Results 1 to 29 of 29
    Jul 21 2004
    South Florida
    74mm Throttle Body vs 82mm Throttle Body Testing...
    First, let me take the time to once again thank Bryan at Euromodsperformance.com for the awesome experience purchasing the IABED throttle body harness and adapter. Bryan kept me informed every step of the way and was overwhelmingly responsive, professional and polite throughout the process.
    I was able to take advantage of the 10% off sale and purchased the harness for $270 and the adapter for $180. This is all that is needed. I already had a 74mm Bosch throttle body sitting around from my 997. This TB is on a ton of Porsches and can be found in great shape on ebay too for around $50. I also had the 82mm Bosch Throttle body available which is a common 997 Porsche upgrade. This is usually found brand new for approximately $140
    Thank you also to Issam Abed for taking the initiative to create this harness given us a plug and play solution for upgrading TB sizes.
    CONDITIONS:
    All testing was performed the same day and same hour on the same stretch of road running the same direction. The fuel was the same for both runs. The starting intake air temps were closely matched so IAT related timing changes were not confounding.
    74mm Runs DA: 3:03pm - 71f
    82mm Runs DA: 3:48pm - 70f
    Ultimately its about as well controlled of a test session as you can get without having a climate controlled test cell.
    The following was the vehicle setup for all runs:
    2013 Audi S5, DSG with Unitronic Stage 3 file that allows up to 26 degrees timing and requests 2450mbar boost. 200mm KI pulley was installed with stock SC pulley. Divorced Revo charge cooler installed. Exhaust is stock. The air intake was identical for each run with the exception of the size of inlet to t the throttle body.
    TEST VARIABLES:
    I tested the following setups:
    1. 74mm Throttle body p/n: 99760511501 for 74mm throttle body
    2. 82mm Throttle body p/n 99760511601 for 82mm throttle body
    RESULTS:
    Here is the log of two 74mm runs with cool down in between to stabilize and equalize intake air temps across all sessions and runs…
    https://drive.google.com/open?id=1Ke...6SktLBgOdzsz2K
    Here is the log of two 82mm runs with cool down in between to stabilize and equalize intake air temps across all sessions and runs…
    https://drive.google.com/open?id=1O3...9tUOwJgkrLxxHe
    another 2 runs with the 82mm throttle body...
    https://drive.google.com/open?id=1Bi...fI7-Y2jZtUdxe1
    VIRTUAL DYNO -
    DISCUSSION:
    Performance is a wash between both options with this vehicle configuration. No significant gains or losses were observed.
    Also important to keep in mind that this testing was performed on a car with stock blower without ported inlet and on a relatively modest dual pulley ratio of only 3.17. Further testing is to be performed on a ported blower and higher pulley ratios.
    Driveability has been the same as stock thus far. No issues noted. No perceivable difference noted.
    PHOTOS:
    2018 Audi S5
    Gone-
    Jul 21 2004
    South Florida
    Would anyone be willing to make some charts out of the data for me? Ill owe you one :)
    Mike
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Account Terminated Four Rings
    Mar 22 2016
    73 Jimmy 496 BBC
    Both look pretty much the same. The 74 you get slightly less boost but more engine tq if I’m reading it correctly. Not much of a difference
    Jul 21 2004
    South Florida
    I think i need to virtual dyno the data but my virtual dyno program gives me nothing but error codes. I suck at it
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Doing it for you now
    Mar 22 2016
    73 Jimmy 496 BBC
    [IMG][/IMG]
    Very negligible
    Senior Member Three Rings vpls4's Avatar
    Feb 17 2017
    Tempe, Arizona
    Thank you guys!
    This confirms what Tony@EPL also found doesn't it?
    Quote Originally Posted by Tony@EPL View Post
    In our testing... when staying with a conservative size upgrade, there was no lose in torque (in fact there were significant gains). Then going too big, there's no additional peak horse power gains but there as low end losses (pretty significant if you go too big). We tested several sizes btw.
