Results 1 to 12 of 12
    Aug 08 2014
    New Zealand
    E85 safe submersible fuel hose. 3/8. - 6 Questions
    Hello here in New Zealand I'm only able to get Gates or Dayco submersible fuel hose e85 safe ect. There wa s a test a while ago and the gates showed sum sort of perishing and the forum was told to get the dayco stuff, I have just emailed them to see if thay can send direct as I'm being charged 47$ for a foot,
    I'm re using the top hat in the B5 using Bulkhead fittings copy of another build on here, from the pump to hat and as a return line in hose not hard line to the bottom of the tank any help is appreciated thanks. The pump is a push lock end so have made the same off the top hat.
    Apr 21 2013
    Cleveland, OH
    Are you able to order from Radium Engineering? They have PTFE corrugated submersible fuel hose, that's what I've been using and it works great.
    Link here: http://www.radiumauto.com/Submersibl...bing-P672.aspx
    02 Allroad 6MT
    01 Single Turbo B5S4
    Aug 08 2014
    New Zealand
    I had some but could not get it on and ruened the end I have also seen a few of them burst
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    I’m using them on my GT build. They are working fine with my dual 450 walbro setup. You need to either put the hoses in warm water first or use a heat gun to warm up the ends. Then they will slide on with ease.
    Aug 08 2014
    New Zealand
    I did try the heat gun but from pushing so hard it tor on the ribby part dam Hay. Otherwise I need to get the dayco I can't do ptfe as the pump is push lock also. Just really hard to find and sooo expensive
    Jul 04 2012
    Woodbridge, VA
    I wouldnt use any of the rubber submersible hoses. All ive ever seen is failures. Go with any PTFE corrugated hose and you shouold be fine.
    Oct 26 2011
    CA
    Quote Originally Posted by marka4 View Post
    Are you saying you have push lock fittings on your fuel bulkhead? I had push lock AN fittings on my fuel bulk head as well. If so, you can change them out to non-push lock fittings to use the PTFE hose. The fittings are not cheap but, will work for E85 applications. Like vavJETTAw36 stated, I wouldn't use the Dayco rubber hose for E85 submersible application. I had a similar setup running E85 and let’s just say the rubber hoses deteriorated over time. Below are pictures of the AN-fittings I'm using on my dual 450 pump setup running E85. Hope this info helps you out.
    Aug 08 2014
    New Zealand
    Na I have bought push lock ends for the Bulkhead 90.
    Aug 08 2014
    New Zealand
    Do you have any measures of that top hat you have? May be a better way to make one than wreck the plastic oem one
    Dec 05 2007
    Bump
    I'm in the process of finalizing my e85 conversion (engine bay done, and just need to swap out the 044 pump for the 274 with relay kit). I picked up a standard 5/16" corrugated flex line for the line from pump to the cap. Question is, will a standard plastic corrugated flex lines hole up to e85? Or do I need PTFE corrugated hose (expensive Radium stuff)? I just figured stock line is plastic and people ran those e85 no problem, so figured I'd be safe. Still, better to ask before final install (ie def don't want to pull the pump after install just to replace one silly line).
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Should be fine with the stock line
    Dec 05 2007
