Results 1 to 26 of 26
    Aug 18 2018
    Massachusetts
    2015 A3 Water Pump
    Brought my car in for the 55k maintenance and brought their attention to how my coolant was way under the min line a week ago. Get a call today saying my water pump has a leak and it’s gonna be 1200$. It’s odd that this is happening at only 55k miles. Should I get it replaced with the dealer or would it be cheaper somewhere else. What have your guys’ experience been with issues like this?
    Senior Member Three Rings CronicPAIN's Avatar
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    Is not covered by warranty? Mine had a coolant smell and I took it to the dealer and they found it was from the thermostat they replace it and the water pump too it was covered by warranty my car has 49k now
    Sent from my SM-G950U1 using Audizine mobile app
    Feb 09 2008
    Quote Originally Posted by TheLoneA3 View Post
    I can almost guarantee that it'll be a lot cheaper at a reputable independent. It does seem odd that it's failing so early, but I suppose anything is possible. If it was me I'd absolutely take it to a good local mechanic, assuming you know of one.
    Aug 18 2018
    Massachusetts
    Quote Originally Posted by CronicPAIN View Post
    Warranty ran out last year
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    I think a local shop will charge cheaper
    Veteran Member Four Rings Grey3's Avatar
    Mar 14 2018
    B8 S4, mk6 Jetta, 2 mustangs
    Sherrills Ford NC
    Mine was replaced along with the thermostat at 54k. Pump and thermostat was 800 bucks at a trusted independent. Sucked that it was just out of warranty
    Sent from my phone using Tapatalk
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Dealer is the very last place I'd go for work. Cheaper anywhere, and unless you are in the sticks, there's probably a decent euro shop around. I just did myself last time I needed on on my A4 but I'm comfy with that sort of stuff.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Sep 14 2006
    Waterpump and thermostat is a known issue on this car. Audi has been known to have waterpump issues in other models in the past as well.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Dec 25 2004
    Earth
    Waterpumps $54...
    https://www.audiusaparts.com/auto-pa...ater-pump-scat
    Too bad ya dont DIY ya Audi.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Sep 14 2006
    Quote Originally Posted by MikTip View Post
    Waterpumps $54...
    Nice!
    -Thomas
    Current: /S3
    Jun 02 2014
    09 A3 Quattro, 15 A3 Quattro, 14 A4 Quattro, 22 VW Taos, 19 TT 20th Anniversary Edition
    Lynnfield MA
    I'm on the same boat as you. 2015 A3 with bad thermostat. I just ordered the part and I'm planning to replace it this Sunday. It will be a little warmer so I can do it outside.
    Aug 18 2018
    Massachusetts
    Found a Euro Mechanic to do it for $620 which is pretty high but I guess that’s what I get for not doing it myself...
    Jun 02 2014
    Lynnfield MA
    The thermostat is $165, water pump $55, couple gaskets $30. I did 3 water pumps on my 09 Audi A3 and 4 carbon buildup cleanings so I am familiar with what needs to be done but I would say $600 is not that bad considering the work involved.
    Active Member Two Rings BfunfLieben's Avatar
    Jan 20 2019
    Colorado
    I work at an independent German shop and we've replace water pumps on a 2015 as early as 45k. Whether it be the plastic pipe to the cooler or the thermostat/water pump assembly they are pretty prone to failure
    Sent from my SM-G960U using Audizine mobile app
    Senior Member Two Rings MkUrMark's Avatar
    Aug 09 2015
    Southern Cali
    Yup they’re prone to fail, 51k on my s3
    2016 S3
    12' Golf R:. Stg 1+sold
    10' Gti sold
    06 A4 sold
    Oct 19 2013
    Saint James ny
    One water pump and 2 thermostats, pretty sad all before 45k
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    Anyone make a better pump? Sure seems like a capital opportunity here
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Someone should make a DIY video and share the knowledge
    Sent from my ONEPLUS A3000 using Tapatalk
    Sep 25 2016
    Miami
    Pretty normal for these engines. My GTI's went out at 19k and my A3 at 16k. Bummer it happened out of warranty.
    Jun 02 2014
    Lynnfield MA
    Finally finished with mine. It is not much different than CCTA/CBFA engines on the previous generation A3. Audi/VW engineers did a little better job this time so we don't have to remove the injectors with the intake manifold. They still screw up with the fuel pump - the flange is on the way of the intake manifold so you have to disconnect the fuel line to remove it. If anyone decide to do it yourself be sure you replace the $5.00 connector between the thermostat and the oil cooler. I didn't, bolted everything and was ready to start the car when I noticed drip - drip. I had to do everything twice because of that little piece. Oh, and while the intake manifold was off I did carbon buildup cleaning. I had CEL couple times last month with freezing cold temperatures. The car is with 105 000 miles and runs like a champ now. Not a single error
    Deactivated Two Rings
    Jan 29 2018
    Audi%20S6
    Stillwater,mn
    Quote Originally Posted by evo v View Post
    Any idea what the 5.00 connector part number is? Just want to make sure I order the correct one…..
    Jun 02 2014
    Lynnfield MA
    Quote Originally Posted by D-max15 View Post
    111K306L-121-131 Union
    Feb 26 2019
    Belgium
    Hello all,
    I have a 2014 s3 sedan and have to bring it to the garage because the thermostat is leaking.
    My car is only 4,5 years old and has only 20000km, it is really unacceptable for a premium brand like Audi!
    It will cost me 1311 euro to have it fixed :(
    Active Member One Ring Hugpls's Avatar
    Feb 24 2019
    Orange County, CA
    Just had the Water pump and housing replaced on my 2015 A3 at 36k miles, under warranty but seems like a common issue.
    The dealer forgot to connect the charge pipe back in afterwards, just something to check when you pick it up..
    Jan 29 2018
    Audi%20S6
    Stillwater,mn
    Did a search on Audiusaparts.com and did not get any results from this part number. Is this part # correct?
    Jun 02 2014
    Lynnfield MA
    Yes. I got it from the invoice. When I was searching for this part I also couldn't find it. The dealer typed it directly on his tablet. He said he knew exactly what it is.