    '15 S4 - Monsoon | GIAC DP 183-fluidampr / 57-awe & DSG tune | Autotech HPFP, GIAC LPFP | iABED 75mm TB | Tampa Ported SC & 4" Intake | AMS Alpha Cooler | 034 Street Density Eng Mounts
    EuroCode Sways, Links, Alu Kreuz | CR-15 | ECS 2pc D/S Rotors, EBC Red Stuff | HRE FF01, Pilot SS | Bilstein PSS10's | RSE Test Pipes | AWE Touring /Res DPs
    Jul 21 2004
    South Florida
    There were no losses in torque but no gains either. It confirms part of what he saw. I'd say its a wash for now. Not surprising with a non ported blower and only 3.17. I'll test again on parted blower and likely up to 3.55 pulley ratio.
    Hopefully we'll see even more testing soon as a little birdie told me a certain tuner now has one ready to go on their shop S4 for some exhaustive testing in their MAHA dyno chamber.
    mike
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Yup. A wash. Any differences you're seeing are well within margin of error.
    There's a reason issam and EPL are pushing the 74mm TB.
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Mar 22 2016
    73 Jimmy 496 BBC
    Agree but with a larger ratio and ported blower there may be gains but my guess is still minimal at best 5-10 maybe.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    Nice Mike! Really looking forward to seeing the data with ported blower and higher PR.
    Sent from my SM-G965U using Audizine mobile app
    Veteran Member Three Rings brs2c's Avatar
    Apr 26 2017
    GLS 450
    Nashville, TN
    As I posted in another thread- Going to be very little difference, if the SC inlet is stock diameter. You can’t take advantage of the 82mm, unless you either have the blower inlet ported out to almost no metal left (76-78 opening), OR cut the inlet off and weld a flange on at the wider point of the inlet (80mm opening, and the safer option). Do either of these, and you will see a difference over the 74mm.
    2013 S6 Prestige Monsoon Grey || SRM RS-7 Turbos, APR Catted Downpipes, SRM Long Intakes, DS1 Tune, SRM TCU, HPFP, SRM High Pressure Fuel Line, SRM Ethanol content analyzer, SRM Driveshaft Carrier V2, O34 Drivetrain Inserts, 034 Control Arms. || RS-Style Grill, BBS CI-R 20x10.5 Wheels.
    Previous
    2013 S4 || 3.5" Velocity Stack Intake, EPL Stage 2+, Fluidampr 183mm CP, iAbed TB, EPL TCU, AMS Alpha Cooler || VMR V804's (19x9.5 et45), 2-piece Rotors, 034 SB, 034 drivetrain & subframe inserts,
    Jul 21 2004
    South Florida
    Quote Originally Posted by evil35r View Post
    [IMG][url=https://ibb.co/h7CY84R][img]https://i.ibb.co/0DQsJ6j/0-D63-AECA-DB9-F-4-EC1-96-D5-E4822763-
    Very negligible
    Thanks for the graphs!
    Yeah i agree for my mods 74mm makes sense. You can find the tb used for change and the 74mm adapter plate seems like it provides a better seal to the throttle body.
    You can see on the 82mm adapter the seal is broken up by the bolts from the adapter to supercharger. Theres no ring of clean smooth surface around the tb where it mates up to the adapter.
    Mike
    2018 Audi S5
    Gone-
    May 19 2015
    winnipeg
    Quote Originally Posted by brs2c View Post
    If someone is willing to mail me an empty core I will gladly cut it off and weld one on for science free of charge.
    Aug 08 2016
    Oshkosh, WI
    +2 in dealing with Bryan at euromods. great experience.
