Results 1 to 11 of 11
    Jan 29 2018
    Il. / Wi. border
    Charging battery on a 14 S6
    Hey gang,
    Due to the frozen tundra temps here in Illinois (-50 wind chills), my S6 didn't want to start this morning. Do I need a special battery charger, or can I use the old trusty old charger that I use for every other vehicle I own? I assume that I will use the posts under the hood to do so? It seems that every other thing on this car requires special tools or parts.
    Thank you guys in advance!!
    Veteran Member Four Rings ericw.'s Avatar
    Apr 23 2011
    C7 S7 4.0TT, Jeep JKU, MB GLB
    Sac Area, CA
    Whatever charger you have is probably fine, I always charge from the remote posts under the hood.
    IG @lolzhax
    //AGILITYDRIVES.US
    C7 S7 4.0tt faster than kaploww and passed smog | LX7U | JHM STG3 ECU+TCU | JHM DP + CATBACK + Oil Screen Relocation + LW Crank Pulley + Heat Exchanger | SRM +4MM Turbos | S-FloV2 | EUROCODE SWAYS | CETE ASC | RFX7 | PS4S | RS7 FR+R | PD700R Splitter | Maxton Skirt+Spoiler Extensions | Indicator Delete | Hardwired
    b7 a4 2.0t | Stage 2+ | DTM Body [sold]
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Audi does offer a charger. However it is just a rebranded Ctek
    https://www.amazon.com/Genuine-Audi-.../dp/B00A0J8R1K
    Any smart charger would work as long as the current is not too high and has some intelligence to prevent overcharging.
    I personally use the Ctek MUS 4.3.
    Also FWIW just a technical note wind chill does not affect the battery but understood it is very cold in Chicago. Bundle up and good luck.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Jan 29 2018
    Il. / Wi. border
    Thanks a lot guys, it is really appreciated! The base temp of -26 is pretty chilly for sure...it put a deep freeze on that battery!
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    If the battery is original it is likely time to replace. At -22 the battery has only about 50% capacity if it was brand new. Couple that with age (yours is likely 4-5 years old) and you have a recipe for a dead winter battery.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Valpo A7 View Post
    Excellent point. Also every time it "dies" its lifespan is decreased even after you recharge it...some say by half, so you are really on borrowed time.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Jan 29 2018
    Il. / Wi. border
    Well, charged the battery for almost 3 hours and it is a goner. Is it as simple as just replacing, or do I have to have it programmed to the car. My gut tells me it won't be a simple or cheap endeavor.
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Rkhitect View Post
    Ah too bad. It is a mixed bag. Some say you absolutely have to program it to the car otherwise the battery management will have issues others say just regular swap the battery and no issues....I'm not sure which is for certain the best path...sorry.
    However, I do know that since it is an S6 you have to move the air suspension tank to even get at the battery. Should not be a big issue but just another hurdle. Good luck.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Some people have just replaced the battery but it will probably last longer if the car "knows" what type of battery you have and that it is new. The battery change is pretty straightforward. If you have vag-com there are some instructions on their website. I went to the dealer and got an oem battery for my S4 when it went out. I'm sure there are a multitude of options on batteries that would work.
    Senior Member Two Rings overclocked's Avatar
    May 21 2018
    2018 Audi S6 Sepang Blue APR Stage 2, ECU/TCU tune, SRM intake, 2015 Audi A3, Mercedes Benz GLE 350
    Washington DC Metro area
    I was in the same situation. Put my S6 in storage but procrastinated and did not connect my trickle charger in time. Battery was dead (reading 4.8 volts). I was able to jump start it after connecting directly to the terminals of the battery (located in trunk), and it started. Connecting to the battery manager could not wake it up. I took it to the dealer and he said the battery was dead, and gave me a new replacement.
    I now keep all our cars on trickle chargers, and unplug when using them and reconnect when parked, just for winter. I use the Battery Tender Plus.
    2018 S6 Sepang Blue APR Stage 2 with APR DP, TCU tune, SRM intake
    2017 Mercedes GLE 350 4MATIC Stock
    2015 Audi A3 2.0T
    Jan 29 2018
    Il. / Wi. border
    Well, looks like I am running to the dealer tomorrow to buy a battery. I am gonna use the battery tender I have to keep it up to snuff from now on. Thanks again for all of the insight guys!
