Results 1 to 8 of 8
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    p130a00 + p030600 cel flashing and EPC light on
    So this morning I started my car and the engine light was flashing and it went off and the EPC light stayed on. Car had a very rough idle and felt like it was going to stall. Once the engine warmed up I turned off the car and turned it back on and the EPC light went away and it drove fine. Drove it to my shop and they pulled this with their snapon reader. P130a00 and p030600. Anyone else have this issue or know where I should start? Tia.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Feb 20 2018
    Italy
    Quote Originally Posted by ichi d View Post
    Hi
    On what cylinder? Sparks or coils problem i think
    Rs6 Performance, Catless Downpipes, Straight Exhaust, Loba High Fuel Pumps, Forge Intercooler, Arma Intake ....
    May 10 2013
    Toronto,ON
    Cylinder 6. But I had some misfires in other cylinders can't remember which ones but I cleared it and it all went away. Mind u it's like - 30 here and it happensd on a cold start. Would it be safe to drive Still?
    Feb 20 2018
    Italy
    I would check the sparks because mil on does it mean over 60 misfires/1000Umin and thats not really good....
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    replace the spark plugs and make sure they're gapped correctly per recommendation.
    OEM is a little wider than the recommended gap for a tuned car but a lot of the time you won't have any issues either way until it gets super cold.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    May 10 2013
    Toronto,ON
    Car is driving fine now but I will replace the plugs. Don't think they have ever been replaced. 13 with 53km. I'm stock now but will retune after the winter so what gap should I run it at?
    Veteran Member Three Rings 3g_bishi's Avatar
    Mar 03 2016
    07 a6. 13 A7, 13A6, 08 A8LW12, 16A3, 15RS7
    DFW
    Hello, it’s becoming a common problem. Slot of 4.0TT guys st heaving misfires. Mostly on one specific cylinder. I have a 2015 RS7 that had a cyl#3 misfire. I have tried everything as far as plugs, injector cleaning, carbon cleaning, coil pack, still no fix. So I purchased a brand new ECM from the dealer ship ($1400) and installed it and programmed it my self. It’s been 1 day and so far no more misfire. I hope that was the issue. I spoke with the APR guys st SEMA this yes ein Vegas and he told me he ran into the same issue and it ended up being the ECM.
    Mar 03 2016
    DFW
    Quote Originally Posted by 3g_bishi View Post
    I purchased a $1400 ecu and I still have a misfire, new coil, spark plugs, tons of injector cleaner, and I have a specific cyl #3 do not waste money on the Ecu it’s either an Injector (highly doubt cuz someone in here changed it and still had a misfire) or a mechanical engine problem such as a piston ring sticking or a valve spring wearing out