    2013 S4 monsoon gray. EPL DP (fluidampr 183). Milltek exhaust, rotiform wheels, KW variant 1 coilovers, PLM HE, 034 alu kruez, 034 motormounts, trans, diff mounts. solowerks rear swaybar, CR-15 brace, roc-euro intake, rs grille etc. And 2 Land Cruisers
    Mar 17 2016
    CO
    Couple cleaner vdyno files for comparison:
    First 74mm run vs. First 82mm run in the first file:
    First 74mm vs Second 82mm run in first file:
    In both cases, it looks like 5-10HP increase across most of the powerband. I think the comparison evil35r (lmk if I'm wrong) posted was based on the later log with 1-2 degree higher starting / ending IATs relative to the 74mm logs. I'd say....cautiously optimistic?
    Edit: re-uploaded vdynos with DSG specs (somehow I ran it under manual)
    2014 B8.5 S4 Ice Silver DSG
    EPL Stage 2 DP::EPL TCU Tune::Merc Racing HX::iABED 75mm TB::ECS Luft-Technik Carbon Fiber CAI::Bilstein B12::ECS Transmission Mount::ECS Slotted Geomet Rotors::EBC Red Stuff Pads::19" Black AG M510 Wheels
    Jul 21 2004
    South Florida
    Quote Originally Posted by k186 View Post
    COp8Iii.jpg[/IMG]
    [g[/IMG]
    Hey, thank you so much yet again! It may not seem like much but I go nuts trying to get my virtual dyno to work, lol. I had mistakenly only posted that first, single 82mm run. I meant to post the 82mm session that had multiple pulls.
    Yeah, its possible there is a little something. At the very least I'm glad there appears to be no losses at all. Perhaps the more we go up in pulley ratio the more we can see.
    Thanks again
    mike
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    I used the first set of runs in both logs when he first posted them. Yea I agree if anything prob 5-10 still a wash now if I were to do it all over again would I get the 82 now that I am ported and have a larger ratio prob but will I stay where I’m at till I’m bored and wanna switch and sell my 74 maybe lol
    Jul 21 2004
    South Florida
    So my concerns about the design of the 82mm may be well founded.
    Look here at the 82mm tb adapter and see the sunken bolt holes that secure the adapter to the supercharger span the entire width of the adapter plate.... meaning there is no uninterrupted flat surface to mate to the throttle body...
    Here on the 74mm tb adapter see there is a flat full circle of metal that can mate and seal to the tb...
    Sure enough im getting p2279 air leak codes despite torquing perfectly again now to even 15 lbs
    Mike
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Mike you’ll get a air leak code it’s tune related... I don’t think you have a air leak. Anyways I used gasket maker in both sides.
    Jul 21 2004
    South Florida
    Never gotvan air leak code on the 74mm and i beat the piss out of it. Look at the imprint in the gasket. I think i need to use something else to seal it no?
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Gotcha, yea I would just forgo the gasket and use gasket maker...
    Jul 21 2004
    South Florida
    Heres the 74mm seal. Theres space to seal between the bolt hole and lip
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Concur
    Jul 21 2004
    South Florida
    Concur
    Darn. I was hoping youd tell me why i was being stupid lol
    2018 Audi S5
    Gone-
    Mar 22 2016
    73 Jimmy 496 BBC
    Lmao you’re being stupid 🤣
    Senior Member Three Rings j23a45m's Avatar
    Feb 07 2018
    19’ Qx60, 16' s1000rr, 15’ S4, 12' X5, 10' A3
    Lacaster, Pa
    Mike do you know the out side bolt specs? Looking for them and didn’t know what ones to get!
    Jul 03 2016
    Ontario
    Great comparison mike. Glad to see you back in a 3.0T
    Sorry if it’s off topic but how would you describe the differences in the b9 compared to the b8.5
    Apr 10 2017
    Fort Mill, SC
    Hello. Upgrading the TB will net no significant gains if the air is being choked at the intake of the supercharger. you must allow all the new air to feed to the blower unrestricted. :)
    what you may get is a slight bump in the chart because the TB is opening to more air sooner.
