Results 1 to 9 of 9
    Oct 08 2014
    Stow,Ohio
    APR high flow fsi injectors
    https://www.uspmotorsports.com/APR-H...Injectors.html
    Anybody ever use these or heard of them? I'm always searching and dreaming about my next setup and 500+hp would be my goal. As well as a setup that is simple and somewhat developed. I know there has been a few threads about the limited injector options our platform has available but I have never seen these mentioned. Nor have i seen many setups actually making power in that range. Interested in some input.
    Sent from my SM-G930P using Tapatalk
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    arent those just s3 injectors? 13% more than stock (k03)?
    Oct 08 2014
    Stow,Ohio
    Now that I actually read the description correcetly looks like these are just S3 injectors made by apr or the ones offered in their k04 kit? I'm confused? I already have S3 injectors so looks to me like these wouldn't be much of an upgrade lol.
    Oct 08 2014
    Stow,Ohio
    Ya I read the description wrong I believe. I read it as 13% larger then k04 injectors...
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    That’s correct. APR injectors are the same as S3.
    S3 injectors are the most reliable injector we have for 400 HP and down.
    Above that, there are very few options but a couple guys are playing around with modern GM injectors with some success.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Injectors for our platform are available up to 748 hp. Just need open up your search to the UK and you’ll find all kinds of options.
    May 20 2017
    New Hampshire
    Quote Originally Posted by canadianA4B7 View Post
    Your last post in the injector megathread is well over a year old. Did you ever get Gen 2 RS4 njectors to run right?
    May 20 2017
    New Hampshire
    And did anyone ever confirm that newer DI injectors that take 12 amps to open fully will run right with an ECU sending 6 amps?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    My two cents, for what they’re worth...
    RS4 injectors, tune to about 85% duty cycle at max RPM. Then add port injection (either 4x small injectors or 1x large) with secondary injection control (034 EFI) and tune those injectors to pick up the slack based on AFR.
    Canadian is right about looking at Europe. There are some great options, but cost prohibitive. The Gen 2 RS4 injectors ended up going to an MK6 owner. I might get them back and make a harness, or just go with option 1 from my first paragraph. Tuning wouldn’t be too hard.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
