these model is, after a while, the lock doesn't lock properly and start leaking air.
    Veteran Member Four Rings kjeeper10's Avatar
    Dec 07 2017
    2007 Jeep Wrangler JK
    Quote Originally Posted by BigKeshy View Post
    I like !!
    2015 Daytona S5 - Madico Ceramic Tint 35/20 - 6 Speed - Mods - Sprintbooster V3 - APR Stage II - Dual Pulley - CPS Cooler - Eurocode ST Shifter - EuroImpulse weighted knob - USP SS Clutch Line - 034 SD Engine Mounts - 034 Trans Mount Insert - 034 rear SB - CR-15 - ORT Coilovers - SPC Front CA’s - IE Non Res Downpipes - AWE touring w/ 102 tips - CTS intake - ECS Streat Shield - Deval CF Splwitter/Rear Valance - Signature SV901 Forged 19x10.5 wheels - 275/35 Mich PS4S Tires.
    Senior Member Three Rings MME1122's Avatar
    Mar 26 2016
    2011 Jeep Liberty
    I have a similar style one that stays in the car. I had an electronic one but every time I needed it the batteries were dead. So now that one stays at home in my toolbox, where I can get new batteries if needed. Analog is best when you're on the road.
    Aug 25 2013
    florida
    Quote Originally Posted by doughboy17 View Post
    the first tire gauge i had was a digital accutire. then i had an analog short accu-gage https://www.amazon.com/gp/product/B00070KA5I, which got dropped a few times. then i've been using this long neck accu-gage https://www.amazon.com/gp/product/B0006O2RR4. the long neck holds the reading more accurately and is more maneuverable. i've had the long neck since 2012, it's the most accurate when i cross check after services or against other analog gauges and it still my go to in the garage. in the car, i keep the short neck.
    Quote Originally Posted by hilmar2k View Post
    since july 2017, i've been running a set of valve open bluetooth tpms readers on my other vehicle and have put on 26k miles, which isn't a long duration nor distance. they don't seem to sell them anymore https://www.amazon.com/gp/product/B015QTPJ0K but it's saved my ass at least 3 times on 2 different tires. 2 nails and 1 "thorn from a tree". they look stupid as hell and seems like they might bend rubber valve stems at highway speeds. tire stores do not want to balance with them on. i haven't had any noticeable issues.
    i've had the same concerns as you and they can be a pain in the ass to remove and reinstall without leaking too much air out of the tires. but since i've own the bluetooth tpms, it's survived weekly (sometimes semi-weekly) conveyor belt car washes (full body contact y0!) for 1 year and a cat 1 hurricane irma. i've driven with them out of state a few times (9+ hours each way) and across the state many times (5+hours each way) still on my original set of batteries and would not hesitate to buy another set when the time comes. the cold and hot readings can be anywhere from 1-2 psi difference compared to my long neck analog accu-gage. for a commuter car, i think they can be a reliable and helpful system. on a weekend or hoon car, it's probably more hassle than it's worth. i mean, if you are really utilizing your sport diff with crown gear at 11/10ths, this is not for you on the s4, i just stayed with the stock tpms system.
    2014 sfeux p+ 6mt bo nav w/o sd
    Dec 19 2004
    I have the Audi one, a racing one and a few digital ones. They all read the same. So accuracy is good regardless of which you pick:
    https://www.amazon.com/Genuine-Audi-.../dp/B006U1WHHC
    2011 B8 S4 | EPL Stage 2 | KW H.A.S. | APR Stage 1 & 2 Carbonio Intake | Borla Exhaust | Eurocode Alu Kreuz | Eurocode ÜSS Stabilizer Bars and End Links | 034 Motorsport Trans Mount Insert | Spulen Rear Differential Mount | Hartman RS 4 Wheels
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    If you have a compressor I recommend the JACO FlowPro Digital Tire Inflator Gauge - 200 PSI. you can get it on amazon, love this filler and gauge wish I had it years ago. As for just a gauge I have cheap digital I keep in the Mrs truck and it works great. I have compared it to my Longacre precision race gauge and its within 1/4lb. Seems these low cost digital units are pretty accurate.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Senior Member Three Rings Dash's Avatar
    Jun 07 2012
    St. Louis
    My other car is a jeep that I wheel a lot... and have to air down before hitting the trails... Will this allow me to quickly release air and read pressure? So basically, can I put it on the tire not hooked up to a compressor, hit the fill lever and release air, then release the lever and see the PSI?
    Because, if so, I need this in my life.
    Mar 28 2016
    Quote Originally Posted by Dash View Post
    Yes, though you use a air release button, not the lever.
    Jun 07 2012
    St. Louis
    Ordered!
    Junior Member One Ring
    Feb 01 2018
    MN
    I've had the electronic ones but the batteries are always an issue. Now I am using a compressor fed analog inflator/deflator/gauge similar to the electronic one previously listed but no need for batteries.
    https://www.griotsgarage.com/product...hoClecQAvD_BwE
    2014 Black S4, B & O, Sports Diff, 6MT
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I've used the same two of these in my cars for over 10 years, and never replaced a battery yet, despite being left in the cars year round.
    https://www.shopbmwusa.com/PRODUCT/2...PRESSURE-GAUGE
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Dec 07 2017
    Get the Teraflex tire deflators. Cheap, They all screw together, and have a key chain loop. Fairly quick at letting air out too.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I prefer the old fashioned analog gauge type instrument that holds the tire pressure reading until you release it.
    I have several. They all seem to read within 2 psi of each other. Who knows what absolute is? My favorite is an old VDO, made in Germany. I don't think they are still in production, though. Motometer, also a German company, makes an identical model. It is OEM for Porsche, but you can get one without the Porsche logo from Motometer vendors for about $35 or so.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
