Results 1 to 21 of 21
    Junior Member One Ring Quattro_Junkie's Avatar
    Jan 21 2019
    California
    Very Confused Why My Audi Locked Itself When Idling in the Driveway...
    Hi Audi Fam,
    I'm in need of your help. Last weekend the worst thing happened - I got locked out of my car and it ended up sitting there idling for over three hours as we waiting for AAA to stop by. Here's the play by play of what happened exactly:
    • I turned on the car to warm up in the morning because it was freezing...
    • I existed the car for literally 3 - 5 seconds max and realized I needed my jacket so I proceed to open the driverside door.
    • Now all the doors are locked...
    • Of note, the trunk was open and remained unlocked even when I closed it because it was snow - I found this to be odd since everything else was locked up.
    Does anyone have any idea why this would happen? It is my understanding that my car's doors and trunk would lock up after a couple of minutes when the car is off, or if I were to start driving and reach 10-15 MPH. I'm just stunned it would lock itself when the car was just idling in the driveaway...
    If this has happened to you or someone you know or know of a solution, I'd be extremely pleased to hear your suggestion! This happened to me when I first bought the car three years ago (when the car was off), but at the time, I was convinced I did something to lock the car. I did some digging on the forums and read that the key fob battery should probably be replaced and I'll definitely do that (I believe I did that a while back), but I'm not convinced that's why it automatically locked on me when running.
    Any help would be much appreciated!
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Once you unlock your car, if you don’t open a door, the car should lock itself.
    This is just a theory but maybe the contact switch for the drivers door is faulty and did not register as being open. So when you started your car and got out, it locked itself.
    You can check door contact switch with VCDS. I’m sure you can check it with the display too. Does the door show as open when you open it?
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Veteran Member Four Rings tloft4's Avatar
    May 15 2016
    Lock Haven, PA
    it doesnt lock itself until you go over a certain speed. and it unlocks when you open from the inside. never had this happen and i leave mine all the time
    Veteran Member Four Rings Nor_Cal_Driver's Avatar
    Jan 03 2005
    14 MkVI, 11 Sienna AWD
    530, California
    Very Confused Why My Audi Locked When Idling in the Driveway...
    If the trunk was open, why did you not enter through the folding rear seats?
    13 S4 DSG/Sport Diff/Drive Select
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    01 S4 Sedan MTM tune
    01 S4 Avant APR tune
    02 A4 3.0 Sport
    99 A6 Avant, w/3rd row
    01 A4 Celebration Edition, GIAC tune
    May 15 2016
    Lock Haven, PA
    dont they only open from the rear seat side?
    Nov 21 2014
    Montreal
    I have a similar problem haven't really found a fix yet. It could be related to the red light in the door, it's broken maybe open circuit is causing the problem?
    Oct 26 2018
    2014 Lincoln MKZ 400 HP
    Akron, Ohio
    My car did this to me yesterday as well.
    I was lucky though, I was at home and used the spare key to get it unlocked.
    One of those things that makes you go mmmm.
    May 20 2017
    New Hampshire
    Door contact switch....
    Check it out. Does the door show as open on the cluster when you open the door or on VCDS if you have it?
    Veteran Member Four Rings A4_PimP's Avatar
    Jan 18 2012
    Waterdown/Ontario/Canada
    My old Passat battery died after sitting all winter. I was locked out because the driver door lock was removed by the PO. After that happened I always leave one of the fold down seats open it's up just not pushed back to lock. No one sits in my rear seats so it's not a problem.
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    Quote Originally Posted by EvolutionArmory View Post
    but if the engine's running it shouldn't lock the door , right?
    I could test this, but its not something that I normally do, I mean let the engine running while Im out .
    - Always keep the plastic key in your wallet or hidden somewhere outside the car.
    - dont warm up the engine. I mean its -24°C here (-11°F) and most people don't warm the car since we are suit up for cold days and running cold cat, well, hello co and nox for our little comfort...
    May 20 2017
    New Hampshire
    Quote Originally Posted by oVeRdOsE View Post
    Once you unlock your car, if you don’t open the door within a certain time, it locks itself again. If the door contact switch is not registering the door being opened, it should lock itself even if you start the car in theory.
    It’s Soooo super easy to prove or disprove this and I wish someone who is having this issue in this thread would simply turn their car on and see if the cluster shows that the door is open when they open it.....
    Jan 03 2005
    530, California
    Why not warm up for 1-2 minutes. Isn’t that why the engine has the kick down after a cold start?
    Gone:
    06 A4 TQM APR tune
    01 A4 TQMS
    02 A4 3.0 Sport
    May 15 2016
    Lock Haven, PA
    if you are saying your car will self lock while off after x amount of time that isnt true. yes my cluster works, mine doesnt self lock while driving until a certain mph, so going slow on a road then speeding up 30s later, you will hear the lock.
    May 20 2017
    New Hampshire
    Quote Originally Posted by tloft4 View Post
    I already explained it like 3 times :)
    I just timed it with my own car. If you unlock your car with the fob and don’t open your door within exactly 1 minute, the car locks itself back up.
    What I’m suggesting is that maybe the door contact switch isn’t working or was stuck.
    I’m suggesting that maybe the car was unlocked with the remote, the car was started, and the door was closed with the car unoccupied as he was just warming it up. I’m suggesting that maybe the door contact switch is faulty and didn’t register as the door ever being opened and the car locked itself.
    Does that make sense now? It is a feature of the locking system. I know this to be true because well, I just timed it with a stop watch 😉
    May 15 2016
    Lock Haven, PA
    just did as well and will agree to that. i usually leave mine double unlocked and in that state, it will not self lock. only driver door unlocked, 1 min, relocked itself
    May 20 2017
    New Hampshire
    And I don’t believe there is an actual plunger type door contact switch. I believe it’s part of the door locking mechanism.
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Can confirm. If you don't open a door, it WILL self-lock.
    I found this out trying to get the car on a jack, and after unlocking the car it would lock itself again (setting off the alarm when I got the jack under it, mind you) until I opened the door after unlocking.
    Sent from my ZTE B2017G using Audizine mobile app
    Sep 01 2016
    Vancouver
    Quote Originally Posted by a1dan_87 View Post
    This only happens if the car is OFF. If the car is running, the self-lock is not on a timer.
    Aug 04 2015
    Kansas City
    I only have one key so I get paranoid about the door locking while running. Whenever I leave the car for a moment I always roll my window down just in case.
    Nov 03 2011
    All Over!
    My car won’t self-lock if the ignition is on, or the engine is running.
    I also turned off the self-locking at speeds above approximately 9mph with VCDS. I don’t like cars that lock me in. I prefer to seize that control back, and lock it myself from inside if I so wish.
    It’s also a bad idea to leave an engine running unattended. In some states, it’s actually an offence.
    1986 Type 85 Audi 90 quattro
    May 20 2017
    New Hampshire
    See post 14 and 16. Replacing the door lock was usually the first step for us at the dealer. I didn’t know there was a potential software update so that’s good info to have. Thanks for the TSB. It could be useful for the future. 👍🏻
