Results 1 to 17 of 17
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Q5 Brake Pad Suggestions
    Looking to replace the front/rear pads on my 3.0T Q5, what pads are most people running for low dust good daily usage? On my A4 I ran Akebono's and loved them.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Jan 07 2019
    Phoenix, AZ
    I just put on Akebono ceramics and zimmermann rotors. Love them so much that I may replace the rears to cut the dusting even thought they were done about 20k miles ago and have a lot of life. The dust is absurd.
    I'd stick with those if you were happy.
    Apr 24 2017
    Hilton, NY
    So the only thing I am confused with is that the Q5 came with two different front caliper options, the non-Brembo and Brembo. One that also uses 320mm or 345mm rotors. From my research and my options codes on my '16 Q5 3.0T I believe I have the Brembo w/the 345mm, can anyone else shine some light on this?
    Senior Member Three Rings KillerQuattro's Avatar
    Dec 15 2016
    Englewood CO
    I believe you are correct. 345mm for the 3.0T. When I did my brakes last year, I tried finding Akebono pads with no real luck. I have used them previously and loved them but I dont think they make them for the 345mm/Brembo combo. I went with EBC Redstuff pads and have enjoyed them so far. Also did stainless steel brake lines to firm up the pedal feedback.
    Current: 1995 urS6 Avant. RS2 manifold, Stage 1 chip, Apikol FMIC, custom exhaust.
    Sold: 2013 Q5 3.0t- EPL Stage 2, 183mm CP, KW Coils, Eurocode Alu Kreuz, 034 inlet/AWE filter, EBC Brakes w/ SS lines, Hartmann HRS6 20x9, MF #11385 (center res) and Vibrant Ultra-quiet resonators out back.
    Sold: 2007 Ibis Avant- 2.0t 6mt, JHM HFC, TT DP, JHM HPFP, GFB+, B5 perch mod, 19x9 RS6, Hawk slotted rotors and performance pads.
    Sold: 1992 urS4- Garret 3071R, 034 tuning, RS2 goodies, 993TT BBK
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by KillerQuattro View Post
    Awesome! From my initial search it looked like my options were StopTech/EBC/OEM. At least changing the front pads will be a little bit easier being able to drop them in from the top.
    Jul 03 2004
    SF Bay Area
    Can anybody confirm if these will work with a 2017 Q5 3.0T? I believe I would have the 345mm front brakes correct?
    https://www.rockauto.com/en/parts/ak...brake+pad,1684
    2017 Audi Q5 3.0T P+ | Sepang Blue | Black Optics | Competition S-Line Plus | Tech | Black Nappa | Aluminum Satellite Inlays | 21" factory wheels
    2004 BMW M3 | Alpine White | Speed Cloth | 6MT
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by simy View Post
    The Akebono EUR1018 are rear brake pads, all the variants of the Q5/SQ5 use the same size rear brake pads/rotors.
    Jul 03 2004
    SF Bay Area
    You're right. I copied the wrong link since I was looking at both front and rear options.
    Here is the link for the Akebono fronts: https://www.rockauto.com/en/moreinfo...448536&jsn=255
    Apr 24 2017
    Hilton, NY
    Looks to be the right ones in that link, just remember you will have to re-use your OEM mounting pins. I went with the Posi-Quiets and they come with new pins/hardware. Also I found that the Q5 OEM brake pads arn't nearly as "dusty" as my A4's. Where as the OEM A4 pads made my silver wheels look gray/black after only a few days and switching to Akebono' eliminated that.
    Mar 12 2017
    N.C. USA
    With Mops recommendation I had HAWK street performance front pads installed on my 2016 Q5 2.0. Very pleased with their performance & no brake dust problems.
    2020 Q5 prem plus Matador red/Beige
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I just installed new Brembo rotors and pads for my 345mm rotors and Brembo calipers.
    I went with Brembo ceramic low dust pads. They have surprisingly good initial bite and are very linear. Very low dust. I believe they were about $78 for the four front pads with free shipping.
    https://www.brembostoreusa.com/produ...brembo-ceramic
    The part number is on the back of the pad in the photo below.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    I'm on my 2nd set of EBC redstuff. Compared to OEM there's less initial bite/ more progressive feel but no complaints. Quiet and low dust.
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Another good option, just checked the Brembro site and they offer front pads for the B8.5 SQ5 now too. Different part numbers than the 345mm option so assuming they are meant for the 380mm option. Options are for "NAO" or "Low Met", seems like the NAO are more for comfort and extended life like a true ceramic pad. the Low Met seem more like a aggressive street pad with improved pedal feel, better stopping power and higher braking temps.
    Noticed RockAuto carries them too now for the front and rear.
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by SDV325 View Post
    NAO = ceramic - low dust, longer life, progressive increase of grip with pedal pressure.
    Low Met = semi-metallic - higher dust, shorter life but greater initial “bite”, typically like most OEM pads.
    Neither of these are track day or race pads. I went ceramic for low dust, quiet operation, longer life and because I like bite to increase with pressure. Either is a great option. And, Brembo pads are engineered to go with our calipers.
    Here’s Brembo’s comparison chart:
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Jul 09 2009
    Cleveland OH Area
    Sent from my SM-G965U using Audizine mobile app
    Dec 01 2020
    Phoenix
    Reviving back from the dead. Can anyone tell me for certain the P/N for EBC Redstuff pads for a 2014 Q5 3.0T with 345mm rotors? I get a different answer on every website...
