I went through the B7 rear calipers this weekend and wanted to pass on a tip on reinstalling the emergency brake mechanisms snap ring. One went together no problem. This is of course using the special 90° long reach snap ring pliers. The other caliper was a PITA. It would kind of go in but then snap back out. It turns out the mechanism was sitting a tiny bit high in the snap ring groove. The spring that I needed to compress to get it down in the bore is really beefy and there is not a lot of room to work. I tried using a drill press to push the spring down as I put the snap ring in, I got close but never got it in right.
Plan B. It took the part back out and noticed that the retaining tabs for the spring hat were a bit bent and the hat was getting pushed upwards. That would explain not being able to get the snap ring in.
The fix: I compressed the mechanism in a vice using a socket and peaned the tabs a little to tighten the assembly up (see red arrows). Five minutes of work and the snap ring was a cinch to get back in.
Tabs:
90° snap ring pliers: - Motion Pro 08-0279 Master Cylinder Snap Ring Plier
Amazon Link: https://www.amazon.com/Motion-Pro-08.../dp/B000WJJ4U6
Quick tip: I slid the boot over the piston and installed them at the same time. Once the piston was in I hit the seal with compressed air and blew it up a bit. That moved it up the piston and made pushing the piston in the rest of the way a piece of cake.
Glad that's done!
