Results 1 to 14 of 14
Thread: APR Cold Start
    Senior Member Two Rings seanix9's Avatar
    May 24 2017
    Melbourne - Australia
    APR Cold Start
    With the stage 2 file, APR has removed cold start which is great as it gets rid of the WG rattle.
    However I have noticed the disabling of cold start to be random. Most times there is no cold start. Then for some odd reason it will fire up with cold start.
    Has anyone else noticed this?
    Speaking to a friend of mine who also has APR 2, mentioned he gets cold start at times.
    Keen to hear why the cold start is a random occurrence.
    Current - 2018 RS3 Sedan
    Past - 2016 RS3 SB
    Current: 2018 Ara Blue RS3 Sedan
    Past: 2016 Glacier White RS3 SB
    Instagram: Melbourne_rs3
    Established Member Two Rings cantcatchtomm's Avatar
    Jul 31 2017
    Portland, OR
    If I...
    1-turn the ignition on
    2-put it in comfort mode
    3-put exhaust in standard
    4-start engine...
    it doesn’t do the cold start.
    If I forget to do those steps it does do the cold start. (Regardless of whether the car was in comfort/standard when parked)
    Just something I’ve noticed in the 4 or so weeks I’ve had it stage 2. May be other experiences or solutions.
    May 24 2017
    Quote Originally Posted by cantcatchtomm View Post
    If I...
    4-start engine...
    My car is mainly left in dynamic. No cold start most times.
    Then randomly it shakes the garage and roars to life. It's actually deafening when you have an AWE exhaust to amplify the effects.
    Past - 2016 RS3 SB
    Jun 15 2017
    Snohomish, WA
    Quote Originally Posted by seanix9 View Post
    Past - 2016 RS3 SB
    Noticing the same issue with the cold start on APR Stage 2. Some times it will go through the higher RPM cold start and some times it won't. Funny thing is, I started with an APR Stage 1 tune a few months back. The Stage 1 tune had the same issue. APR released a revision to the tune. After getting the updated tune, the cold start issue went away.
    I have a feeling the same thing will happen in this case. APR will release an updated tune for Stage 2 and the cold start inconsistency will be gone. I know they've already done a revision for the "cut" at 4k rpm on the Stage 2 tune.
    May 24 2017
    Quote Originally Posted by steveo987 View Post
    Thanks for your feedback.
    The other big difference I have noticed is that stage 2 is quite linear and pulls hard up the mid-top rpm range.
    Stage 1 was a lot more aggressive off the line. To the point I was even breaking traction in 2nd gear at times. Stage 2 feels no where as rapid.
    Past - 2016 RS3 SB
    Jul 10 2018
    Stamford
    SB
    Have you contacted APR directly or Arin@APR on here? I would make them aware of this as soon as possible so they can release an update if the behavior is not intended. That “cold weather, fuel cut” thread went on for months before Arin said he was made aware of the thread and issue.
    May 24 2017
    Quote Originally Posted by Aramze View Post
    Good point. I will give Arin the heads up
    Again this morning car fired up on cold start.
    Past - 2016 RS3 SB
    Veteran Member Three Rings Wkraus's Avatar
    Sep 25 2017
    Prior lake minnesota
    Past - 2016 RS3 SB
    They had to “fix” the fuel cut by dropping boost so it didn’t demand as much fuel. When I had my 3 that is what custom code was gonna do. Turn it down until the issue went away. I sold it before I had to mess with it though. And I had the exact same issue with the cold start when I tried apr!! Forgot all about it. Did that to me a few times totally randomly
    Established Member Two Rings 5_cyl's Avatar
    Nov 12 2018
    Salt lake city
    I just got the APR stage 2 update and it fixed the issues. Incase you haven’t heard APR resolved the issues with the tune in cold weather.
    Senior Member Two Rings whitewaterguy87's Avatar
    Dec 12 2018
    A badass Scooter! I've had an 05, STI & 1998, 3000GT VR-4
    Northwest
    I kinda like the start-up... My beast coming alive but i just hit my the button 5 times & its sound fine.
    Sent from my SM-G955U using Audizine mobile app
    May 24 2017
    Quote Originally Posted by 5_cyl View Post
    Hi,
    APR has a V1.1 out? Did you have a similar issue with cold start on your old file?
    I have their original V1.0 and I'm getting cold start up more often now and it's summer here in Australia
    Past - 2016 RS3 SB
    Nov 12 2018
    Salt lake city
    Yeah I had it on my V1.0 but not on V1.1
    May 24 2017
    Champion
    Thank U very much. I'll go get the update.
    Past - 2016 RS3 SB
    Stage 2 Banner Advertiser Four Rings Arin@APR's Avatar
    Aug 23 2008
    Auburn, AL
    Can you email our support team so we can look into this?
    [email protected]
    Thank you!
    Quote Originally Posted by Wkraus View Post
    100% incorrect.
    The update has no power/tq difference and no drop in boost.
    Thank you!
    -Arin
    GoAPR.com | Facebook | YouTube | Twitter | Instagram
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
