At my last oil change (93K miles), the tech noted that my serpentine belt is starting to wear. I've already replaced the front supercharger belt when i did the single pulley upgrade.
Audi maintenance schedule says to check/replace (ribbed V belt) if neccess at 75K miles. Is that the same as serpentine belt?
Curious - for those with 3.0T, what has been your experience with replacement mileage for that belt?
Looks like spark plugs are to be changed at 115K, once you've done the first replacement at 55K so i'm prob good for a while there.
Thanks-
