Results 1 to 6 of 6
    Jan 30 2019
    London
    2014 audi s3 8v vehicle electronic malfunction shift to p ...
    Hi
    I have a 2014 Audi S3 8V
    Recently I had been getting this random warning on the dash vehicle electronic malfunction shift to P and visit workshop
    The car ran and drove perfectly fine still I continued to drive still
    One day the car cut out
    Now is showing the same fault plus all electric faults such as
    Hill start fault
    Esc error
    Parking brake fault
    Etc etc
    Have taken it into Audi who have advised the ECU is faulty
    Any suggestions as the car hasn’t even dne 30K miles and ecu has gone also very rare for ecu to mess up
    Thanks
    Junior Member Two Rings
    Mar 04 2018
    I had a similar problem. They replaced the ECU and gateway. ~3k for parts that should never fail in my opinion. Since then I've had other electrical issues pop up... Good luck
    Sent from my Pixel 2 XL using Audizine mobile app
    Jan 30 2019
    London
    Quote Originally Posted by speetol View Post
    When they replaced ecu did they fix the fault -
    Now my car is jus starting and cutting out showing all these electric faults on dash
    Cannot believe ecu failed
    Mar 04 2018
    Yeah. They did the gateway first but there was still issues, new ecu fixed everything.
    The service supervisor said he's only ever seen something similar happen when someone jumped there car with the leads backwards. I don't know about you but I can confidently say I did not do that.
    I should mention this is a 15 a3 with 50k miles.
    Apr 24 2019
    Denmark
    Quote Originally Posted by Sab_s3 View Post
    Hi Sab_s3,
    I'm currently having the same issues with my A3 8v 1.8 TFSI quattro, did you manage to get this sorted or figure out what needed to be fixed?
    Best regards
    Jan 30 2019
    London
    Quote Originally Posted by lower View Post
    Hi Sab_s3,
    Best regards
    Hi not fixed yet will be getting booked into Audi soon
