Originally Posted by
morph2k4
What is illumination? Is that the ring lighting up? How can that run off a single conductor? What is a test light?
As for the fuses, the cable is purple and says "3" on it. I need to compare that to what the cigarette lighter connects to on the fuse box?
Thank you!
There is an illumination circuit. It’s what turns on the lights on the buttons when you turn on your headlights. In the case of the cigarette lighter, yes, it should turn on the light ring when the headlights are turned on.
It doesn’t run off a single conductor. There are two power lines. One to power the outlet, and another for the light. Both share the third line, which is ground. That completes the circuit.
A test light looks like a clear pencil with an ice pick on one end and a wire with an aligator clip on the other. You clip the wire to a ground source. Then you probe the wire with the pick end. If the wire you are testing is a live power wire, the lightbulb in the center of the test light will turn on.
If your fuse has a 3 on it, it’s a 3A fuse. I’m pretty sure that the smallest fuse on this car is 5A. That’s one of the many reasons I don’t tap off an existing circuit. There are blank spaces in the fuse panel on the left side of the dash. You can get a wire that goes into a blank spot from Audi and then add the appropriate fuse. You would hen connect your red wire to the new wire from the fuse panel. Then it’s isolated from the rest of the car and the fuse is easily accessible. In that scenario you’d want to be rid of the inline fuse that’s in your kit. You don’t want two fuses on the same wire.
Honestly, I’d recommend you either add a circuit to a blank spot in the fuse panel or use a fuse tap. I personally don’t like fuse taps, but it’s definitely the easier way to go. And less likely to cause a problem for someone that isn’t familiar with wiring.
Fresh.S4
fairly certain that isnt an ILLUM wire (that should feed off the 12v)
my guess is its a switched 12v (meaning it goes on/off with the ignition)
but yes best way is just to test.
use a volt meter and go red/ brown then test grey/brown
Incorrect. Any lights that turn on with the headlights are part of the illumination circuit. See above.
And I’d still recommend a test light over a voltmeter or multimeter. Connect the wrong wires on the wrong multimeter setting and you could potentially break something. If you actually know how to use a multimeter correctly then it’s a good option. But for finding a power source, a test light is still the simplest and most foolproof way to go.
