I am installing a Android Radio to replace the Factory Symphony/Bose unit.
I am trying to sort out the antenna connections.
The factory unit appears to have two antenna wires. One with a flat OEM style connector (shorter than, but not Motorola), and another connector (maybe Fakra, but not like other Fakra I have seen)
See picture below.
The Android unit has single Motorola type antenna socket. I used an adapter for the OEM flat connector (can be seen in picture). But the reception is not good.
I am looking for an adapter (or combination of adapters) to combine the two antenna wires.
Anyone have an idea or ever find something that would work?
Also, I read somewhere that factory antenna amplifier gets power through the antenna wires from the Symphony unit.
Can anyone confirm this? Do I need an adapter with an inline amplifier?
I have seen this thread, it is similar but not the same connector issues.
https://www.audizine.com/forum/showt...ed-Navigation)
Any help is greatly appreciated.
FYI...
Android Radio:
https://www.aliexpress.com/item/Andr...5bb14c4dYXHUYk
Harness Adapter (this was really "plug-n-play", but does not include any antenna connections):
https://www.ebay.com/itm/Active-Syst...72.m2749.l2649
Antenna Adapter:
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Dash Kit (some assembly...and modifications required, not perfect, but not to bad):
Radio Connections:
