hi all, already read several threads about this problem. but mine is specific.
so here it is.
1. brake light faliure light up on the dash board
2. i change the lightbulb, nothing happens
3. i then proced to disasemble the wire harness
4. the brown wire on connector was a bit burn and plastic melted around.
5. cut the brown wire from conector, soldered new ground wire to metal rail inside the lights holder, soldered the new wire to brown wire from connector.
6. still nothing hapens.
i have tried to measure without bulb i get 10v of voltage, with bulb nothing.
everything other works fine.
this one light bulb is for taillight and brake, on the other side works fine, taillight is dimmed, whan press brake full power.
the bulbs are p21w...
any suggestion as what i can check more???
thank you
