https://dbilas-shop.com/en/engine-va...di/3-6-4-2-v8/
I would contact them and see if they'll do something for the RS5. Those may be for the B7 RS4 or B8 S5 V8. Not sure what the OEM lift/duration is on the RS5 off hand.
Also, I talked to someone else and you can see good gains from porting the RS5 and R8 heads. Take a look at the exhaust valves. Again, I don't know the size off hand but the 2nd gen exhaust valves out of the R8 V10 may fit. They're 1mm thinner and flow better than the first gen. R8 V10 exhaust valves.
Velocity is going to be critical so I'd find someone who's experienced with high revving n/a setups to port the heads. If you were going forced induction, you could mostly just hog them out.
Also, check with Shrick for complete camshaft kits. They may not sell directly to the public, might have to go to a vendor.
http://www.schrick.com/index.php?article_id=50&clang=1
All of this would, of course, require custom ECU work.
