Page 2 of 2 FirstFirst 12
Results 41 to 51 of 51
  1. #41
    Established Member Two Rings cadguy77's Avatar
    Jun 07 2019
    London, UK
    Quote Originally Posted by celticsevad View Post
    Just received those latest version KI pulley... The 200mm and the 206mm here is the official weight Attachment 151484Attachment 151485Attachment 151486
    Sent from my CLT-L04 using Audizine mobile app
    Which one is which? Red 206mm I assume?
    '15 CREC SB | Black/White Napa | Sports Diff | Dynamic Steering
    TVS ECU/TCU | Intake Mods | 82mm TB | Ported SC | 034 SC Clutch Delete | KI 206mm Crank Pulley (3.26PR) | Merc Racing HE | Bilstein B16 PSS10 | Front 4-Pot Brembos | EBC Turbo Groove and Yellow stuff | HEL Lines | 15mm Spacers | 034 X-Brace | DK Tuning B8 Front Strut Brace | 034 Rear ARB | 034 Trans Mount Insert | Profusion Custom Exhaust | Xenonz Rear Diffuser |
  2. #42
    Account Terminated Two Rings celticsevad's Avatar
    Jan 23 2019
    Montreal.Canada
    Yes
    Quote Originally Posted by cadguy77 View Post
  3. #43
    Established Member Two Rings 2013S4's Avatar
    May 20 2017
    NW Indiana
    The SC also has a type of spring dampener between the pulley and the gears that absorbs any remaining vibration. Any well-made pulley should not be a problem. (XLR8 196 on my car).
    Quote Originally Posted by MSq5 View Post
    I wonder if Jake could comment on the effects, if any, of solid pulleys, light or heavier, on the life of bearings in the supercharger (rather than the engine).
    Someone posted here a while back that the real reason for the two piece dampened crank pulley was because NVH was otherwise being transferred to the supercharger through the belt and would reduce the life of the bearings in the supercharger.
    That made no sense to me, as the belt, itself, and the tensioner pulley would have the dampening effect on any vibrations that would otherwise reach the supercharger through the s/c pulley and belt.
    I ignored that speculation and have done fine with the JHM 179. I'd much rather have a little NVH (and I sense absolutely none) than have a crank pulley delaminate out on the highway, God only knows where or when.
    Just curious.
  4. #44
    Oct 21 2010
    Salisbury MD
    Jake,
    You're the man! I just ordered my new crank pulley!
    Now to save up for that full exhaust.... If you need a teacher's car for advertising purposes....
  5. #45
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by ron4pres View Post
    Jake,
    Thanks for the order!
  6. #46
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Chiming in quick although our name has already come up. Everyones support is greatly appreciated!
    Our XLR8 crank pulleys vary in weight based on sizing. The 179mm outer ring (the smallest size we offer) weighs in at 1lb 14oz. The 196.5mm outer ring (which is also our largest size) weighs in at 2lbs 3 oz.
    Since our XLR8 crank pulleys are a modular design you can't forget to add the weight of the hub! Those come in at just over 1lb (1lb 1oz) themselves. Given the fact that the stock pulley weighs 8lbs 10oz, regardless of the sizing you choose, you're going to be shaving off at least 5lbs!
    You can find some more info on our pulleys on the old release thread HERE, and you can find them on our online store HERE.
    If anyone has questions or wants the best pricing possible please feel free to shoot me a PM. Happy modding!
  7. #47
    Oct 25 2019
    Cedar Grove, NJ
    How can I purchase one of these?
  8. #48
    Feb 14 2014
    Some broken BMWs
    Branford, CT
    Quote Originally Posted by Jay2014S4 View Post
    Send me a PM or shop online here: https://xlr8performance.com/b-33-61-xlr8.html
    We'd be happy to help you get setup with the option of your choice!
  9. #49
    Dec 23 2019
    2016 Audi SQ5
    Ohio
    bump again for pulley weights for those of us that are just getting into this. Wish I would have found this sooner.
  10. #50
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Who has put the JHM 207 on a scale?
  11. #51
    Jul 19 2015
    Chicago
    The 034 Motorsports 207 mm crank pulley weighed in at 3.40 lbs.
