Originally Posted by
Dawid
Correct.
Pre facelift have seperate module
Facelift have all pdc connected directly to the BCM.
I have facelift BCM because i facelifted the car with matrix headlights.
I still have PDC module in the trunk because its simply is too much work to rewire and no end result.
So ik my BCM all pdc is not coded as it runs through the PDC module and is coded in there.
In your case you simply add the missing wires to the BCM and activate PLA / 360 OPS.
Rewiring PDC to seperate pre facelift module would be a waste of time.
@Dawid, hi!
I have pretty the same config as yours.
I have A7 2010 and did facelift for it with BCM replacement. I've replaced ordinary parcklife 8k(
Part No SW: 4H0 919 475 H HW: 4H0 919 475 C) with PLA module (
Part No SW: 4H0 919 475 M HW: 4H0 919 475 E), so i got PLA works well but OPS 360 doesn't.
PCD looks like:
My scan:
Code:
Thursday,23,July,2020,10:46:22:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.1.0 (x64)
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ4G2BN006250 License Plate:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 20 28 30 34 36 3B 3C 42
44 46 47 52 53 55 56 5F 62 6C 6D 72 88 89 8F 90
VIN: WAUZZZ4G2BN006250 Mileage: 142777km-88717miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
88-Multicont. Seat Driver -- Status: OK 0000
89-Multicont. Seat Pass. -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CHVA) Labels: Redir Fail!
Part No SW: 4G0 907 552 D HW: 4G0 907 552 D
Component: 2.8l V6 FSIH06 0004
Revision: --H06---
Coding: 1A250034042E01020800
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM28FSI0214G0907552D 001006
ROD: EV_ECM28FSI0214G0907552D.rod
VCID: 2B55B2AB420539171C-807E
No fault code found.
Readiness: 0010 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G2 927 156 G HW: 0B5 927 156 K
Component: 0B5 28 FSIRdW H03 0002
Revision: --H03--- Serial number: 0000001604
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501021 A03005
ROD: EV_TCMDL501021_A03.rod
VCID: 326BAFCF652F68DF5F-8066
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0183
Revision: -------- Serial number: --------------
Coding: 02A6C7024065E340DB00
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6ED37BBFB1970C3F7B-803A
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 FT HW: 4H0 907 064 ET
Component: BCM2 2.0 H36 0551
Revision: 00002001
Coding: 05AA2F06000000000000
Shop #: WSC 02391 785 00200
VCID: 000F350793030A4F99-8054
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2310000036922011
Address 06: Seat Mem. Pass (J521) Labels: None
Part No SW: 4H0 959 760 E HW: 4H0 959 760 E
Component: MEM-BFS H08 0156
Revision: AA000000 Serial number: 00000072173297
Coding: C018330085847201000001010101112131303333283333
VCID: 356194D39C417FE77A-8060
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 L HW: 4G0 820 043 L
Component: KLIMA 4 ZONEN H12 0065
Serial number: 21111100040898
Coding: 468300BF28
ASAM Dataset: EV_AirCondiComfoUDS 002036
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 285F4DA753F3120FF1-807C
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 GH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0368
Revision: 1502003S Serial number: 00001848477702
Coding: 0105001145749FE0C9014084A0001800CF9CC3082E08010100000894ED00170200400000070000
VCID: 74E769D7D7BB26EF8D-8020
Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
Component: WWS57X 101104 H32 0051
Serial number: 101106075019
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11066677
Coding: 02562B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 08 11 2010 00000238
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: FA08C255000000000001
Address 10: Park/Steer Assist (J791) Labels:| 4H0-919-475-7X5.clb
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261128401755
Coding: 340304
Shop #: WSC 00028 028 00001
ASAM Dataset: EV_EPHVA2CAU57X0000 002008
ROD: EV_EPHVA2CAU57X0000.rod
VCID: 3C7781F7B76BAEAF85-8068
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG0013ACL
Coding: 30314530323130303031554A304C34473853
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
VCID: 366393DF894774FF73-8062
Crash sensor for side airbag: driver side:
Serial number: 3575HRB405L07OTS30UB
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB404T06JDCEOC+
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB404P036N2GPMT
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB40696THNE197P
Crash sensor for front airbag: driver side:
Serial number: 3554VRB404R04QM0A0NY
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB404V04QM0P8UQ
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4H0 953 568 H HW: 4H0 953 568 H
Component: Lenks.Modul H03 0003
Revision: -------- Serial number: 90372JKA000Q8
Coding: 000434
VCID: 387F9DE78B53828F61-806C
Subsystem 1 - Part No SW: 4H0 951 528 E HW: 4H0 951 528 E
Component: E221 - MFL H07 0009
Serial number: 20 08 2010 11039784
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 12
Reset counter: 89
Mileage: 142765 km
Time Indication: 0
Date: 2020.07.22
Time: 13:37:57
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 930 M HW: 4G8 920 930 M
Component: TBenRdw H34 0303
Revision: 18100069 Serial number: 658171110593015
Coding: 03A600021B030008010100
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 377D9EDB8E4D8DF768-8062
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G5 907 468 H HW: 4G0 907 468 AC
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002348662
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002_AU57.rod
VCID: 3A7B87EFBD5F909F97-806E
