Results 1 to 14 of 14
    Nov 18 2018
    Midwest
    Abnormal Audi Grill Damage
    I just noticed the grill on my vehicle started having some wavy lines in it. It was only noticeable in just the right light. After a week or so it started getting worse. I wiped down the area and tried to figure out if something got onto it or something. This evening it became even worse its like the chrome layer is delaminating from the grill. At first it was small and i thought worse comes to worse i could get it painted black or plastic dip it, but now its in seriously bad condition. Has anyone ever ran into this issue? I'm in Minneapolis and it has been in the negatives to is the heat from the engine then sitting outside in the cold while am at work doing this? Our A6 has never had this problem and i just got this car this month.
    Can this be fixed or am i just going to have to bite the bullet and find a new grill?
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    I have seen this before. Essentially, it is a manufacturing flaw. The plastic chrome is delaminating from the plastic grille frame. This shouldn't happen regardless of heat/cold or weather conditions. It isn't worth attempting a repair and if it isn't replaced under warranty, I would suggest an RS style replacement grille. They are relatively inexpensive and look better imo.
    Sent from my SM-T713 using Tapatalk
    May 09 2014
    Phoenix, AZ
    That picture matches exactly the grill on my 2013 S5 (75k miles). Probably started to see this around 65k miles.
    Mentioned this to the service agent when the car was at the dealer for service. He said it happens on occasion, likely due to heat (I'm in Phoenix, but not sure I buy that explanation), but that it wouldn't be covered under warranty. Didn't want to pay for a replacement grill as not sure how much longer I will have the car.
    Veteran Member Four Rings 03TLSinCO's Avatar
    Feb 02 2018
    '16 S5 Prem Plus; '13 Q5 Prem Plus S-Line; '09 Honda Odyssey (The Wife's, in the driveway)
    CO
    This is called "dewetting". Dewetting is a phenomenon where a thin film of liquid ruptures on a substrate, which leads to droplet formation. It is the opposite of the process of spreading, which is a liquid spreading on substrates. In this case, chrome is the liquid plating spread across part of the plastic grill. Dewetting usually occurs when some sort of contaminant is left underneath the top plating coat, causing this delaminating, or more accurately, dewetting. It is a manufacturing defect and I would imagine it would be covered under warranty, if you still happen to have one (not likely on a 2013).
    2016 S5 Prem+, Moonlight Blue Metallic/Lunar Silver, Sport Diff, Black Optic Plus, B&O, Adaptive Damping Suspension. 034 Stage 2 ECU/TCU, RS5 grill, AWE S-FLO Intake, 034 X-Brace, 034 Rear Sway Bar, CR-15, Magnaflow non-resonated X-Pipe
    2013 Q5 Prem Plus S-Line, Moonlight Blue Metallic, 034 Stage 1 ECU/TCU
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    My mom's first Q5 had this problem, too. They actually had an appointment to get it fixed, but the day before the appointment is when they got hit head on by a dead guy and the car was totaled, so nothing ever came from it. The same problem hasn't come up on their new Q5, which is the same model year as their one that had the issue.
    If it's under warranty, have it replaced. If they claim it's not under warranty, have them prove that to you with their little booklet. If it's out of warranty or proven to not be covered, it's a great excuse for an RS style grille.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    May 09 2014
    Phoenix, AZ
    Quote Originally Posted by 03TLSinCO View Post
    Mine was under CPO warranty at the time (and still is for one more month), but they said it wasn't covered so I didn't push it. Guess I could try again before the warranty is up.
    Jul 17 2015
    Colorado
    Quote Originally Posted by mpo77 View Post
    I'd ask for a second opinion. That seems like something that should be covered, but I've been surprised by things that aren't covered before. The upper trunk latch assembly, for whatever reason, is not covered under CPO. The lower assembly is, but the upper isn't. My service adviser showed me the CPO book and the codes that coincide with specific failures, so I knew they weren't lying about it not being covered.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    May 09 2014
    Phoenix, AZ
    Wanted to give an update on my situation.
    My grill damage was getting progressively worse. Eventually the wrinkling led to cracking and then part of the chrome trim that was cracked ripped off when I was on the highway. It exposed the plastic underneath and obviously needed to be replaced. From the pic you can see the missing portion and also another section of chrome plating has already delaminated from the plastic.
    I sent that pic to my service advisor and he said that he will get it covered under my CPO warranty (only 2 weeks remaining). They had my car for 3 days and I didn't hear anything. Yesterday he called and said they are getting rejected by Audi for covering this under CPO. He said his manager is involved and they are trying to get it covered, but no luck as yet.
    If anyone has any experience getting this covered under the CPO, any advice would be appreciated. Will reply here when I have resolution either way.
    Veteran Member Four Rings Neil F's Avatar
    Jan 13 2017
    marlton/nj/usa
    If the Audi replacement does not work out, It is easy enough to get a stock replacement (very easy to put on yourself). There always are stock grills in the classified. People do try to sell them but there are not many who buy. I would not pay much.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    if it's not covered you can paint it black
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jan 13 2017
    marlton/nj/usa
    Quote Originally Posted by wangshuo1989 View Post
    But that won't keep it from peeling
    May 09 2014
    Phoenix, AZ
    Quote Originally Posted by Neil F View Post
    My service advisor contacted me and said that him and his manager got a "final NO" from Audi that they would not cover it. As an aside, he said they checked how much warranty work they did on my S5 - it was over $13k over the 5 years I've owned it (not counting regular service intervals). So a little bummed that the CPO didn't cover it, but it has been good to me.
    My advisor said it would be around $1400 for the grille replacement and labor. Part is $1200 and the labor around $200. He suggested I just find a grille on ebay and they would install it (I'm not a DIYer, so not even a consideration for me). I took the advice above and picked up a barely used one from the Classifieds here for around $200. Will just have them install it when it gets here. Thanks for the heads up.
    Jul 17 2015
    Colorado
    It will if you remove the chrome junk and properly prep and paint it.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Veteran Member Three Rings snocat17's Avatar
    May 12 2017
    2016 S5 Cab, 2016 Mazda CX-5, 2012 Ford F-250
    Steel City, USA
    I'm not a DIYer either. I asked a very reputable collision shop how much they would charge to change out the grill and they said maybe $150 if they were having a busy week. That might be a good option too, and you could ask them to paint the gray bars black. It would still be under $500 all-in.
    -Joe
    2016 S5 Cabriolet Prestige Glacier White Metallic w/ brown comfort seats and piano wire black wood trim. RED Brake calipers holding EBC RedStuff pads, APR Carbonio Intake, ECS carbon fiber back-pipe, VCDS cable
