Originally Posted by
BMWManiac
Here is the thing....the piggybacks are doing 5-8% additional boost, correct? The MAf signal is being manipulated to account for more air and for the ECU to add more fuel. You are asking the boost controller to now manipulate the wastegate pressure, without manipulating the MAF. What I think would happen, is that the MAF/ECU will now throw a code because the amount of air being anticipated will go beyond the thresholds, therefore MIL.
You could always try this and then everyone would stop buying piggybacks and tunes and just get the eboost2 :-)
No, not 5-8% additional.....I'm talking 8 psi additional. I think that's what Neuspeed has and I know there are a bunch of guys using them on the forum. MAF just measures air. So if more boost produces more air, the MAF will see it and the fuel will be adjusted to keep the ratios where they should be (actually, isn't that the function of the O2 sensor for the most part?) But of course everything has limitations, so if the threshold is truly exceeded, something would definitely happen. In my older turbo cars, it would basically shut the boost down momentarily (due to an overboost conditions, not a really a good thing obviously), so it was important to make sure the boost controller stayed within the limitations of the fuel system.
On my old HKS EVC boost controller, I had push-button control of the boost level. I left one button set for stock boost level and had the other two buttons set up as "mid" and "high" boost. And then there was a circular dial that was flush with the face of the unit. If you push on the button, it popped out and allowed you to dial in whatever boost level you wanted. That's where you needed to be careful. I could always get a little more maximum boost in the cold winter air (good density) without hitting an overboost conditions compared to hot summer days. Having this control was awesome in a unit no bigger than a radar detector.
A true software tune is definitely a better option, but I can see a boost controller working at least as well as a piggyback tune because it should do just about the same exact thing.