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650214473
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 B HW: 8K0 959 663 B
Component: J532_DCDCStab H05 0006
Serial number: 10315001302021200410
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 04018E64747464545425363E
VCID: 3365AACB923561D754-8066
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 D HW: 4G0 919 158 D
Component: KLIMA FOND H07 0054
Serial number: 05111000040147
Coding: 00
ASAM Dataset: EV_ClimaContrUnitRearUDS 002010
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 306FA5C76B235ACF29-8064
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000008117
Coding: 01010101000000000000000102
VCID: 64C71997675BB66F1D-8030
Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
Part No SW: 4G0 907 553 B HW: 4G0 907 553
Component: LUFE-DAEMPFER H17 0778
Coding: 008000
ASAM Dataset: EV_AirSuspe 003022
ROD: EV_AirSuspe_VW51.rod
VCID: 2A5BB7AF4DFF201FE7-807E
Address 36: Seat Mem. Drvr (J136) Labels: None
Component: MEM-FS H08 0156
Revision: AA000000 Serial number: 00000072133897
Coding: C018330085857201000001010101112131303333203333
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA420056AL0
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D51BCB37C11372702-8078
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 4G0 907 566 J HW: 4G0 907 566
Component: J769 SWA MasterH04 0060
Revision: 00H04000 Serial number: 6PZ 010 287-08
Coding: 0000103
VCID: 366393DF414774FF73-8062
Subsystem 1 - Part No: 4G0 907 568 J
Component: J770 SWA Slave H04 0060
Subsystem 2 - Serial number: 6PZ 010 287-28
Subsystem 3 - Serial number: 5F14.02.1300H04000AMS15178ÿ
Subsystem 4 - Serial number: S15178ÿ
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F5E625E20628002080012
Shop #: WSC 28035 001 104857
VCID: 4581E413CCA1EF67EA-8010
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000813313
Coding: 101100010001
Shop #: WSC 15966 002 104857
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0336226326
Coding: 013A0E2020B9BC8583300A040A0300000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 7P5 959 591 HW: 4H0 959 591
Component: J245 PS40.033 H06 0006
Serial number: WOO10814390
Coding: 001F00
Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
Component: HSP-SG H09 0027
Serial number: WA101833000000126953
Subsystem 5 - Part No SW: 3AA 962 243 G HW: 3AA 962 243 G
Component: GEB.F.Heckoef H16 0903
Serial number: 84381235
1 Fault Found:
03932 - Real Lid/Hatch Opening Sensor
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 88
Mileage: 142765 km
Time Indication: 0
Date: 2020.07.22
Time: 13:38:01
Address 47: Sound System (J525) Labels: None
Part No SW: 4G0 035 223 A HW: 4G0 035 223 A
Component: BOSE G3 C7 H07 0070
Revision: CJ007000 Serial number: 00000000008781
VCID: 1B35626B1AA5C9976C-804E
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 B HW: 4G8 959 792
Component: TSG BF H04 0209
Coding: 011F5E625E20628202080002
VCID: 3E738BFFA977BCBFAB-806A
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 D HW: 4H0 907 801 A
Component: EPB-4 H03 0010
Revision: -------- Serial number: 00000000017838
ASAM Dataset: EV_ParkiBrake 001021
ROD: EV_ParkiBrake_VW51.rod
VCID: 295948A348F92B07EE-807C
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 05FA02102A600200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 3467A9D79F3B66EF4D-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7570
Coding: E02000
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7570
Coding: E02000
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 053 J HW: 4G0 035 053
Component: Radio U Basic H52 0133
Revision: AB001007 Serial number: 050K.0A7529507
Coding: 010003010000000001
VCID: 254144932CE10F67CA-8070
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 666 P HW: 4G0 035 666
Component: H-BN-EU H46 1072
Revision: -------- Serial number: 426KY0AB000348
Coding: 090100040003F1FF55108B1E00000003F00001000000000000
Shop #: WSC 00046 123 12345
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDA130051XC
Subsystem 3 - Part No SW: 4G1 919 610 C HW: 4G1 919 612 C
Component: E380 BDT C7 H08 0204
Serial number: 90349JKB0004M
Subsystem 4 - Part No: 8R0 060 961
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 B HW: 4G8 959 795
Component: TSG HL H02 0210
Coding: 010F1C624020628002080002
Shop #: WSC 02312 785 00200
VCID: 4189F003D889C347D6-8014
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H03--- Serial number: 525 PA8J0XF0A1
Coding: 1020013
VCID: 25414493ECE10F67CA-8070
Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
Part No SW: 4G8 959 107 D HW: 4G8 959 107
Component: HDSG-Modul H12 0036
Revision: 11012001 Serial number: 300000364
Coding: 0A3205C000
ASAM Dataset: EV_HDSGAu573 001014
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H02 0210
Address 88: Multicont. Seat Driver (J873) Labels:* None
Part No SW: 4H0 907 182 H HW: 4H0 907 182 H
Component: IVB H07 0042
Serial number: 00012592127202
Coding: 662FF2
ASAM Dataset: EV_IVBDriveSideFrnt 001003
ROD: EV_IVBDriveSideFrnt.rod
VCID: 2F6DA6BB761D453730-807A
Address 89: Multicont. Seat Pass. (J872) Labels:* None
Serial number: 00012592127702
Coding: 262FF2
ASAM Dataset: EV_IVBPasseSideFrnt 001003
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030801424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FED66BBB69D053770-803A
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70EF65C7ABA31ACF69-8024
End-------------------------(Elapsed Time: 06:33)--------------------------
Could you please share your 09 and 10 blocks coding?
